Question about Canon PIXMA MP780 All-In-One InkJet Printer
Color copy not accurate from pixma mp780 it comes out yellowish
I've tried everything. Replaced all ink cartridges, used ink cartridges made just for cleaning. Im using Printpal ink, do you think that matters. I 've also checked all my set ups -set color adjustment to auto, Ran all the appropriate Maintenance requirements.
    President:
  • 1,335 Answers
I would try using a set of OEM cartridges. Make sure to run deep nozzle cleaning and alignment.
Some aftermarket cartridges are not as well quality controlled and tend to be inconsistent and gum up the nozzles.
If you need a source for good aftermarket cartridges try LD Products online.
Posted on May 11, 2009
Canon mx860 printer not using ink from PGBK 220
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 07, 2013 | Canon PIXMA MX860 All-In-One InkJet...
NEAR EMPTY M & Y BUT IS NOT.
try removing the cartrages and clean them with rubbing alcohol and a qtip. Do the same for the printer jets the cartrages sit in.
If that fails, unistall the printer software restart pc and reinstall printer software.
Nov 13, 2007 | Brother MFC 420CN All-In-One InkJet...
How do I reset or disable the ink level indicator on the Canon mg2120?
Inkjet cartridges dried up at the nozzles. Can be dissolved by water to print again. Refill cartridges done by yourself can have dried up ink left in the cartridge to make it too concentrated. Too easy to dry up.
Jul 15, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
Won't Print Color Ink
INK PROBLEM
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
Installed a refilled black 34 cartridge on a X7170 all in one printer. message says " incorrect cartridge" ERROR 2200. Thank you for help.
Sorry for the bad news that follows.
Extracted from Lexmark’s web site: www.lexmark.com
Lexmark End User Statement of Limited Warranty for Supplies
Lexmark International, Inc. Lexington, KY
Not Covered:
Warranty Service does not include repair or exchange when the problem results from accident, disaster, misuse, abuse, non-Lexmark modification (including refilling, tampered with in any way or remanufacturing), improper storage, malfunctioning equipment, laser print cartridges which are simply empty as a result of normal use, or normal wear and tear. Character or page yield is also not covered by warranty service, as it is influenced by customer application, printer contrast settings, operating environments, printer condition, and paper type.
Don
May 13, 2009 | Lexmark X7170 All-In-One InkJet Printer
Generic black ink cartridge causing black ink to not print
Never mix dye and pigment inks/machines Head could be screwed Try copying many black text only pages up to 200 but run head clean after 50 or so Inkypete
Apr 20, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Epson Stylus 440, solid light on for black ink, have replaced and still won't print
This morning I was researching to purchase a new printer to replace the 10 year one. The last cartridges I had purchased were from Printpal and made in China. They looked the same, but I had to force the door closed on them. With the solid red light on and replacing the cartridge three times with new ones from this order, it was time to find an old used cartridge from another company that I intended to refill myself. I did, installed it and the solid red light disappeared. The old Epson Stylus 440 is still ticking! However, I had written off InkGrabber for unused cartridges going dry in 2 months and now Printpal is on my $%%# list for non-uniform replacement cartridges as well as not lasting long. I am back to refilling my own. I had followed the instructions for resetting the ink level indicator, but to no avail as those instructions are for a blinking light, not a solid light.
I appreciate your website, if for nothing else, to be able to vent. Thanks so much for your follow-up inquiry and I'm sure you'll hear from me again soon about my old Epson.
Shirley
Aug 17, 2008 | Epson Stylus Color 440 InkJet Printer
Printer cartridge problem
I have a 440 and have had the same problem. Of course, I have been using cartridges from Printpal, Inkgrabber, etc. that are not official Epson. I have found that it takes several cleanings and after the cartridge has been in the position for the ink to go down it will start. My last order from Printpal said to set all the cartridges in the position they are in when installed in the printer for several days prior to installation. Of course, every cleaning of the print head uses up more of your ink. You don't have much choice though.
May 07, 2008 | Epson Stylus Color 440 InkJet Printer
Black ink not printing
Fix ink cartridge
I had same problem. I must have ran the clean cycle more than 30-50 times over a period of days. That never made any difference. I was about to toss the whole thing but figured I would try one more thing. If it didn't work I would be in no worse shape. Here is what I did.
Took an almost empty black cartridge and inject a lot of 100% Acetone to dilute ink. Left some black in it since I didn't want to think it was empty. Inserted this cartridge and ran the cleaning a few time. IT WORKED. I used my word processor program and filled a page with large bold font characters and printed a page or two. Each page cleared more nozzles. After doing this cleaning/printing a number of time, I put in the full good cartridge. Ran the cleaning a few time to eject any of the Acetone diluted ink. Ran the printed page a few time to remove more of the diluted ink.
Everything seems to work now.
Apr 20, 2008 | Brother MFC-5440CN All-In-One InkJet...
I have a Canon Pixma IP 5000 inkjet printer and am using Mac OS 10.3.9. It has 5 ink cartridges: 2 black (3e and 6) and one each yellow, magenta and cyan. I use it all day every day. After printing...
Thanks for getting back to me.
Sorry this ain't a solution but it seems to be the only cash-free way to contact you. No problem not solved - though I have tried everything. Dismantled the printer; washed, dried and replaced the waste ink pads; washed the print head; blew compressed air through the print-head sponge; replaced the cartridge 3 times; printed hundreds of test prints. I can't think of anything else to do and so I think the only solution is to replace the printhead (probably not even available) or replace the printer. The latter is looking most likely.
Feb 10, 2008 | Computers & Internet
Canon PIXMA MP780 All-In-One InkJet Printer Logo
174 people viewed this question
old marine
old marine
