Question about Kodak EasyShare DX7590 Digital Camera
Flash doesn't open - Kodak EasyShare DX7590 Digital Camera
I need a password for my Maxell flash drive
If you've got a generic flash drive, you'll need to download a tool to make this happen. Something like TrueCrypt would be ideal, as it can be installed to autorun on the flash drive upon placing it into a computer, and doesn't require admin privileges. Plus, it's free and open source.
Nov 12, 2012 | Maxell 4 GB USB 360 USB 304 - 503201 Hard...
The middle part is broken what do I do
Try to pry it open all the way, and then put some superglue right at the base where it meets the case so it doesn't slide closed. Let it dry. It will permanently be open, but at least you can still use it.
May 17, 2012 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
The flash on my camera doesn't work
There are three reasons, open filament in the flash bulb, defective high voltage capacitor, and the step up transformer.
Mar 22, 2012 | Olympus FE-230 Digital Camera
Cannot find flash player download site for HTC wildfire desire phone
Normally the phone comes with flash pre-installed. If it doesn't however it is very simple to find Simply:
  1. Unlock your phone and open the main menu.
  2. Scroll down to the app with the title: "Android Market" Tap it and wait for it to open.
  3. In the top right-hand corner, the is a small magnifying glass. Tap it to bring up the search function.
  4. Enter the following: "Flash Player"
  5. Follow the onscreen instructions to download and install the Flash Player.
  6. Try using it by opening a webpage with flash enabled. :)
If you have not used Android Market before it will ask you for you Google account login information. Simply enter your standard Google account details. If you do not have an account you can make one for free here: https://www.google.com/accounts/NewAccount
Hope this helps!
Aug 10, 2011 | HTC Wildfire S Smartphone
I can't open my FLASH DRIVE it says that "please insert a disk into Floppy Disk Drive (E:), How can I open this? please help me.. I have only 1 flash drive and I don't have an extra money to...
First thing to do is to safely remove your flash drive..
then insert it again...
If it doesn't work then your final choice is to make loss of your data..
here's how.
on the icon shown from your flash drive right click
then format..
You can select quick format in there..
and there you go again,, you can use your flash drive now....
Jun 27, 2011 | Computers & Internet
The flash of my sx30 doesn't work, when i open the flash it was detected that the flash is open but the the problem is when i'm going to shoot even i press my shutter it doesn't take any...
hion flash defuser unit up position, it doesn't allow to take picture. This means technically flash circuit is continuously sending charging signal causes blocking shutter release.( but not all of model, it is depend on model of camera.). Like this case, it is obvious that either a fuse brown or charge controlling pcb defective. I recommend you send to your local repair shop or canonUSA. They would charge around $45 to165 depend on what they really want to charge.
Jun 05, 2011 | Canon PowerShot SX30 IS Digital Camera
The blitz doesn t open at all
at what mode ?
are the batteries fresh
try P mode and press the flash realse button on the camera
if this doesn't work it probably is defective ..
Apr 30, 2010 | Fuji FinePix S5700 Digital Camera
Trouble in my camera: no flash while taking photographs even though it is set in flash position. As on opening there comes a blinking like'E:919'& flash symbol. It arose 2days back when I just opened...
Flash capacitor doesn´t charge in a specific time. There may be more reasons. Camera remembers error state and do not use the flash even you turn it off and on. You can try to let it "forget" by resetting (initializing), but if problem persist, do not do it often, it may cause secondary problem.
Sep 01, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Flash is not working
The flash icon appears in the upper left corner of display or it appears as circled flash icon? If flash is open and appears a circled icon, then there’s a malfunction contact that don’t communicate to the camera that the flash is open. Your camera needs service! Be sure the upper part of the flash is unfolded, pointing directly in front of the camera (not downward), because the sensor is just in this second folder. If the icon is not circled, press the right arrow until only the lightning symbol appears (forced flash). Try a shot! If the flash doesn’t pops, then your camera needs servicing (burned or broken lamp or other malfunctions).
Oct 05, 2007 | Panasonic Lumix DMC-FZ1 Digital Camera
Kodak EasyShare DX7590 Digital Camera Logo
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
