Question about HP Compaq Presario SR1820NX (ER919AA) PC Desktop
I need a clean installation of Vista
When my hubby's laptop expired (Motherboard) he used the recovery form the laptop to install Vista on our PC which was preinstalled with XP. This has been fine for almost a year but has now started losing files etc. System restore will not work and we have lost the laptop recovery disc which was used. The PC has a format option to restore to factory settings, but I assume this will take it back to XP. Any ideas out there please?
  • mbox000-sas May 10, 2009
    Thanks, that is very helpful - except that I no longer have the COA as the laptop was disposed of.
  • 433 Answers
If I understand this correctly, If you are using the system restore, it will maintain the last operating system install. When you went from XP to Vista, XP is totally gone. So your only option the will arraise it to restore system and if successful should be just fine.(I know that you mentioned it didn't work) you may have to do a total reinstall with Vista. If you can locate the disc.
Now the part that is left in a particitlon is as you thought...XP unless you formatted the whole drive what you installed VIstA in which case you will have nothing.
As long as you have a COA sticker on your computer you can borrow a disk from someone who has dell, and call the microsoft number and explain that you reformatted and use another copy to put it in and they will get you through the activation. Use the numbers on your sticker.
Good luck please leave rating.; thank you
Posted on May 10, 2009
Problem installing Vista SP1 on Asus G2s
If you tried to install Vista on the Primary drive and formatted the primary HDD your Factory Recovery Partition , most likely has been written over, it's gone. Choose one or the other , Vista or Win 7, start from the beginning, install a clean Vista load, formatting in the installation procedure, form a Vista Installation DVD, follow instructions, boot up, do ALL the Vista Updates, it will take hours of updates, rebooting, updates, rebooting. You will get to the Service Pack's 1 and 2, in 24 hours or so. Put on a pot of coffee and be patience. If you prefer Windows 7 use the same procedure.
May 09, 2013 | Computers & Internet
Did a clean install of my laptop. Windows does not acknowledge Windows Vista Home Premium
There will be a sticker on the laptop wi the product key. It will be in the format of xxxx-xxxx-xxxx-xxxx-xxxx Sometimes the sticker will be under the battery. If the sticker is not on the laptop it was either removed, or you need to make a complaint with Walmart.
Apr 17, 2013 | Dell Inspiron Computers & Internet
HP Pavillion Desktop Computer, with windows vista installed. Tried to do a system recovery using disks that ex hubby created for me and now I can't log back on.
may be the disk can not read by windows update. Try to recover by using RESTORE the computer to some date that was working before.
Update the BIOS +CHIPSET and try it.
God bless you
Oct 10, 2012 | Computers & Internet
Installing Vista Home Basic at clean install got an error code 0x80070057 Windows could not format a partition on disk 0 the error occurred while preparing the partition selected for installation _____...
this sounds like a hardware issue, i suspect the harddrive. Try formating it and running diagnostics form a hDD external enclosure. Run a full scan disk and then format it form there before initializing it and back to the laptop for full installation of Vista
Sep 22, 2011 | Acer Aspire 5742Z-4200 Notebook
How to reformat laptop
  • 1
    If you have the recovery cd, you can just pop-in the CD, select the reformat option and the installation process will continue automatically. Some laptop might have a special partition in the drive contains the operating system, drivers, etc. in case you want to reformat your laptop without the CD.
  • 2
    If you don't have the recovery CD, you usually can request one from the manufacturer. Otherwise, if you want to do a clean install, make sure you download all the drivers for your laptop, this may includes: motherboard, chipset, graphic card, sound card, modem, network card. Once you do that, put in the OS CD and start installing.
  • 3
    If you decided to do a clean install without the recovery CD, it would be best to create partition on your harddrive first, so you can have dedicated partition for operating system and backup. The next time you want to reformat your harddrive, you can just reformat that particular partition ex. C:\
  • May 05, 2011 | Computers & Internet
    Forgot password, does not have cd rom drive, need to restore to factory settings. How???
