Question about Estate EED4300TQ Electric Dryer
Will not heat and belt is off
Dryer belt came off, and will not heat
You can purchase a new belt from Sears on-line, or the brand you own. typically 20 dollars range. they come with directions to install the new belt, typically you remove the front panel of the dryer and replace the belt. it is not hard to do and really is best with 2 people. good luck!
Posted on May 10, 2009
Dryer heating but does not thumble clothes
CHECK FOR BROKEN OR WORN BELT
Sep 14, 2014 | Dryers
If my Samsung dryer belt was loose but still turning, will it stop the heat element? Because I had a problem earlier in the week with it heating. I took the back off and noticed the belt was freyed
Yes if the air flow is reduced because of a slipping belt that could cause the heating element to turn off due the temperature sensor being a high input. Remember the motor runs a fan as well as the dryer drum.
Jan 20, 2012 | Samsung DV218AEW Electric Dryer
My dryer turns on and reads sensing , but does not turn ....does heat
If your dryer heats yet does not tumble i would be looking for a broken belt..when its heating that means the motor is running,but since i suspect the belt of being broken its not tumbling
Sep 13, 2011 | Whirlpool WED8300S Dryer
I have a whirlpool dryer that will spin but will not heat or shut off automatically?
some dryer 's have belt sw on them if belt breaks dryer stopes ( no spin ) if dryer stops no heat . replace the belt and it should work .. other problems / ck the power if 220 you may have lost 1 leg . dryer will go but heat and will not shut of auto . mm
Dec 09, 2009 | Dishwashers
Dryer will heat up but drum will not turn. Unable
Good day,
Sounds like a broken belt, Excellent tutorial on changing the belt on the link below.
Caution: Some models used a very poorly designed belt tensioner. If the tensioner is that style, replace it while purchasing the belt.
Appliance parts house counter men are well aware of the problem. The Roper line is made by whirlpool.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Dec 04, 2009 | Roper REX4634KQ Electric Dryer
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
Dryer power problems
Yes, all dryers have a belt that turns the drum. Chances are the belt and heat problems are 2 separate issues.. The belt turns the drum from a motor mounted inside the unit, your electric dryer has a heater element/coils that heats the drum your clothes are in. The belt could be bad and heat element also but both at exactly the same time is rare. Try unplugging the unit for about 5minutes and see if it resets. My washer does that sometimes and I have to unplug
Aug 07, 2009 | Whirlpool WED6400S Electric Dryer
Dryer heat but what turn
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Mar 28, 2009 | AEG T57800 Electric Dryer
Dryer heats up, drum won't turn. any suggestions?
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
Thank you for useing Fixya
Feb 12, 2009 | Bosch Axxis WTA 4107 Electric Dryer
Estate EED4300TQ Electric Dryer Logo
93 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
