When I disengage the blades they continue to spin , not at full speed, but enough to hurt someone. please help, its a manual engage/disengage lever
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
SOURCE: The blade engage lever on my 42
Get a can of penatating oil and spray the pivot point of the idler arm on the deck. That's the one that moves back and forth when you lift the blade engagement lever.
SOURCE: Blades will not disengage
SOUNDS LIKE THE CABEL IS BAD IF IT HAS ONE OR THE ENGAGEMENT IS BENT
Testimonial: "This is what I concluded too. I have ordered the part, and we'll see."
SOURCE: after replacing the belt, new pulleys, and bolts,
sounds like the linkage to your blades, check your lever, to make sure its working right may need some grease, it may be sticking and not fully engaging, or doing its job when its supposed to
