Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I have a cub cadet model 3 1042 it starts but
I have a cub cadet model 3 1042 it starts but after it gets warm it stalls
  • 246 Answers
Hello
After the Engine Stalls, Check the Plug for Fire. If No Fire then the Ign Module/Coil is BAd and Requires Replacing.
>>The Following is a Basic Instruction File I made for this. Any Input is Appreciated. I Usually Suggest you Check the Following in this Order for a Problem like yours. 1- Check the Gas Tank Cap and Ensure it is Venting the Tank. A Vacuum Builds in the Tank and the Gas Flow Stops or Slows (15 to 45 Minutes and if the Small Grainular Sand is in the Tank it can Take Several Days of Constant Running to Bring All the Sand Particales to the Tank Outlet Port) to a Point it Shuts Off the Engine. 2- Operate the Equipment Until it Quits (15min to 1hr). Then Immediately Check for Fire from the Plug. If the Plug is Firing, then 3- Check the Carburetor Solenoid. If the Carburetor Shut Off Solenoid has Current, then Remove the Carburetor Solenoid and Go to the Hardware Store. Purchase a Bolt of the Same Diameter and Threads. It Needs to be 3/4" Long. Put this Bolt in Place of the Solenoid. If this Corrects the Engine Problem, then Replace the Solenoid. ***NOTE: THIS IS FOR CHECKING THE SOLENOID ONLY I NEVER SUGGEST YOU OPERATE THE ENGINE WITH THE SOLENOID OUT OF THE CARBURETOR EXCEPT FOR TESTING PURPOSES*** Sometimes the Plunger is Moving, Just Not Far Enough to Allow the Gas to Enter the Jets. 4- Depending on the Model Mower, it can Also be the Pickup Tube in the Gas Tank. If No Fire, then Remove the Shut Off Wire from the Coil and Check for Fire. If Still No Fire, then the Ign Module or Coil is Bad. **Even if the Coil is New of Fairly New, it can Still be Bad.** On JD Mowers; Remove the Igniter/Module and the Coil and have the Local JD Dealer Test them.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
Cub Cadet XT1 Kohler Engine Stall
Most likely your cap is not venting properly, replace the cap.
Sep 03, 2016 | Cub Cadet Garden
My Cub Cadet just got serviced for another 500 bucks and is doing the same thing as last year. Ran it all day then it starts to sputter and stalls. Model GT 1554 HELP!
Make sure the fuel filler cap breather hole is clear if its blocked it will create a vacuum in the tank which prevents the fuel flowing forward.
May 25, 2015 | Cub Cadet Garden
How to replace belt model 2155 cub cadet engine pulley to deck?
Download the owners manual from Cub Cadet using model number 13A-244G100.
Customer Service Cub Cadet
Sep 16, 2014 | Cub Cadet Garden
Cub cadet manuals pdf
something clogging jet in carb water in gas rebuild carb
Sep 06, 2014 | Cub Cadet Garden
When I put my pto on my cub cadet 2155 it stalls
This issue can be caused by several things but the most common is to check your deck spindles to insure you don't have a seized or bad bearing.
Aug 27, 2014 | Cub Cadet Garden
Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Aug 07, 2012 | Cub Cadet Garden
My Cub Cadet lawn tractor model 2155 stalls when I take my foot off the brake. Why?
SOUNDS LIKE ONE OF YOUR SAFTEY SWICHES ARE BAD ID START WITH THE SEAT SWICH THAT MAY BE ALL IT IS
Oct 08, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Oil light blinking cub cadet model gt 2542 it started blinking the frist time . has oil in the ttractor . tfe tractor has less then 100 hrs 2 yrs old.
Screw a test gage in the engine where the electric sending unit is. Check to see what the pressure is cold and after it is warmed up. It may be a bad sender.
Mar 08, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
660 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
