Question about Air Tools & Compressors
Over Pressure My DeWalt D55141 Air Compressor does not shut off when maximum pressure is reached, but continues to run until the relief valve lifts. Any suggestions?
  • Anonymous Mar 13, 2014
    Motor continues to run when pressure reaches maximum psi
  • 50 Answers
I suggest trying to adjust the pressure switch, however, it is more likely that the pressure switch is bad and will need replaced. These can be purchased at most hardware stores or www.mcmaster.com. After you install it, you will need to readjust it to the pressure it was originally set to so as to not overpressurize the tank. Overpressure is very dangerous so do not use the compressor until it is repaired.
Best wishes!
Posted on May 11, 2009
I have a Dewalt model D55166. It will not shut off when it reaches the maximum allowed air pressure. What could cause this?
If safety pressure release valve pops open then electric pressure switch is bad, however if compressure keeps running and never pops safety valve then most likely tubing / joint leaks or cylinder / ring worn out. Spray soapy water on all joints and drain valve , if no leaks suspect cylinder. Good luck
Feb 23, 2015 | Dewalt Air Tools & Compressors
Compressor relief valve opens 150lbs on my d55141
That is the compressor's holding capacity 150psi. Therefore, the cut-out pressure has been reached. The safety valve opens to relieve the excessive psi. Compressor should come on at 120 psi.
May 15, 2012 | Dewalt d55151 factory reconditioned emglo...
D55141 Electric 2 gallon Dewalt Emglo compressor won't shut off. It builds pressure past the max rating 150 psi and blows the intended safety feature, pressure relief valve as it should, but then...
Hi
your pressure switch is bad. so it isnt cutting off the compressor. the part number is N003306SV and can be obtained from Dewalt on Servicenet.
Detail
Good luck and hope this helps
Oct 26, 2011 | Dewalt D55141 Heavy Duty 2 Gal, 150 Psi...
Relief value releases and will not reset
Likely the check valve is bad or has contamination on the seat. The result is the pressure will bleed back out the compression relief valve which is often as part of the pressure switch.
If the safety valve is the one that is bleeding, then the pressure is set too high at the pressure switch.
Apr 07, 2010 | Dewalt d55151 factory reconditioned emglo...
My dewalt emglo air compressor has been pumping up and cutting off but can here air escaping in the inside and when it reaches cut-in the motor just hums loud and cuts off until I bleed all air and then it...
Sounds like the pressure relief valve......It works as a relief so when the motor comes on it is not under a load/pressure. Much eiser to start not under a strain.........
Dec 19, 2009 | Dewalt Air Tools & Compressors
Hi I have a Dewalt d55141 emglo contiues to run
Open the shut off switch box and adjust the cut out pressure.
Nov 17, 2009 | Dewalt & 2HP Hand Carry Heavy Duty...
COMPRESSOR RUNS, FILLS TANK, AND THEN LEAKS OFF ALL THE PRESSURE. WHAT IS GOING ON?
Is the air "leaking" from the pressure relief valve? If so it is either faulty or it is doing what is supposed to do. The pressure relief valve is there in case the pressure switch fails.The tank could blow up if the pressure switch fails, so the pressure relief valve is there as a secondary measure to insure the tank does not receive too much air pressure. Assuming your gauge is operating properly, watch the gauge to see if it reaches the maximum pressure (check your manual to find the maximum PSI) or if it goes over the maximum pressure. If it goes over the maximum pressure then replace the pressure switch. If it the motor stops at the maximum pressure, replace the pressure relief valve.
Jun 07, 2009 | Dewalt D55250 Factory Recondition Heavy -...
Dewalt d55141 Builds only 45psi
Check the unloading valve. Accumulation of dirt might be preventing the valve to fully close, by-passing a portion of the compressed air.
Jun 07, 2009 | Dewalt & 2HP Hand Carry Heavy Duty...
Air Tools & Compressors Logo
292 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
