SOURCE: I need to replace the window regulator
Go to this website
http://www.fordf150.net/articles/idx.php/0/019/article/How-To-Repair-the-Power-Window-Regulator--Motor.html
SOURCE: Door won't unlatch or come open
Ford had a problem with the door handles not working properly. They are cheap plastic. If the exterior door handle is broken, you will need to drill out the rivets that hold it in, and then get the door open and the panel off. You have to disconnect the rod going to it. Then, remove the handle. If you don't want to drill again, I suggest replacing the rivets with a bolt and nut easily obtainable at your hardware store. I've found that a M7 bolt works very well. If you are having a problem with the interior door handle, it's the same problem. Remember to check your door latch because if your exterior handle is broken, then your latch isn't working properly. I got one at Ford for about 40 bucks.
SOURCE: how do you remove driver door panel
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls. Pull back the weather seal and you can access the window parts. You may need to take something to temporarily jam the window in the up position
