Question about Microsoft Windows XP Professional for PC
My computer is denying the password
I have switched off my computer then trying to login with my possword I failed to access my computer. How can unbroke my conputer? Please help:
    Problem Solver:
  • 12 Answers
It states that you are using XP Pro. if you are locked out of your system by entering the incorrect password too many times, you have only a couple of choices short of re-installing XP Pro.
1.Did you make a Password Disk? If so problem solved, just insert the disk and it will open up.
In the event there is NO Password disk, you will need to locate special software to be able to unlock your computer. This software can be quite expensive at times.
OR, you can Re-Install your Windows XP Pro, and LOOSE everything on your hard drive in the process. Hope you Back-Up often to offsite/External source.
Good Luck, Oh check your CAP lock key, the biggest mistake made when entering passwords.
Posted on May 10, 2009
Access denied on computer
I hope you double checked the caps lock, what was the last activity you performed? If it was an installation from unknown / untrusted web source, possibly it's the spyware that infected your OS. Also try to login using Guest account (if enabled). Or check the password hint.
Aug 03, 2014 | Microsoft Windows Vista Ultimate Edition
Computer denying me access with correct password
why was it denying you your login password? did you put in wrong? need more detail as to what happened.
Aug 03, 2014 | Microsoft VISTA Computers & Internet
MY C:\ SHOWS THAT ACCESS DENIED(WINDOW 7) ON MY HOME LAPTOP. HOW TO REMOVE THAT?
This is almost as bad a lost password, because of the limitations.
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html GUI interface. There is a free boot CD called Hirens Hiren's BootCD. This one command prompt only.
Oct 13, 2012 | Microsoft Windows 7 Home Premium 64BIT...
Access denied
yes, you should be able to connect to the console port using a roll-over cable RJ45-DB9, connect using hyper terminal or similar using the com port settings 9600,8,N,1
You can then configure the switch from the CLI...
Have you set the 'Login' command on the VTY lines in the switch setup and an IP address on the management VLAN to connect to.
You also HAVE to have a password enabled on the vty lines in order to connect via telnet.
hope this helps.
May 09, 2012 | Cisco Catalyst 2960-24PC-S Ethernet Switch...
I cant log on. I am always logged on via my phone but tonight when i went to check my yahoo mail it said something about not the correct password. Then I went online and tried to log on and kept being told...
this usually happens if you are still logged in into your mobile phone without logging out, you access the same account using a computer this time.
the way to avoid this next time is to log out first when you're logging into your computer from the mobile phone and vice versa.
or much worse you have clicked another url pretending to be yahoo mail login and provided your password into it, yahoo will automatically deny access protecting your account.
before you login
http://mail.yahoo.com/
click either on I can't access my account or Help below the button "Sign In"
Aug 12, 2011 | Yahoo Mail
Access is Denied error
Hello
There is a small program that can be installed on the TI8x that asks for a password before you can use it. The program is called login.
Hope it helps.
Sep 29, 2009 | Texas Instruments TI-84 Plus Calculator
WGr614V7 Router doesnt let me login. You are supposed to login with Admin as your user name and Password as Password but when i try it it asks me 3 times and then a page says access denied client has not...
Make sure you are using proper case as Password and password are different.
If still same, try to reset the router which will let it accept the username and password you are using. To reset press and hold the reset button (its a very small button) at the back of the router for 20 seconds.
Jul 28, 2009 | Intel Pentium Dual Core E2140 / 1.6 GHz...
Password problem
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin." Once you are past the login screen, you are able to reconfigure the LinkSys router
Aug 10, 2007 | Linksys NSS4000
Lost login Username and Password
How do I use the reset the password on my DES-3226?
Nov 14, 2006 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
Microsoft Windows XP Professional for PC Logo
110 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
