Question about Cell Phones
Can't connect jabra to cell phone
My Jabra doesn't show on my at&t cell phone. I turn on the jabra hold the button till the light is solid and search for new devices. But no devices show
  • 5 Answers
SOURCE: How do I pair my Jabra Bluetooth -48D
well what you have to do is to go to the bluetooth menu turn  it on and select add new device now on you jabra headset it has an answer button wich you can press untill the blue light stays on that when the env can find and paire the device
Posted on Nov 01, 2007
Crashster
  • 181 Answers
SOURCE: Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life.
2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Posted on Dec 18, 2007
MonsterG
  • 52 Answers
SOURCE: pairing Jabra BT135 with motorola L2
okay, try this, turn off the jabra headset, and then, hold the power button but hold it down until the lights flash in a different way, and make ur phone search for devices and if it finds it then its all good, just use the 0000 password to pair it.if this works give me a fix rate. thank U
Posted on Feb 11, 2008
SOURCE: jabra vbt185z, light stays on, won't connect to phone
My head set had another pin code other than 0000 when I recieved the unit which made it dificult to connect. I learned how to reset it to the default pin of 0000 which allowed me to sync it with my phone. After using it for a month or so my phone requested the pin again.I entered 0000 and once again would not accept the pin. I had to retore the default pin again and it works just fine. Here are the instructions. Plug your vbt185z into the wall charger and while connected press down and hold the center blue button untill the light comes on.(about 30 seconds)Unplug the the ear piece and turn the unit on.Now enter pin 0000 and your phone should accept the pin.
Posted on Mar 01, 2009
rocky2005
  • 70 Answers
SOURCE: i hav a jabra bluetooth....type
1. Put the headset in pairing mode and make sure that the headset is on. To do this: Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra headset
(Follow your phone’s instruction guide to do this)
3. Once your phone locates the headset, it will ask you for a code to pair with it, the code for jabra headsets is usually 0000
Posted on Sep 02, 2010
I want to connect my Jabra 0te3 blutooth headset to my laptop fujitsu P3010 in win 7 but my bluetooth is not finding jabra. how can i pair it.
1) Ensure that your Jabra headset is turned completely off. Press the tap button on the headset until it ceases flashing and the light goes off.
2) Hold down the tap button to power your Jabra headset back on. Keep holding the power button until the lit power indicator cycles past flashing mode and becomes solid.
3) Release the power button.
4) Navigate through your cell phone "Settings" menu and ensure your "Bluetooth" or "Hands-free" section is set to the "On" or "Active" mode.
5) Choose "Search for new devices" or "Find new devices" on your phone's Bluetooth or hands-free menu.
6) Place the Jabra headset close to your phone to ensure it can be discovered by your cell phone.
7) Select a "Connect" or "Pair" option once the Jabra headset name displays on your cell phone.
8) Enter the default passcode by entering "0000" on your cell phone keypad.
9) Ensure that the Jabra headset has been paired. Look for the Bluetooth icon in the upper portion of your cell phone screen. Make a call to verify that audio is being routed through the Jabra headset.
Dec 22, 2010 | Computers & Internet
Cant find a manual jabra bt4051 bluetooth
abra burst onto the audio microtechnology scene in the early 1980s, gaining initial attention for its Macintosh EarPHONE telephony products. Jabra's cell phonemag-glass_10x10.gif Bluetooth headsets have also garnered wide acclaim for their sleek aesthetics and compact form. Jabra Bluetooth headsets can be connected or "paired" with virtually any cell phone by using a few simple steps.
  1. Ensure that your Jabra headset is turned completely off. Press the tap button on the headset until it ceases flashing and the light goes off.
  2. Step 2 Hold down the tap button to power your Jabra headset back on. Keep holding the power button until the lit power indicator cycles past flashing mode and becomes solid.
  3. Step 3 Release the power button.
  4. Step 4 Navigate through your cell phone "Settings" menu and ensure your "Bluetoothmag-glass_10x10.gif" or "Hands-free" section is set to the "On" or "Active" mode.
  5. Step 5 Elect to "Search for new devices" or "Find new devices" on your phone's Bluetooth or hands-free menu.
  6. Step 6 Place the Jabra headset close to your phone to ensure it can be discovered by your cell phone.
  7. Step 7 Select a "Connect" or "Pair" option once the Jabra headset name is discovered and displays on your cell phone.
  8. Step 8 Enter the default passcode by entering "0000" on your cell phone keypad.
  9. Step 9 Ensure that the Jabra headset has been paired. Look for the Bluetooth icon in the upper portion of your cell phone screen. Make a call to verify that audio is being routed through the Jabra headset.
Nov 12, 2009 | Cell Phones
How do i pair my jabra w/my phone. cant find
hold down the button till the light turns solid blue, then let the phone already in bluetooth mode find the jabra, it will ask for a password, enter 0000
Sep 07, 2009 | Jabra BT125 Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
Get jabra in discoverable mode
ok i finally found out.. Turn on the jabra unit once on hold the answer button AND the volume up button at same time till u get solid blue light... It will flash like 8 times then go solid... At that point it can b found by all ur devices... the passcode is 0000... Enjoy
Apr 14, 2009 | Jabra BT350 Bluetooth Headset Headset
Reset pairing mode to attach to different phone
With headset off... turn on bluetooth search from the phone.
Hold on button on headset until light turns solid blue. Then search for connection from phone. (code is 0000 (4zeros))
http://www.jabra.com/Sites/Jabra/ap-en/headsetsupport/pages/Knowledgebase.aspx?kbid=ee68a9ea-df26-4882-a7f8-a6cbcc42345c
Mar 07, 2009 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 stopped connecting
BR, I had the same problem with my BT350 and my Razr V3c. I was finally able to resolve the problem by doing the following:
- delete BT350 from device list on Razr
- start Razr looking for device
- put BT350 in pairing mode while phone searching (hold answer button till solid blue light)
- phone will detect BT350 and retrieve name
- select Jabra BT350
- say 'yes' to bond with Jabra BT350
- enter passkey - 0000
- phone will connect with Jabra BT350
May 14, 2008 | Jabra BT350 Bluetooth Headset Headset
How to pair my Jabra BT125...
Instructions for the Jabra BT125 Bluetooth
For people who are having problems pairing their cell phone with their Jabra BR125 Bluetooth, here are a few simple steps:
First, make sure that the Jabra BT is off (the light should be off). If it's on, hold the flashing button until it goes off.
Second, turn your Jabra BT on. Continue holding your Jabra button (EVEN AFTER IT STARTS FLASHING). Hold onto it UNTIL YOU GET A SOLID LIGHT.
Third, as soon as you get a solid light try pairing up with your cell phone.
Fourth add your Jabra to your cell phone's Bluetooth list by having it search for the Jabra.
Fifth, the cell will ask for a passcode. The default passcode is 0000.
Aug 17, 2007 | Jabra BT125 Headset
Pairing with a phone
this happened to me too.. i googled a user manual for it.. if i recall it said, turn the headset power off, then once the phone is in pairing mode, hold the power button on the headset till the light stops blinking and becomes a solid blue light. then the headset is in pairing mode as well and your phone should find it
Mar 20, 2007 | Jabra BT250 Consumer Headset
Cell Phones Logo
50 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
