Question about Xerox FaxCentre F116 Plain Paper Laser
Insert toner card? do I have another solution accept new toner?
Insert toner card??? waht should I do?
  • 239 Answers
I believe you are talking about the toner modual.
if you need to change the toner modual, you will need to tell the machine a new one is put in the machine.
Insert the card after you insert the toner modual.
The machine should prompt you that the modual has been installed.
If you have anymore questions about this, please let us know.
Posted on Oct 17, 2009
Printer is reading INSERT THE TONER CARD, after replacing the toner cartridge
You need to replace the chip card that came with the toner.
http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=LFF6020W/GBB&dct=QAC&faqview=1&refdisplay=QAC_80832&refnr=0080832&scy=GB&slg=ENG
May 14, 2012 | Philips LaserMFD 6020 (LFF6020)
My toner is not empty, but still it shows to insert new card
reached 4000 pages, refill cartridge and insert new card.
Jun 22, 2011 | Xerox Phaser 3100MFP/S Laser Printer
On Xerox Phaser 3100mfp., after refilling the toner its asking "insert toner card"
when you refill the cartridge you got to put a card {seem like a credit card} to reset a counter of the printer. the slot of card is in bottom of control panel {panel with buttons}
Jan 11, 2011 | Xerox Phaser 3100MFP/S Laser Printer
How open in laser toner catridge make-xerox model-phaser 3100
Replace the toner: Always use the smart card provided with the new Print Cartridge when replacing the cartridge. The smart card contains the information necessary to reset the level of Toner. Replacing the cartridge without using the smart card may result in the consumable management system being inaccurate.
  1. Insert the smart card provided with the new Print Cartridge into the smart card reader. A "Change Toner?" message will be displayed.
  2. Press the [OK] button. An "Open Front Cover Replace Toner" message will be displayed.
  3. Push on the left and right side of the Front Cover and simultaneously lower the cover.
  4. Grasp the handle on the Print Cartridge, and then raise and remove the cartridge from the machine.
  5. Unpack the new cartridge, and then insert the cartridge into the machine.
  6. Close the Front Cover. A "Have You Changed the Toner?" message will be displayed.
  7. Press the [OK] button. A "Please Wait" message will be displayed while the machine reads the smart card, and then a "New Toner Remove Card" message will be displayed.
  8. Remove the smart card from the reader and dispose of the card as normal office waste.
    NOTE: If the smart card has been used with a previous installation of a Print Cartridge, a "Remove Card Already Used" message will be displayed. The smart card can only be used once. Make sure to use the card that came with the new cartridge.
Aug 30, 2010 | Office Equipment & Supplies
I have a Brother fax and copy machine and have just replaced toner with a brother TN 350 cartridge and still getting message that toner is low
You didn't include the model, but here are instructions for the Fax-2820; it should work for any of the models that use the TN-350 toner:
  1. With the power on, open the front cover.
  2. Press the Options key. The display will read "Change Drum?"
  3. Press Start.
  4. Press 1 0.
  5. The display reads "Accepted" for about 2 seconds, then change to "Cover Open."
  6. Close cover. The "Replace toner" message should be cleared.
Normally, inserting a new cartridge (with the power on) will reset the toner counter, and you won't have to do any of this.
Dec 21, 2009 | Brother IntelliFax-2820 Laser Fax
Insert toner card
I think you mean insert the toner cart, meaning just that, if you just put a new one in is it OEM, and if it is try gently shaking it to unclump the toner in it. -Carl
Jul 07, 2009 | Ricoh FAX2900L Plain Paper Laser
New ds lite will not accept r4 cards
Thats because the new DSi has a new firmware that stops old flash carts from working. Although a flashcart is gonna be released soon that does work in the DSi
Dec 25, 2008 | Nintendo DS Lite Console
Xerox Workcenter 222 toner card
There is a card that should come with a cartridge. It slides into the slot on the side of the machine to reset the toner cartridge count.
I don't know of a way to reset the count without a card.
Wish I had a better answer, but the card is encoded to reset the machines toner count in the software.
May 06, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Trying to insert a 2gb expansion card into my palm
A lot of palm haldhelds only support SD cards up to 1gb. The 2gb and up ones are not supported. So check your manual and figure out waht the maximum size of sd card is in your palm, or try a smaller size SD card.
Feb 03, 2008 | Palm Zire 31 Handheld
Problem in accepting the tonner by machine
This is a common problem. You need to be sure that the toner and drum unit are seated correctly. I assume you. You may also want to try a different toner in case the chip is bad on it.
The following has been known to work also. Open front cover leaving the toner cartridge and drum unit in.
Press the Options button,
When "Replace Drum?" comes up quickly press the Start button.
Immediately press the "1" and "0" button. The display will say "Accepted" and the error will go away.
You need to this these pretty quickly.
Nov 29, 2007 | Brother IntelliFax-2820 Laser Fax
Xerox FaxCentre F116 Plain Paper Laser Logo
1,000 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
