Question about Epson LQ-1050 Matrix Printer
EPSON LQ 1050+ printer; OS Windows XP, How to Print long pages of 24" length
How to print long pages of 24" in LQ 1050+ Epson DMP printer. Operating system Windows XP,
Re: EPSON LQ 1050+ printer; OS Windows XP, How to Print...
My LQ1050 is cutting off text at the bottom what could be the problem please help?
Posted on Apr 01, 2008
0 characters
3 Points
I want printer driver for Epson lq-300+ for windows xp sevice Pack 3
windows xp already has driver for that
go to start, setting-printer and faxes- click add a printer
add wizard printer box will apear
click next
set yo local printer uncheck automativaly detect
click next the use following port lpt1
next again
then search epson and the printer model
then click next and next set print test page then next and finnish..
the driver will install..
Aug 22, 2011 | Epson Dot Matrix LQ-300+ Printer
My printer is EPSON LQ-1150 II. It is not working with windos xp os. when installing it ask xp. cd. but the system regets it and ask again and again epson.dll. how can i get it.
Hey dude,
Ty to install the epson compatible 24 pin driver fom the add printer Wizard .It woks well with the EPSON LQ-1150 II.if it again asks for the windows xp cd run "regsvr32 dllfilename.dll" where dll file name is where you gets from the windows xp test page.Hope it'll work
Mar 07, 2011 | Printers & Copiers
Epson LQ-2180 continuous printing problem
The default paper height is 12". If you want to change it to 11" you should refer to printer manual and follow the steps. Otherwise if you are using a software for printing. Ask your developer to give following command for setting paper height
Chr(27) + Chr(67) + Chr(0) + Chr(11)
Mar 09, 2010 | Epson LQ-2180 Dot Matrix Printer
I don't have the correct driver for Vista, using printer to print technical drawings
When the drivers are not available, you can install VMware virtual machine and be able to use windows xp and xp drivers to run your print jobs. The basic VMware is a free download and works well on my Vista machine.
Nov 25, 2009 | Epson LQ-1050 Matrix Printer
Want to print draft mode in dot matrix printer in XP
Not all dot matrix printers will print in draft mode. When operating from DOS it was usually necessary to send an Esc(ape) code such as ESC @ in ASCII code. I don't think it can be done from Windows; in fact some windows programs will not even talk to a dot matrix printer. Some printers have one or two banks of DIP switches, but before changing them you need to read the manual to see what they do. There could be one which allows Draft MOde.
Sep 24, 2009 | Epson LQ-1050 Matrix Printer
Page setup
see the paper length you are using
ex. 8.5 X 12 "
set the paper length programatically by using following command
?? chr(27)+chr(67)+chr(0)+chr(12)
Jan 09, 2009 | Epson LQ-2180 Matrix Printer
Cross printing
I'm not sure exactly what your issue is, but Epson printers should be well supported as far as drivers are concerned. Do you have the correct driver loaded? If you are trying to use a Tally driver with the Epson printer, this may not work right.
Also, when printing from Windows, some older printers print only in a single direction, from left to right, instead of bi-directional (left to right & right to left).
I've used a few different Epson dot matrix printers, and problems have been few.
Feb 26, 2008 | Epson LQ-1050 Matrix Printer
An Emulation driver will fix everyones problem... Do this:
1. Click on "Start", then "Control Panel" and then "Printers and Faxes".
2. In the left hand column choose the option "Add Printer". The "Add Printer Wizard" comes up, click on "Next".
3. At the "Local or Network Printer" screen choose "Local" and remove the check from "Automatically Detect".
4. Click on "Next".
5. At the "Select Port" screen choose the appropriate port (usually LPT1: recommended printer port).
6. At the install printer software screen choose "Epson" under "Manufacturer" and LQ-1050 for the printer, then click "Next". If you wanted to install the Windows universal driver, choose "generic" under "Manufacturer" and choose "Text Only", then click "Next".
7. At the printer name screen choose "Next".
8. When asked if you would like the printer to be default make the appropriate selections and then click "Next".
9. Finally click on "Finish". You may need your Windows XP installation disk.
Feb 05, 2008 | Epson LQ-2180 Dot Matrix Printer
Custom size paper on xp
When you are in the page go to file, then print setup then go to advanced and it will let you do manuel adjustments or custom paper sizes. Depending on your printer you can also go to page setup and it will also give you page options..Be mucho blessed...Mark
Nov 20, 2007 | Epson LQ-2180 Matrix Printer
Printers & Copiers Logo
366 people viewed this question
Top Epson Printers & Copiers Experts
Are you an Epson Printer and Copier Expert? Answer questions, earn points and help others
