Question about Behringer PMP1000 Europower Powered Mixer
Behringer pmp 3000 power supply got burnt, where can i purchase the power supply.
    Sergeant:
  • 336 Answers
That , as far as I know, can only be bought through Behringer. They will probably NOT sell it to you or help you. THEY want you to buy a new one. This is one of those companies that has most of their semiconductors marked and labeled with odd numbers of their own so a technician will have no clue what values they are or where to get them. Behringer is the one main brand of equipment I have never been able to get ANY parts for other than colored resistors or diodes, some caps, switches and lights. Finding a schematic is easier done than to actually find replacement parts. Sorry, wish I could help more while being as honest as possible.
Posted on Dec 03, 2013
SOURCE:
hmerchant110
  • 7191 Answers
SOURCE: I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on Jan 15, 2010
  • 5603 Answers
SOURCE: Where can I buy a fuse and fuse holder for my
DO NOT REPLACE A FUSE if it blows. You will do additional damage to the unit internally.
When these blow, there is damage inside that must be repaired before restoring power.
To get an exact replacement fuse holder it is best to get it from Behringer parts. This one has a switch in it depending on which way the fuse carrier is inserted.
Posted on May 12, 2010
  • 5603 Answers
SOURCE: Fuse and fuse holder needed for Behringer 3000 pmp mixer
Try this Behringer support:
BEHRINGER USA, Inc.
18912 North Creek Parkway, Suite 200
Bothell, WA 98011
Tel.: +1 425 672 0816
Fax: +1 425 673 7647
I just repaired a PMP3000.
A bit of warning on these. Do not let a speaker leads get pulled while powered. They can arc out the power amp causing extensive damage.
If the fuse ever blows do NOT replace the fuse as much more damage will result. Service the unit before using.
Posted on May 13, 2010
toolkits
  • 1099 Answers
SOURCE: I HAVE A BEHRINGER PMP POWERRED MIXER 5000,I LOST ...
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} tries websites like Shopjimmy.com,Ebay.com to buy parts for the replacement.
Good luck..
Posted on May 23, 2010
  • 5603 Answers
SOURCE: my behringer pmp 3000 has litle power i thing is
The unit should drive 400 Watts RMS into a 4 ohm load per side.
The amount of sound power you get will VASTLY depend on speaker efficiency. You would likely use at least 15 inch speakers with the unit.
Posted on Aug 08, 2010
I have a ppm 3000 and one of the XLR outs quit working. Easy fix or not worth it? Everything else works fine. Suggestions for a replacement??
If it's really just the socket that's quit then it may be an easyish fix depending on which one. If it's worth fixing really depends on which XLR out had died and in what way. These were from the 'bad' behringer phase and are normally not worth fixing.
Sep 27, 2013 | Behringer PMP 3000 POWER MIXER
We are trying to purchase a pmp mixer for our church choir. What's the difference between the pmp 3000 and the pmp 4000? Thanks!
The answer is "Not Much"... they upped the rating for power out and added 1000 to the model number... I don't know of any circuitry difference between them... it would probably be minor. Functionality is the same.
Oct 17, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
My europower pmp 2000 powered mixer wont turn on and the fuse appears good. I turned it on and it immediately turned off ,nothing smells burnt. any ideas on what it could be
This is likely a power supply failure, possibly brought on by a failure of one of the amp channels.
This is probably close to your supply:
http://elektrotanya.com/behringer_sps600_power-supply_sch.pdf/download.html
Scroll down to "get manual" and click on that to download schematic. Ignore other download links.
Aug 05, 2011 | Behringer Pmp2000 Europower 800w 10ch...
I have a behringer PMP 3000 mixer, on e of the channel is gone, it is not under warranty, can you tell me who can repair it ? what causes the channel to blow.
Often the A channel power output blows. CEASE using the unit immediately until repaired as continued use can have additional damage to power supply.
Any problem with speakers can blow the channel as there is real weak insulation on a multi-layer circuit board in the rear most amp (channel A). It burns and takes out three transistors on the HCA2400 module inside.
ALSO read my tip on here regarding a hazard of Behringer PMP units due to the channel A connection when using Speakon to 1/4 inch plugs or adapters having the BARREL being the hot lead instead of the TIP of the 1/4 inch plug. Short that barrel to ANY ground and goodbye channel A.
Jan 06, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
How do i plug in xp 4000 do i need balanced or un balanced to pmp 3000 tell methe whole story please
What is an XP4000 ??? Searches come up with coffee makers and un-interuptable power supplies.
No audio devices appear to have this model number.
Dec 20, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
My behringer pmp 3000 has litle power i thing is 3000 or how much power it haveit? I put 2 speaker only ,,,, thankyou
Aug 08, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
BEHRINGER USA, Inc.
Bothell, WA 98011
May 12, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Europower pmp 3000 120v or 220v ?
Unit has wide range power supply will operate on 100 volts to 240 volts without any change other than possible plug adapter to mate with each countries receptacle standard.
Feb 05, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer PMP1000 Europower Powered Mixer Logo
257 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
