Question about Roundup "" Weed & Grass Killer
DIRECTIONS FOR USE FOR ROUNDUP GC - Roundup "" Weed & Grass Killer
  • nathan May 11, 2010
    mixing or application what is it you want to know?
How do you refill roundup pump and go
The Pump N Go can be refilled with either the Roundup Super Concentrate or Roundup Ready To Use Plus Refill Bottle.
To refill the Pump N Go with the Roundup Super Concentrate (purple cap), add 6.5 fl oz of the Super Concentrate to container and slowly fill with water.
To refill with the Ready To Use Plus Refill bottle, just slowly fill the Pump N Go with the refill container.
We do not recommend using Roundup Concentrate Plus (red cap) to refill the Pump N Go because it has different active ingredients and different information regarding use around edibles.
To open to Pump N Go container, please follow the directions below:
Stabilize container by holding between your feet
While holding the pump handle push down slightly and turn left (the pump will be out of the locked position)
The first time it is opened it will be difficult to open because for shipping safety the top is but on very tightly at the factory.
If you have any further questions, please contact us at 877-465-5160.
Hilary @Roundup
Aug 29, 2011 | Roundup "" Weed & Grass Killer
Directions "stuck" together and can't open. I
I use 3oz. per gallon for around the house and garden.
Apr 24, 2011 | Roundup "" Weed & Grass Killer
How do you refill roundup pump and go container with sprayer, cant work it out. IT WOULD BE A GOOD IDEA IF MANUFACTURES GAVE INSTRUCTIONS HEY.
Any Roundup Weed & Grass Killer RTU can be refilled with the new 1.25 gallon Roundup Weed & Grass RTU Refill bottle OR use Roundup Super Concentrate (purple cap).
Directions to Refill with Roundup Super Concentrate
  • 24oz RTU: 1 oz of RoundUp Super Concentrate, fill with water very slowly to avoid foaming.
  • 1/2 Gallon RTU: 2 1/2 fl. oz. of Roundup Super Concentrate and slowly add 1/2 gallon of water
  • 1 or 1.1 Gallon RTU: 5 oz RoundUp Super Concentrate, fill slowly with 1 gallon of water
  • 1.33 Gallon (PNS & PNG): Add 6.5 fl oz of the Super Concentrate to container and slowly fill with water
How long do I need to wait to reseed / sod lawn after applying roundup?
If you use Roundup or equivalent (do not use the long-acting product with a pre-emergent). Then you can reseed three days after the treatment. Do check the label for your specific product for any directions that differ for the reseeding schedule.
Some specific treatment limits: First some lawns will require two treatments with Roundup before reseeding (or planting sod). So wait 7 days after the first application to identify any green (growing) spots and then retreat. After all existing lawn grasses and weeds have been treated, you can rake the area and then put down sod or grass seed 3 days after application.
Second: for best results the plants treated with Roundup need to get rain or irrigation a few days before the application and 2-3 days after the application. (This is true if the soil is dry when you are getting ready to plant.)
I hope this helps.
(the labels for several Roundup products are here: http://www.scotts.com/smg/catalog/productCategorySubSelf.jsp?itemId=cat50096&navAction=jump . Click on product information and then the label.)
Oct 25, 2010 | Roundup "" Weed & Grass Killer
Whats the mix ratio for a weed wand useing roundup concerntrate? thank you
It will depend on which roundup product (there are many, many different ones) your using, what type of sprayer, and what type of weeds your treating. If your directions are missing, or your not sure how to interpret something, I recommend going to any home depot, lowes, ace hardware, etc, and ask them for help. You can also visit Monsanto's web site. here is a link with many of the Labels that include directions, and mixture ratios. http://www.monsanto.com/products/Pages/msds-labels.aspx Good Luck!
Oct 05, 2010 | Roundup "" Weed & Grass Killer
How many gallons per acre
Boy, I hate to state the obvious, but did you read the directions? It will depend on which roundup product (there are many, many different ones) your using, what type of sprayer, and what type of weeds your treating. If your directions are missing, or your not sure how to interpret something, I recommend going to any home depot, lowes, ace hardware, etc, and ask them for help. Good Luck!
Sep 29, 2010 | Roundup "" Weed & Grass Killer
How much do I water after the roundup is applied
Roundup (glyphosphate) doesn't get watered in. However if the area was stressed due to heat or dry conditions, water before using the Roundup to ensure that the plants are growing and transporting nutrients to the roots. The usual recommendation is 1" per week. Roundup kills all plants that it is in contact with. Then let the product dry before it rains (1-4 hours depending on the formulation read the label for rain-fastness information).
Water the plants that were not sprayed as you normally would as long as the treated areas will not be wetted before the Roundup is dry.
Even the extended control version does not need to be watered in.
If you are using a different product that needs to watered in, please read the label for directions. (For example some pre-emergents need to be followed 1" of rain to water them. Alternatively you can do a shallow tillage of the treated ground (2" deep iirc).)
I hope this helps.
(any directions given in the product label should be followed)
Sep 13, 2010 | Garden
Agriculture Application of Round-up
Very important to buffer the pH of the water at pH 5. Then add Roundup /Glyphosate 360 at a 2% for grass weeds and 3% for brush weeds. Ensure that the grass is dry when treating and no rain is expected within 6 hours. Please take care with roundup as it is poison .
Apr 22, 2010 | Roundup "" Weed & Grass Killer
Roundup "" Weed & Grass Killer Logo
1,412 people viewed this question
Top Roundup Garden Experts
Nick Olsen
Mike
Are you a Roundup Garden Expert? Answer questions, earn points and help others
