Question about Gateway Media Center 610X PC Desktop
Bent CPU Pins
I have a few rows of cpu pins that are bent.. I use a credit card to straighten them out.. now i cant tell which ones are bent before... however, the cpu chip still don't really fix holes...
any suggestions?
  • wtm Oct 12, 2007
    is there any way to know that the pins are all straight?
  • 788 Answers
Never use a credit card as the magnitic strip may damage the cpu.
These cpu's are fare too easy to damage. You would be better off replacing the cpu and not removing it if you are un-aware of the outcome.
Cpu's can be picked up almost anywhere, cheap.
Posted on Sep 20, 2009
  • 26 Answers
Line them up in the light. Pins should be evenly spaced in BOTH directions. Look at the pins at eye level and try to line them up straight very carefully, using tweezers gently nudging individual pins. Those pins are VERY fragile and if you bend them too much they'll break. Try to very gently slightly wiggle the CPU into the motherboard without pushing down. Make sure it is lined up with the orientation marker before trying this. Good luck!
Posted on Oct 12, 2007
Asus motherboard p8z77-v lx 1pin got bent toughing another one we have straightened the pin
Mmmmm may have damaged Mobo, pin may have broken off underneath... I have done this, I have also successfully been lucky in straightening pins with a credit card.. good luck... ;o(
Jun 29, 2017 | ASUS Computers & Internet
Bent pin memory card slot
The repair shop, probably will charge more then a new camera, even newer than yours will cost. In my young years I had to learn to adjust relay contacts, and that was not easy, if you want them to survive all. I won't say it is impossible, but it would be a nasty job.
If it is only one pin you have bent, you could try to use one or two little knives or other small and flat tools, and coming from a different side, you could try to come on the pin. If they are not bent that much, you could try to use an old and defect CF card,
Use a little saw, to saw from top to bottom so you are left with a pice with just a few rows of contact holes. you could try to place the piece of the old memory card on a few pins endif they fit, careful press the part of the card down. Or if the pins are bent a lot. shift the part over the pins and try to bent them straight.
I don't know how far the pins are bent, but just try something, without opening the camera.
Jan 09, 2014 | Canon Rebel XT / EOS 350D Digital Camera
Pins have bent as i was trying to place it into the mother board
Are you are talking about the CPU? If so, try tweezers and a lighted magnifying glass. I was able to fix a P4 CPU with a few bent pins that way. You may be able to fix yours. It requires a lot of patience. Good luck!
Sep 24, 2010 | Dell Dimension C521 PC Desktop
CPU pins are bent
Wait if there just bent you can very gentily bend them back with your fingernails. the gentil put it in the Mother board socket slowly if you do it right you can use the socket to re align the pins. make sure you align up the gold arrow on the processor the the arrow on near the corner of the socket. If you have a little of patience you'll be all right. I've done that too along time ago.
Apr 04, 2010 | EliteGroup ECS G31T-M Motherboard - Quad...
L have not yellow colour and blue in my screen,,,
assuming you have a VGA monitor, disconnect the video cable and inspect the pins. Check to make sure that the pins are not bent/crushed or missing (there should be 15 pins in 3 rows). You may need to look at both sides of the cable. If they are crushed/bent, replace the cable if possible. If not possible (because your cable is hard wired to the monitor), try VERY GENTLY to straighten the pins
Mar 07, 2010 | Computers & Internet
How to install CPU- Intel Pentium Dual Core E5200 into a asus barebone system P4-P5N9300pc please?
This particular CPU is not on the list of processors supported by this board. See "CPU Support List" tab:
ASUS P4-P5N9300 Spec
How to install Socket LGA 775 CPUs:
Lift up the cpu slot load plate (which covers the pins and also locks the cpu in place) and install the processor slowly, vertically and carefully into the socket without bending any of the tiny pins in the motherboard socket. Lock the load plate.
The advent of the LGA 775 form factor moved the tiny pins from the CPU to the motherboard socket. Great for Intel, not so great for motherboard manufacturers. Now bent pins are the responsibility of the board makers. Customers with bent pin problems are no longer contacting Intel.
Sep 23, 2009 | ASUS Computers & Internet
Problem with VAIO PCV-RS320
The broken pins are definately the problem. Any CPU needs all the pins to work properly. This problem is solved by replacing the cpu.
Aug 11, 2009 | Sony VAIO PCV-RS412 PC Desktop
Compactflash memory cards
If it will not read ANY type of flash media it would suggest the reader or main board is faulty.
If it reads some type but not others, look down into the card slots with a torch and check to see if any of the pins are bent over. This is a common fault most notably encountered when the machine fails to read CF type cards. You will see two rows of pins in the slot. Chances are one of the pins is bent or been pushed inwards. If you are REALLY steady with your hands you can use a very small (jewelers) screwdriver to straighten the pin. If the pin has receded, it almost impossible to fix it.
Aug 18, 2007 | Epson Stylus Photo R320 InkJet Printer
No Signal Detected
Is this on a notebook or on your regular PC?The answer will determine what the solution is. You can first check to see if the little pins on the plug are all straight and none are bent or broken. If one of he pins is bent then you can try gently straighten it (unplug the monitor from the wall first) If any of the pins are broken then either the cable needs to be replaced or the monior has to be replaced.
Jul 14, 2007 | BenQ FP91G+ 19" LCD Monitor
Are all P4 478pin cpu's compatible with the P4mm2 motherboard?
Just in case your pins are only bent you can straighten them out as long as you are careful. Take a mechanical pencil without lead (.5 works ok but .7 may be easier to use) and ground it by touching it to your power supply. Then work the CPU pin slowly into the pencil and slowly bend the pin up. If you?re patient and careful you can usually straighten out any pins that have been bent. You didn?t stat which version motherboard you had. On the P4VMM2 (V1.3) motherboard the manual states that the motherboard will automatically determine the CPU clock and system buss frequency and makes the appropriate changes. The manuals only references a front-side buss limitation of 400 MHz, however, a FAQ from the manufactures support site says the V1.x motherboard?s CPU is limited as follows: - Pentium 4 400Mhz FSB (256K/512K L2 cache) CPU ? 2.6GHz - Celeron 400Mhz FSB (128K L2 cache) CPU ? 2.6GHz I would stick with the FAQ recommendations if you have to purchase a new processor, that or contact the support line to verify. Make sure you point out the FAQ on their site since they will probably just refer you to the manuals specs. P4VMM@v1.x CPU FAQ: http://www.ecs.com.tw/ECSWebSite/Support/FAQ_Answer.aspx?FAQID=3010023&MenuID=65&LanID=9 Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 14, 2007 | EliteGroup P4VMM2 Motherboard
Open Questions:
See all Gateway Media Center 610X PC Desktop Questions
Gateway Media Center 610X PC Desktop Logo
362 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
