Pioneer TS-W383DVC Car Speaker Logo
Lloyd O'Connell Posted on Dec 02, 2013
I have 2 pioneer ts-w383 15" dvc subwoofers and cant get any sound out of them. a few days ago i got one to play but now neither one will play any sound.
They are connected to an infinity reference series amp thats 1300 watts.
Jeff
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Dec 12, 2014
Jeff
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
9166
Points
50
Try gain set at half, and adjust accordingly.
Anis Hrvic
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 03, 2013
Anis Hrvic
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3323
Points
I need help for my Opel Astra cd code.
DELCO ELECTRONICS CDR500
NO. 09136107
Type CDR500(E)
2F4
GM1500Y9242228
Thanks in advance !
2 Related Answers
Anonymous
  • 11896 Answers
  • Posted on May 04, 2010
SOURCE: what size of box in need Pioneer TS-W307D2 12
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
Anonymous
  • Posted on May 14, 2012
SOURCE: what amp to use for two pioneer ts-w307d4 car subwoofers
Just get 2pi amp pros at1200 watts. That way u have full control of the bass u need. Just remember to turn the amps down the subs are a little under rated. Done this myself and it is a great sous. There not a good pro sub but they will do the job in a mid size car
Manual Pioneer TS-SW1241D
Hi:
I suggest visit this links:
- pioneer-latin.com/en/operating-manuals/mobile-electronics
- manualowl.com/p/Pioneer/TS-SW1241D/Manual/18391
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
What amp to use for two pioneer ts-w307d4 car subwoofers
2answers
10helpful
What size of box in need Pioneer TS-W307D2 12
2helpful
What are specs for a ported subwoofer enclosure for a 12" pioneer champ series
TS-W307D2
Design and Specifications
12” Dual Voice Coil (DVC) Subwoofer for Enclosure applications 1,200 Watts Max. Power Handling 400 Watts Nominal Rating Qts = 0.44 Xmax = 8.7mm Fs = 33.9 Hz Vas = 42.2 litres Frequency Response : 18 ~ 500 Hz. Efficiency : 89 dB Impedance : 2 x 2 Ohm (Total 1 or 4 Ohms) Delivered with “jumper link”: ready for 4 Ohm use f0 (Lowest Resonant Frequency) : 33.9 Hz. Recommended Sealed Enclosure : 24 ~ 49.6 Litres RECOMMENDED sealed enclosure, not Ported. 24 Litres = 1464.569 cu. inches 49.6 Litres = 3026.777 cu. inches
Spl box 12inch pioneer subs pls
this is from pioneer  http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/126763081TRD1217-A.pdf
2 Subs running together
If they have the same impedence (like 4 ohm) then you should be able to run two different model number speakers as if they were the same model number. There might be a slight difference in the way they sound, but I would not expect it to be enough to be noticeable. Good luck.
Sub not playing to full potencial
you haave either connected it incorrectly.make sure the ohm of the speaker matches that of the amp ..connect the positive coil to the positive coil at the back of the sub and the same for negative .then run your cables to the amp .you should only have one positive cable and one negative cable .this connection will create a 2 ohm connection make sure the amp can handle that load .prefarably using a 2 channel bridgable amp or 1 channel monoblock
Pioneer 1200 watts 12inch ts-w1207d4 dvc
if a friend has an amp too, see if it does the same thing to theirs and if it does, you'll probably have to replace the speakers, but if it doesn't do the same thing on theirs you've got a bad amp. but you never know, it could be the speakers and the amp but that isn't very likely
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
