No hot water coming out of any faucets
Came back from vacation ... no hot water. No signs that the hot water tank had leaked. What should I do?
    President:
  • 1,136 Answers
Hi, First thing you need to check is that the hot water valve might have turnd off. What you can do if the valve is on, Turn the machine on and set it for hot water only. If you can here a faint hum, then the inlet valve on the machine is probably plugged with sand. Turn the hot water valve off and remove the hoses. Look into the water inlet valve and there you will see a fine mesh screen. This might be plugged. If the screen is plugged, be careful and just scrape the sand out or you can flush it out by using the inlet hose and turn it on with short spurts. You will get a little water on floor but, it is effective.
If there is no hum or there is no plug, the inlet valve is probably bad.
I hope this helps. If so, please rate my answer so that I know how I am doing.
Thanks,
Vic
Posted on May 10, 2009
What do I do if my hot water is low and sputters in my tub in 2005 jayco flight 5th wheel?
Greetings and good health to you.
Ok, so I'm guessing by low you mean quantity and not temp, correct?
Does the cold water sputter as well? If so, most likely bad pump but we'll go with it just being the hot water for now.
Does the hot water act the same way on the other sink faucets? If not, the hot water is flowing freely without sputter, the problem will most likely be in the tub's hot water valve (knob) or the shower attachment. You can replace these rather easily.
If your hot water is low in quantity and sputtering only on the hot, then your hot water tank is not getting enough water to it which will cause it to be "low" and sputter as there isn't any water in there to pull from. If this is the case, we need to figure out what is causing the hot water tank to not have water in it.
Your pump is obviously working as you are only having issues with the hot water. Since using the hot water would normally use what hot water is sitting in the tank and thus pull in fresh water to heat up as the hot water exits. This would be the case if you are using the on board water storage and not hooked up to a hose for your water supply.
So, if this is the case, we need to find out where/why the water is not drawing in from the water storage to the hot water tank. First off, locate both tanks and make sure there isn't a valve on the water line that may be turned off or almost off. Check those water lines for any breakage or leaks. If not, if there are two lines coming out of the water storage, one for the cold and the other for the hot, see if you can notice anything in the water tank that may be blocking the "hot" line.
If all that is well, lets look at the water heater itself. I'm guess you would have noticed if this was leaking which is why I waited until now to bring it up. If you go outside and open the panel, does it look like it could have been leaking? Look at the plug (this is where your heating element is located) at the bottom center of the tank. Does it feel damp or can you see streaks going down from there? If unsure, hook up your hose to the water intake and turn it on. Watch the tank from the outside and see if it starts leaking. If it does, bad plug (heating element) easy and cheap to replace.
Once you see there is no leaking coming from the hot water tank, lets take out the heating element to make sure it is filling up. First shut off the water flow. You'll need a large adjustable wrench or if you happen to have that big of a socket, go for it. Remove the element. Water should start coming out as you unscrew it. Once you remove the element, water should flow freely out until empty.
Now, with the plug out, turn the water back on and see if it flows out of the tank. This will show flow is good up to this point.
Ok, so if there are no leaks thus far and the hot water tank is filling up when you hook up a hose, then we need to look and the connection line going from the tank to the rest of the faucets. Put the plug back in. Turn the water on again and follow the lines from the tank to the faucets looking for leaks.
Once you do all this, you should have an idea of what is happening where and possibly how to fix it.
Let me know how it turns out.
Nov 03, 2015 | RVs
Water meter keeps running. When I turn off the water supply to the hot water tank the needle on the water meter stops, does that mean that I have a leak in the hot water pipe coming out of tge tank.
Yes you have a leak on hot pipe or TP overflow tube.
Put ear against pipe to listen for sound of running water.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
If TP valve goes into drain line, check if water is running down TP overflow tube.
Check each faucet for leaks.
If pipes are under slab, put ear against each faucet to determine which faucet is closest to broken pipe.
Mar 23, 2013 | Water Heaters
Gas ignites flame but water is not getting hot
You have gas water heater with working burner.
But not getting hot water at faucet?
1) Bad faucet cartridge. Test for crossover. Copy following link:
http://waterheatertimer.org/Crossover.html
2) Is there hot water inside the tank? Open drain valve and check for hot water.
3) Drips and leaks: Turn off all taps and put ear against pipe and listen for water leak.
Water leak can run all the hot out of tank.
Dec 05, 2012 | Water Heaters
Heater comes on with water
please see the next step:
he pilot light may be out or may not stay lit. There may not be enough hot water, or the water may be too hot. The water heater may leak or be noisy, or the hot water may be dirty.
