Question about Samsung PPM50H2 50 in. Plasma Television
REmote Control I have a Samsung PPM50H3/AXX, 50" Plasma TV. The picture is grainy and shadowy The set was made for the United States and is now in Kuwait. I took it to the Samsung Service Center and they could not fix it. The rep. told me the Main board and another part wasn't any good. I am assuming they troubleshot the set using the remote control because none of the rear panel screws were removed. How do you us the remote control to troubleshoot the set, or get trouble code?
Most of the problems is the connections of the cables around the screen some are small electrical high voltage short need to be check, with no lights to see the short.
Posted on May 18, 2008
Hello, I have 50inch Panasonic 3d plasma tv. The tv works good but I feel the picture could look a little better. I have tried all types of calibrating but still have a grainy picture.
if you have cable or satellite remove cable to box make sure it is straight and not broken reattach also with your original remote that came with the tv adjust the contrast & brightness but you must use the remote that came with the tv!
Jan 21, 2016 | Panasonic Viera TCP50ST30 50 3D HDTV...
Autuotune samsung 42 inch plasma
please follow this step:
you have customized the picture and menu settings on your Samsung TV only to find that they keep reverting back to their default positions, this is because your unit is in what is referred to as "Shop Mode." This is the demonstration mode used by electronic retailers to show potential buyers all the features a Samsung television supports. Press the "Info" button on your remote control, and if under the "Picture Mode" heading it reads "Shop Mode," hold down the "Menu" button on the TV itself until the screen reads "Dynamic Mode." This has changed the picture mode to one of the pre-set positions. You may now change any settings you'd like.
God bless you
May 14, 2012 | Samsung 50 in. Plasma TV
Virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
Nov 18, 2011 | Samsung 50 in. Plasma TV
I have a 50 inch samsung plasma tv that i think
You would need to purchase a complete new screen as it is not practical or economic to have this done. I would suspect your fault could be a poor connection from the buffer board to that section of the screen or most likely, as you state, the screen is at fault. It is now just as reasonable to buy a new TV than to have the screen replaced
Jan 10, 2010 | Samsung PS50A466 50 in. Plasma HDTV-Ready
PN50A450 Samsung green screen problem
This is a problem in one or more boards in the TV.
If your TV is still under warranty please call Samsung to get if fix at not charge.
parts for your tv are not cheap and labor is not eider.
Jun 15, 2009 | Samsung PN50A450 50 in. Plasma HDTV
Grainy picture on LG 50PC5D plasma
Did you try another HDMI cable?
Did you try another DVD player?
If the above try-outs does not work for you, then the fault is most likely with the HDMI input processor area. For this the set will require service.
Jerry G.
Feb 03, 2009 | LG 50PX4DR 50 in. Plasma TV
Samsung 50" Plasma TV no response to remote ctrl & buttons
No need to exchange the Logic Board.
Need to exchange the IR modue.
Jan 30, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung PPM50H3
this is indication of protecion short in a integrated circuit to take a few seconds to sense. Please send to recommended service center.
Dec 26, 2007 | Samsung PPM50H2 50 in. Plasma Television
BEST PICTURE SETTINGS FOR SAMSUNG 5044
Try this.... First, go into picture menu and reset it. Next turn contrast all the way up. Turn the sharpness all the way down. Make sure the tint is in the middle. Adjust brightnesses accordingly. If that don't work, just drop me a line and i will explain more
Best regards
CircuitCity
Nov 29, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Samsung PPM50H2 50 in. Plasma Television Logo
115 people viewed this question
Jerry Greenberg
Jerry Greenberg
