Question about Sony VAIO VGN-NR120E/S Notebook
My webcam doesn't work
My pc camera can not work.the file name is pc camera zs0211.a message appears "you have no video capture".
Webcam doesn't work the way I want it can't take photos
A webcam supplements communication with family and friends. It's often used for video chatting. But you could use your webcam to take pictures, as well.
Make sure your webcam is connected to the USB port of your computer, installed appropriately, and the computer is on and ready. Navigate to the "Start" menu and type "webcam" (without quotes) in the Search field. If you've previously installed webcam software, the program should appear in the search results. Double-click the selection to launch the webcam application. From the webcam dialog, select the "Quick Capture" icon (the example is for Logitech software, but other applications have similar functions with different Position the camera and person or object that you want to photo capture. Select the desired resolution from the drop-down menu. Click "Take Photo" to take a photograph. Browse to the picture destination to view your photo. Now that your photo is stored on your computer, you can email or print it.
Apr 08, 2013 | Acer TravelMate Computers & Internet
How can i use my web cam
Your Dell Latitude E6400 laptop comes with a built-in webcam at the top of the LCD screen. This camera can take still pictures and record video for use with video messaging. You can access the camera via a software program already installed on the computer. This program can be accessed right from the desktop screen.
1.Turn on your Dell Latitude and click on the "Start" tab on the main desktop screen. A list of options will appear in a drop-down window.
2.Click "Dell Webcam" from the list of options in the window.
3.Click on "Dell Webcam Center" and the program will open. A capture window will appear on screen. Beneath the capture window will be a control panel.
4.Click on the camera icon to take a still photo.
5.Click on the "Record" button to record video with the webcam.
I hope you find it helpful. Best regards.
Aug 23, 2011 | Dell Latitude E6400 Laptop Computer PC...
Webcamera doesn't work
1. Check if Imaging Devices is listed in device manager.
2. Uninstall and reinstall the webcam companion software.
Use the Arcsoft Webcam Companion Software to use the camera to capture videos and pics. Click on start and type Webcam Companion in the search bar and press the enter key.
This will open the webcam companion software, then click on the capture option to use the camera. If you want to use the camera with any messaging software such as Skype, Yahoo Messenger etc, it is required to close the Webcam Companion Software or any other web messenger software.
The camera can be used with a single application at one time.
May 28, 2011 | Sony VAIO EE Series Notebook VPCEE31FX/WI
How can I use my Sony DSC-W55 camera like a MPG Player? I want to carry my videos downloaded from youtube in my cam and see them when I visit my friends just connecting my cam to the TV of my...
You may not be able to copy the videos other than the one captured in the Camera, as the Camera file system will not accept the file format of other video recordings. The File error message displays when you try to copy or edit the files in the Memory Stick. This may cause all the other images to be corrupted. I suggest that you do not copy the files to Memory Stick which will damage the images already captured in the Camera.
The Camera will not accept the files even if the file names are different as the Camera creates its own file name for videos recorded in it. You may try copying the videos to the folder in the Camera where the movies are recorded with the same file name of the videos. However, this is not recommended.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
I have a sony vaio vgn-fs790 laptop but cant seem to use the webcam i recently bought.my laptop cannot recognise this webcam and i think i dont have any webcam driver installed,please help out,this is the...
The built-in Motion Eye Camera is designed to add video functionality to many instant Messaging or video editing Software applications (such as Windows Messenger or MovieMaker). However the configuration process and support for how to set-up these individual applications is provided by the Software manufacturer, not Sony. Please contact your Yahoo Messenger support team for assistance on how to configure their Software.
TIP: Simply turning on your Computer activates that camera, so no specific
action is required to start the video services. Please note that only one
application can access the video signal at a time. If the signal is already
in use by one application, it will not be able to be detected by a second
Follow this procedure to take still image pictures with the integrated Sony Motion Eye camera.
