Question about Refrigerators
Ice is coming thru the door of the refrigerator - Whirlpool branc
Ice is is not coming thru the door - no issue with icemaking
    Scholar:
  • 152 Answers
Your insulation is damaged inside the door or poor insulation used in the construction of the icemaker
Posted on May 10, 2009
I have a whirlpool side by side w/ice and water thru the door.model#ED5JHEXTQ00.WATER THRU THE DOOR WORKS FINE BUT WILL NOT FILL ICE MAKER.ANY SUGGESTIONS ?...
Note that the temperature in the freezer must be below 10 degrees F for the icemaker to cycle. The icemaker line is the smaller line (1/4") located in the back of the machine that runs from the valve to the filll tube. To test the valve and icemaker you have to manually advance the ice maker and wait for it to call for water with the 1/4" line disconnected from the valve. You can do this by getting a jumper wire, removing the cover of icemaker, which you jsut grab and pull off, and using the jumper wire insert one end of the wire into the cirle marked "M" and the other in the cicle marked "N". Leave there until you hear a click and sometimes see a little spark behind the modular head wheel. Also if you see ice in the maker that hasn't dumper and the teeth of the icemaker are facing any direction other than two o clock position, the icemaker is bad. Before doing any of the above though check the fill tube to be sure the no ice is blocking water from coming in.
Jun 03, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
I don't have drinking water coming out from the refrigerator. The icemaker seems to be fine but not the water line
Have you changed the filter? This is a common issue with all units that have the water dispenser in the door.
Mar 04, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Icemaker is not making ice cubes. fridge is 3 months old.
Well if your ice cube bucket is on the freezer door it self then it could be anything from the optics system to a bad icemaker to a water valve issue...if its located on the side freezer wall. the water valve could be bad or the i/m module/icemaker
Jan 22, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Icemaker isn't making ice cubes
Ice maker full of ice= faulty ice maker
Ice maker empty of ice= bad water valve
More here
No ice is coming out of ice maker
  1. Whirlpool Icemaker Repair Guide ... guide I will walk you through the steps in a whirlpool icemaker not making ice. ... when you do this water does enter the icemaker take that jumper wire and place ...www.appliance-repair-it.com/Whirlpool-icemaker-repair.html - Cached
Dec 22, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker doesn't work
chack water valve and make sure it is getting water if so and there is ice in ice maker then your heater is bad and not releaseing ice
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
check the fill tube on the ice maker to see if its frozen upo. if it is you are going to need a new solinoid valve due to it leaking thru the valve and freezing up.
Apr 05, 2009 | Whirlpool GD5SHAX Side by Side...
Water from ice makers leaks and builds up in botom of freezer
ice maker leaks are usually a sign of icemaker mold corrosion eating the lining off the icemaker causing it to leak. the only repair is to replace the complete icemaker. you will need a complete model number from the unit and the part can be ordered online thru whirlpool or some of the other appliance parts sites. you may even have a local parts warehouse where you live. hopw that helps peyton
Jan 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
