Question about HP Computers & Internet
I have an HP mini s/n: CNU90144NZ p/n: FW376UA#ABA. I was downloading a program (I'm teaching Psych 1A, was downloading the test bank) and everything froze up including my mobile broadband modem. I went tried to restart, and now it says it's saving my settings (for about 15 minutes). The cursor moves, but other than that, it's just plain stuck. Can you help?
  • srpennell May 10, 2009
    Thanks! This was just too easy and I feel dumb. Thanks for for not making fun of me!
  • HP Master
  • 13,433 Answers
Hi
in these cases its okay to force the computer to shut down, it rarely does any harm.
Press and hold the power button down (or pull on some models) untill the laptop shuts down.
Ones shutdown press or pull the power button to turn the computer on normally, the computer should start up and work normally try doing your thing again and see what happens.
Posted on May 10, 2009
2006 Ford Fusion 4 cyl.Engine light is on.Did diagnostic scan and it read P2004 Intake manifold runner bank 1a. There are 2 of these but dont know which one is bank 1a.
On a 2006 Ford Fusion with the 4 cylinder, there will only be one IMRC actuator. The V6 model has two. There is a solenoid and an actuator. You should check both of these for proper operation. The solenoid should click when it receives power and ground, and it controls vacuum to the actuator. The actuator should move when you apply or remove vacuum.
Also, when testing the actuator, it often takes more vacuum than you can produce with your mouth, so that is not an accurate test.
Oct 12, 2017 | Ford Cars & Trucks
User guide for Craig portable power bank model # cma3121a
Craig Electronics Inc
Portable Power Bank with Dual USB Charging Port (3400mAh) CMA3121a Features & Specs Best Replica Watches
  • Quickly Recharge any USB Powered Device such as Tablet, Smartphone and iPad
  • Stylish blue LED power indicator
  • LED light indicates Battery level
  • Built-in TWO Full size USB ports for any device charging via USB port simultaneously
  • Charges Two mobile devices at the same time
  • Scratch resistant UV coating
  • 3400mAh, One Max. 2.1A Output, One 1A Output
  • Available in Colors
ASME B16.5 Accessories Included •Micro USB to Full Size USB Cable
•Mini USB to Full Size USB Cable
Jun 23, 2015 | Craig Televison & Video
HP FW376UA
If you want to know about the size of hard drive just right click on My Computer > Manage > Disk Management .
After that you can see all the drives, all unallocated space and stuff.
Just add them and it will tell you about size!
Nov 22, 2013 | HEWLETT-PACKARD Mini 1030NR (FW376UA) PC...
How do I get a recovery image for HP Mini 1000, Mod 1154NR, P/N NY190UA #ABA, Current image has been corupted and I have no way to install/reinstall this system?
Cut and paste this URL into your browser. It will take you directly to thew HP page for your machine. Select the OS that you have on your Mini abd choose Recovery Media. Follow directions to get CD/DVD sent to you.
Hope this helps!
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=4030691#N436
Jan 11, 2012 | HP Mini 1000 Netbook
I can't get "Mavis Beacon Teaches Typing"
im not sure i understand the problem or why you cant put your name in to mavis's lessons
it might be your pop up blocker or your firewall settings
however this free mavis and there are other freeware keyboard tutorials you might try
http://free-mavis-beacon-downloads.qarchive.org/
http://download.cnet.com/%7Bvalue=http://www.download.com/typingmaster-typing-test/3000-2051_4-10046660.html
If you're looking to boost your typing speed and accuracy, TypingMaster Typing Test can provide the repetitive practice you need. Just don't expect this freeware program to give you any coaching. In a typical session, you might start with the rudimentary (and rather dull) warm-up games and move on from there to the full-blown typing tests. TypingMaster offers only one kind of testing method--retyping a set text--though you can break up the monotony by supplying your own TXT files. The program can store results for several users and track their progress over several tests. At the end of each test, the program gives a brief performance evaluation, though we wish it also gave custom-tailored advice based on our typing patterns. Unfortunately, that feature is restricted to the for-pay version. In sum, TypingMaster Typing Test offers nothing to distinguish it from countless similar titles, and earns only a lukewarm recommendation from us.
http://download.cnet.com/%7Bvalue=http://www.download.com/rapid-typing-tutor/3000-2051_4-10666000.html
Rapid Typing Tutor may be a good program to help novice typists improve, but experienced typists looking to increase their speed may be frustrated by the program's interface
hope this will help you
Sep 30, 2011 | Encore Mavis Beacon Teaches Typing 17...
I want to change the desktop picture on my hp mini 210-sa how do I do that
To change the background on your hp mini you will need to download stardock mycolors. It is a free and safe program I found on google. Once downloaded start up the program and go to wallpaper. All of your picture's in your "My Pictures" will be there. Now just pick a picture and hit apply, you now have a new background.
Feb 22, 2011 | HP Mini 1000 Netbook
How do I get a manual of instructions for a hp mini computer 1000 Model 1154NR. Product # NY190UA #ABA, Case #8039228879 Have been trying for months. If hp cannot get it, is there any place I can find...
You can download and print the instruction manual in PDF format from HP Mini 1154NR support website by clicking this link.
On the page which opens, click on the "MINI User Guide - Windows XP" link to download and save the manual.
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Kindly let me know if you have any difficulty in downloading the manual.
Hope this solves the problem. Thanks for using FixYa.
Sep 25, 2010 | Computers & Internet
HP mini. virus detected
Download Kaspersky to kill virus. I search the web every day and download lots of viruses. The only thing that i download that realy kills viruses is Kaspersky internet security Program.
Dec 29, 2009 | HP MINI 2133 NOTEBOOK PC - 1.2GHZ PC...
I want to install an English operating system in my pda. The current system is Chinese. How do I do that
Hello, you can flash your phone with ROM provided by HP if you are with Windows Mobile 6.
"The Package contains ROM Update utility (RUU) only for products supporting the following SKU IDs. Supported SKU IDs: FA979AA#ABA, FA980AA#ABA, FA982AA#ABB, FA982AT#ABB, FA981AA#ABG, FA981AA#ARE, FA981AA#ACJ, and FA981AA#UUF."
You can find your Product ID by going here:
Start>Settings>AssetViewer>System>Product ID
If your Product ID match with these download ROM Update from Manfufactures web site and update your Pocket PC.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=au&prodNameId=3544253&prodTypeId=215348&prodSeriesId=3544250&swLang=13&taskId=135&swEnvOID=4014
Just select your language: Chinese (Simplified); Chinese (Traditional); English (International); French; German; Italian ;Japanese; Korean; Portuguese (Brazilian); Russian; Spanish, from download section for your pocket pc.
It`s around a 38MB. Install it on your desktop machine and follow instructions provided by ROM Update program.
This is not new operating system installation, it`s just language update to your current installation.
How to use information, you can find on this section in manufactures web site.
I do not test it on this phone, use it with caution and on your own risk.
Dec 21, 2009 | HP iPAQ 112 Classic Pocket PC
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