1. On the taskbar, click Start and then click My Computer.
2. In the My Computer window, double-click the Sony Visual Communications icon.
3. In the Sony Visual Communications window, under Camera Tasks, click Take new picture.
Follow this procedure to capture video with the integrated Sony Motion Eye camera.
1. On the taskbar, click Start, point to All Programs, and then click Windows Movie Maker.
2. In the Windows Movie Maker window, on the left side under Capture Video, click Capture from video device.
Dec 12, 2010 | Sony VAIO VGN-FS790 Notebook
How can i install my web cam?
Hi,If you don't have CD for installation, Use the below link to download it.
(microsoft.com/hardware/download/download.aspx?category=ICE)
Set Up and Use the VX-3000 personal web camera
  • 1 Install the software using the included CD and plug the LifeCam into a free USB port. For desktop use, place the LifeCam on a clear spot on your desk that's free of other objects, including cables. The camera should not be more than an arm's length away from you. For LCD (or similar object) use, push the center part of the camera's base upward, place the camera on the LCD and close the base around the monitor to secure it.
  • 2 Open the device software by clicking the Microsoft LifeCam icon on your Windows desktop. If no such icon exists on your Windows desktop, click "Start," click "All Programs" and locate the Microsoft LifeCam program in the list of programs there. After launching the LifeCam program, look at the image that appears. If necessary, adjust the camera to more precisely reflect your appearance. For best results, try to center the camera image on your head and shoulders.
  • 3 Click the video camera icon on the bottom panel of the LifeCam program to begin video capture. Video will begin recording, and you will see a "Recording Video" message beneath the live video image. To stop recording, press the same icon (the icon will have a red square with a blue background during recording).
  • 4 To begin audio capture, click the microphone icon on the bottom panel. To stop the audio recording, click the same icon (again, it will have a red square with a blue background during recording). To snap a photo, click the camera icon on the bottom panel.
  • 5 Access any of your captured video, audio or image files by clicking the folder on the bottom panel. The VX-3000 also provides the ability to edit video or image files using supported software. After snapping a photo or capturing video, click the "Edit" icon that appears beneath the thumbnail of the captured content.
  • Hope it helps.
    Oct 30, 2010 | Microsoft LifeCam VX-3000 Web Camera
    I dont know how to install my new lifecam !
  • Oct 09, 2010 | Microsoft LifeCam VX-3000 Web Camera
    I am not getting any image or video from my web cam.
    1st You download Webcam Driver.
    After this install the Webcam driver in the system.
    Installation of Webcam Driver
    Go to the control panel
    Click on the System Icon
    Click on the Hardware Tab
    Click on the Device Manager s
    Select the Unknown Device or printer device where yellow Question Marks sign on it.
    Right click on it and uninstall it.
    After this go to the top of the device manager and click on scan for hardware changes.
    Driver installation Wizard start.
    Brows Your Driver from the Hard Disk and click on next.
    Driver will be install.
    Mar 15, 2009 | Zonet ZVC7100 Webcam
    How to record a webcam video
    I do not the original software from the camera, but you can use VLC, wich is open source and free, and it works great. You can download it here
    After you install it, run it.
    Select File, and then "open capture device".
    In "Video device name", select your webcam. In the same screen but lower, checkmark "stream/save" and click on "settings".
    That will open another window, checkmark "file" and type a file name.
    Click ok on both windows and start recording
    Good luck!!
    Dec 13, 2008 | Acer Aspire 5610-4648 Notebook
    Cant instal usb pc camera ZS0211 or vimicro ZC030x
    PLACE:KOTTAYAM ,KERALA
    sir...
    please help me. i have a prooblem with my vimcro pc usb camera zs0211.
    when it installs it is showing that some files cannot be copied so please help me with this.
    Sep 12, 2008 | Computers & Internet
    Sony VAIO VGN-NR120E/S Notebook Logo
    48 people viewed this question
    Top Sony Computers & Internet Experts
    Alun Cox
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
