Question about Garden
Problems accelerating / losing power
My John Deere 260 lawn tractor has trouble accelerating and loses significant power in higher gears. In 4th, 5th or 6th gear it can't climb the slightest incline. It also accelerates very slowly in those gears even on level ground. Is this a clutch or a belt issue? Any suggestions to fix? Thanks!
Mine did the exact same thing. It was the drive belt. Take the deck off, loosen the belt shield on the clutch pulleys (under the frame below the seat) and take the old belt off. You will have to disconnect the wiring to the electric clutch, route the belt over the motor pulley and through the clutch pulleys... and over the transmission pulley. It took me about an hour... not bad to do. It will be easier to jack up the front of the tractor so you can get under it easier.
Posted on Jun 03, 2009
Why does my John Deere La145 lawn tractor lose power when climbing a small incline
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 20, 2016 | John Deere Garden
How do you get the gear at the end of the steering shaft off to replace it on a John Deere la175 lawn tractor?
It's a lock nut. But you should have no trouble removing it. Just hold the steering wheel, or turn it all the way to one side. But a socket on the nut below the gear and ratchet it off. That's all there is too it.
Mar 29, 2015 | John Deere Garden
Wiring diagram john deere 260 lawn garden tractor
John Deere will be the best place unless you luck out and a John Deere mechanic or someone with a service manual reads this and responds.
Oct 04, 2014 | Garden
This is a john deere tractor not lawn mower maybe have the wrong number it has frontend loader
Does it have good fresh dry fuel in it? Have you dumped the water bowl recently? Check that.
Aug 06, 2014 | John Deere 420,1020,2010,2020,2510,2520...
No acceleration
check your compresion make sure it is within specs. if okey check your timing make sure timing mark have not change. this is after you ensure that your not loosing fuel or your carb is working normally.
Nov 06, 2013 | 2005 Hyosung GT 250
I have a 310SG john Deere backhoe and it loses power in 3rd and 4th gear on a hill I need help please.
I'm having the same problem with my jd 310. Did you ever end up finding a solution?
Dec 19, 2012 | Cars & Trucks
Sabre lawn tractor 1438 gear manual
John Deere Sabre 1438, 1542, 1642, 1646 Lawn Tractor Service Technical Manual TM-GX10238 * - Download Documents / eBooks
hello arthur, john deere does not post manuals on line,this is all i could find or see your local dealer,hope this helps..
Feb 18, 2012 | John Deere Garden
While riding, the 4th and 5th gears do not engage promptly when you clutch and shift the gear. It sort of goes into neutral as one disengages the clutch and accelerate and then falls in place (ie 4th or...
This behavior is the symptom that your clutch plates are getting worn out. Since power is transmitted from the cam shaft to the front sprocket (smaller dia) is better at lower gears but once the rpm increases the clutch plates do not catch up with the cams rotation, hence slipping at higher gears & in between 4th & 5th gears the pulling power of the engine seems to go to neutral before engaging again. Check your clutch plates as well as the sprocket-chain- rear sprocket for wearing out of the gear teeth & replace if required. You will get back full power & acceleration as when the bike was new.............sodeep
Aug 19, 2009 | 1999 Yamaha XJR 400
Garden Logo
369 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
