Question about Hotpoint WMA74 Front Load Washer
How can i change the rubber seal on a Hotpoint WMA74? Or is it possibe to "turn" existing rubber seal as there is a slight cut at the bottom. Many thanks.
  • 221 Answers
Yes you can turn it, but be aware that on some occasion there might be some spashes even when the cut is at the top side. Dissassemble the spring-assembly (clamp-assembly) at the front side when door is openusing flat screwdriver. remove the top cover by undoing two screws one at each side of the top cover. pull out the detergent compartment, and undo three screws positioned from the front side just behind the detergent drawer, slide all the front panel to right side and it will come of. now unscrew three screws which been covered by front panel. gently pull all the front casing and disconnect the door-lock (2wire connection) put the front casing aside and dissassemble or just loosen enough clamp-assembly at the other end of rubber where the it is attached to the drum. turn the rubber to either side 180 degrees and assemble everything in the reverse order. Please make sure the rubber is properly in it's place when assembling.
Let me know about your progress.
Good Luck
Posted on Jun 22, 2009
  • John Whitworth Oct 22, 2011
    Thank you. You saved us a lot of cash. Only thing that wasn't quite as stated was after sliding the front panel off. On my machine, it did not reveal three screws, but two. An another two needed to be removed behind the bottom panel which just pulls off.
We wish to replace the rubber doorseal on Hotpoint WMA42P. I can remove the door seal ring but cannot quite see how the drum seal is fixed. Is it the same system with a sprung ring? Martyn
The following video is of a Hotpoint WF door seal replacement which is the same as the WMA series except the fascia panel is slightly different, make sure you take a photo of the wiring connections before you remove the fascia so you know where they go when you replace it
http://www.selfix-uk.co.uk/Video_page_washing_machine_door_seal.html
Jan 04, 2017 | Hotpoint Washing Machines
Removingclip from filter
hi it is a jubilee around rubber cup with hose to pump connected to botton of drum
Dec 08, 2013 | Hotpoint WMA74 Front Load Washer
Hotpoint wma74 wont spin
It could be the motor's carbon brushes have worn out. Replace with the same type. Need to get at the motor, you simply unscrew and slide out. If they are hard to reach then you will have to take the drive belt off and remove the motor and then take them out. These brushes provided the electricity to the motor in order for it to spin.
Aug 09, 2010 | Hotpoint WMA74 Front Load Washer
Very little water on wash cycle
water level is determined by the pressure system, and no adjustment can be made.Ensure your programe is not selected to half load.
Feb 18, 2010 | Hotpoint WMA74 Front Load Washer
How to change bearings on hotpoint wma74
Here are a series of free videos to help you with your bearing problems and how to fix them
For all your free videos on appliance repairs remember to mark us down and leave feed back please
For all your parts visit our site http://www.apart4u.co.uk
This first video shows you how to diagnose the problem
The next Hotpoint video is on how to take the drum out
This Hotpoint video will show you how to change the bearings in the drum tub
the last one will show you how to change the spider or drum support as they are known
Feb 08, 2010 | Hotpoint WMA74 Front Load Washer
Hotpoint WMA74 does not pump out after programmed
No test available other than:
Remove pump - check motor will turn by rotating impellor. There is a slight resistance then moves freely, then slight resistance and freely again. This is correct for this machine. worth checking there is no hair, elastic band or other obstruction around the impellor fins and shaft whilst the pump is out.
There is no spin cycle so you have to use rinse & spin, which means if the pump is shot you need to empty the machine each time :(
Worth checking lower filter as stated and blowing down the drain hose whilst the pump is off to check for obstructions.
The resolution to my problem was a new pump - £20.
All working fine again now !
Jan 24, 2010 | Hotpoint WMA74 Front Load Washer
How do i clean a blocked filter on a wma74
Remove the lower rear panel of washer.
Remove the large black hose fastened to the bottom of the drum.
Remove and clean the plastic filter inside hose, make sure you fit it back on correctly, or it will come off.
Remove the hose onto the pump, and check for obstruction or blockage here and in the pump itself.
Please rate my solution.
Thanks.
Nov 23, 2009 | Hotpoint WMA74 Front Load Washer
We have a Hotpint WMA74 - water gusting out of powder/liquid compartment at top when spins - have changed drain pump - but still happens - can you help?
It sounds like you have a partial blockage somewhere..
Remove rear panel.
Remove large black hose onto drum.
Check and clean filter inside hose.
Remove drain hose, and check for restriction here as well.
Thanks.
Nov 17, 2009 | Hotpoint WMA74 Front Load Washer
My wma74 Hotpoint WM door will not open
hi the error shows bcoz of ur door problem...replace the door lock and ur problem will be solved...
rate me
Jun 12, 2009 | Hotpoint WMA74 Front Load Washer
Where can I get a manual for Hotpoint-Ariston WMA74
In your browser bar type in the following:
hotpoint user manuals, then click on manuals user guides and click on user manual , find your model and download to your computer or print it off.
Plz leave feedback for this solution.
Dec 15, 2008 | Hotpoint WMA74 Front Load Washer
Hotpoint WMA74 Front Load Washer Logo
245 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