A problem with your water heater may be due to overwork, not mechanics. If your water heater holds less than 15 gallons per family member (tank volume is stamped on a metal plate affixed to most water heaters), consider a larger unit or staggering your use of hot water.
Drain a hot water tank:
  1. Turn the gas-control knob to off and close the gas-shutoff valve.
  2. Close the cold-water supply valve and open a hot-water faucet in the house to speed draining.
  3. Attach a garden hose to the drain valve and run it outside to a drain. If the heater is in the basement you may need to run the hose to or through a sump pump.
  4. Open the drain valve and allow the tank to drain.
  5. Once done, close the drain valve, open the cold-water supply valve, and open any nearby hot-water faucet. When a steady stream of water flows from that faucet, the tank is full; close the hot-water faucet.
  6. Once the tank is full, turn on the gas and relight the pilot.
Jul 31, 2012 | Heating & Cooling
Turned off the hot water to fix a leaking tap. now the tap has no hot or cold water and the hot water tank valve is leaking?
It sounds like two problems.
Problem 1) Clog inside faucet or clog inside pipes at faucet
Remove supply tubes leading to faucet and see if problem is inside pipes or inside faucet.
My bet is clog inside faucet.
If you have galvanized pipe that meets copper pipe, this can be trouble spot.
Article on clogged water pipes at Inspectapedia:
http://www.inspectapedia.com/water/Water_Pipe_Clog_Repair_Guide.htm
Article on clogged pipes:
http://www.waterheaterrescue.com/pages/WHRpages/English/Troubleshooting/Tanklets/backflushing.html
Problem 2) Water heater leak ... you say tank valve is leaking? Is that cold-water shut-off valve? Or tank drain valve? Or TP valve?
If cold water shut-off is leaking, then replace shut off.
If tank drain valve is leaking, then check if plastic valve is cracked. If drain valve is cracked, then replace with a brass valve from Home Depot. If plastic valve breaks off, then use hammer and screwdriver to gently chip out the broken plastic valve. New valve threads need teflon tape to seal pipe. If valve is just dripping, then put garden-hose cap over end of valve and screw down tight.
If TP valve is leaking, then replace with same temperature and pressure rating.
New TP valve threads need teflon tape to seal pipe.
Problem 3) If pressure is low all over house:
Buy pressure gauge at hardware store that screws onto hose connection.
Test pressure on outdoor spigot.
Open faucet and check if pressure drops. This says if problem is inside pipes that enter house.
Test pressure on water heater drain valve.
This says if pressure problem is before -or- after water heater.
If problem is before the water heater, then shut-off valve located on cold water line is suspect.
If problem is after water heater, it could be in hot water outflow pipe on top of water heater, or a nearby elbow.
Remove hot water line leading from water heater and check pressure. This says if problem is where hot water leaves tank.
Read articles above about clogs inside water lines.
Nov 16, 2010 | Rheem Water Heater Pressure Relief Valve
Hot water does not last long. Model 82vh40-2 mnf. 05/2005
If the lower heating element burns out the upper element will heat the top part of the tank then shutoff. homw depot/lowes etc should carry elements. 1 turn off breaker, remove element access cover (the 2 panels on the front of the heater) test for electricity at the reset button ( uppermost device in upper panel) to make sure power is off. 2 turn off water (I usually turn off the cold water main to stop water cross feeding into hot supply line back into heater) 3 disconnect the 2 wires on the lower element, test with continuity tester. shhould be no continuity between terminals and tank, but around 10 ohms between the 2 terminals. Check the thermostat for continuity if tank is cold thermostat should be closed ie zero ohms across the 2 terminals.
If stat is bad replace stat; disconnect wires push it up out of the spring clip insert new stat reconnect. If element is bad: drain tank. connect garden hose to tank drain valve, open tank drain valve turn water main on to clear rust sediment and get water flowing. Next remove filter screen from a hot water faucet then turn on ( a hot faucet upstairs or higher than tank drain). Now turn water main off, air will now go in through hot faucet and tank will drain, takes about an hour. Use a water heater element wrench about$10 to remove element(s) make sure no bits of rubber gasket are left in element opening- dig em out with a screwdriver if needed. Insert new element with its gasket and tighten. reconnect wires DO NOT TURN ON ELECTRICITY! BE SURE TO FILL WATER HEATER WITH WATER ! Turn water main back on -air will come out of the hot faucet for several minutes. When water runs without any air sputtering, turn off faucet and replace the faucet filter screen. check element(s) for leaks. turn breaker back on.
Feb 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
