Question about Indesit 24 in. IDL500 Built-In Dishwasher
TOtal Gross weight of the machine
What is the weight of indesit dishwasher IDL 55 model
  • 10,865 Answers
Approx. 115 pounds
Posted on May 10, 2009
Does anyone have the specs for this model, HxWxD
Watts (W) 1300 W
Current (A) 12 A
Volts (V) 120 V
Frequency (Hz) 60 Hz
Tub type TallTub
Plug type 120V-3 prong
Dimensions & Weight
Overall appliance dimensions (HxWxD) (in) 34 1/8 '' x 23 9/16 '' x 22 7/16 ''
Required cutout size (HxWxD) (in) 34 1/8 '' x 24 '' x 24 ''
Product packaging dimensions (HxWxD) (in) 36 13/16'' x 26'' x 28''
Length inlet hose (in) 55''
Gross weight (lbs) 123 lbs
Net weight (lbs) 118 lbs
Of course you don't mention which model you have ??
Mar 18, 2016 | Bosch SHX68P05UC Dishwasher
Indesit IDL 40 slimline dishwasher does not drain completely
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems -
Water will not drain out
heatman101
Jan 05, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
My Indesit idl 530 dishwash which is fairly new has packed up with the Prewash and Drying light flashing simultaneously. I know it's under warranty but I'm trying to find out what this error code means and...
Refer the user guide for the error meaning. Switch off the machine and try.
Still the same problem contact the service engineer as this will ease your work!
May 17, 2010 | Dishwashers
Ndesit IDL 535 DW, not cycling, water coming from under unt.
The washer is fitted with an anti flood device that detects water leaks and closes water inlet valve and puts washer in pump out mode. The anti flood device is a polystireen float with micro switch at the bottom floor of the washer. Dry the water and find the leak (pipe or pipe clamp) and this should then solve the error.
Jan 22, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit idl 40 2&3 lights flash
The problem is lack of water. Check that the water is turned on at the stop **** and make sure that the hose hasn't been traped if the dishwasher has been pulled out from it resess as happened to mine.
Jan 21, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Jun 04, 2008 | Indesit 24 in. DE73 Evolution...
IDL 700
A10 2 & 4 Heating element Open circuit heater
info from idl service manuall
Feb 29, 2008 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit idl 705
you may be in "flood mode". there may be a leak into the base. or your bottom base hoses may be blocked, best get someone in who is able to strip a d/w base out.
Feb 08, 2008 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit IDL 530 Dishwasher Prewash and Drying Light flashing
Ours was doing this and it was because there was water leaking into the base because a crocodile clip had come off
Oct 22, 2007 | Dishwashers
Idl 705
i have similar problem machine starts then stops while bleeping the second and third lights then flash nothing more happens have checked water intake which is ok no blockages any more ideas would help thanks
Oct 07, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit 24 in. IDL500 Built-In Dishwasher Logo
121 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Level 1 Expert
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