    How to obtain Vista Recovery Media and/or use the Vista Recovery Partition on your computer to put it back to Factory Settings.
    There is no legal free Vista download available.
    Contact your Computer Manufacturer and ask them to send you a set of Vista Recovery disk/s.
    They normally do that for a small $ cost.
    Also, ask them if you have a Recovery Partition on your Computer/Laptop to restore it to Factory settings.
    See if a Manual came with the computer, or go to the Manufacturer's website, email or phone them for info on how to do a Recovery.
    Normally, you would press F10 or F11 at Startup to commence the Recovery Process..
    Another way I have seen on some models is to tap F8, and go to a list of Startup options, and start a Factory Standards Recovery from in there, by selecting the Repair computer option.
    Also ask them if it is possible to make Recovery Disk/s from the Recovery Partition in case of Hard Drive failure or System Crash.
    They will tell you how to do that.
    Each Computer Manufacturer has their own way of making Recovery Disk/s.
    Or borrow a proper Microsoft Vista DVD(not Dell, HP, etc).
    A proper Vista DVD contains all Vista versions.
    The Product Key determines which Vista version gets installed.
    There are 2 Vista disks: one for 32bit Operating System, and one for 64bit Operating System.
    If a clean install is required with a proper Vista DVD (not HP, Dell Recovery Disks):
    Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
    At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu
    http://support.microsoft.com/default.aspx/kb/918884
    MS advice on doing clean install.
    http://www.theeldergeekvista.com/vista_clean_installation.htm
    A Tutorial on doing a clean install
    http://www.winsupersite.com/showcase/winvista_install_03.asp
    Windows Vista Installation Super Guide
    After installation > Go to your Laptop/Computer Manufacturer's website > Drivers and Downloads Section > Key in your Model number > Look for latest Vista Drivers for it > Download/install them.
    Save all Data, as it will be lost during a clean install.
    Post back if it is not working we will be happy to help you.
    Hope this helps.
    Cheers!!!!
    Jan 09, 2011 | Compaq tc4400 Tablet PC (RL875AW#ABA)
    I have oem key of lenovo vista home premium (on back of pc). How can I use it for activation of a clean install? The motherboard was replaced by the company recently. One recovery is not working.
    The only resolution for this problem is to send the unit back to the lenovo service center for them to register the new motherboard in the system and also to reimage the HDD so that the one key recovery can work again..Call 18774536686 and press option 2 for hardware support so to request for depot repair
    Oct 30, 2010 | Lenovo IdeaPad Y550 Notebook
    Toshiba A205-S5879 laptop won't boot
    Please resort to your installation discs that came originally with your computer package. Those install discs can be used as recovery discs. Try to do an OS repair install from those discs. If the problem still persists, I would suggest to wipe and format the hard disk and start a clean installation again. I understand your warranty expired but if it was only let's say three days ago, it should still be disputed. If your new installation doesn't work either, then I would suggest you contact your supplier to work out a replacement of your hard disk. Good luck.
    Feb 05, 2010 | Toshiba Satellite A205-S5879 Laptop
    Sound card dont work
    can u install sound driver of your laptop if u have not install then install form the recovery cd or drvier & utility cd/dvd of your laptop its come with a laptop or if u have miss that cd then u need to download your sound driver
    Jan 16, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
    I newly bought a fujitsu laptop
    If the laptop is new and won't boot, either take it back to the place where you got it, or else put the recovery CD in the drive and try to do a full install using the recovery CD. It sounds to me like you have a used or ex-demo laptop that someone wiped by doing the first part of an installation process to unpartition and then repartition the drive to wipe all data. Try rebooting to the CD recovery disk and installing a clean OS.
    Good luck...
    Nov 17, 2007 | Fujitsu Siemens LifeBook T-3010 Notebook
    HP Compaq Presario SR1820NX (ER919AA) PC Desktop Logo
    160 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
