Question about Haier Refrigerators
Haier Wine Cooler [Model: HVF020ABB; 2.9 cu ft] Digital display showing "LL" and temperature is not stable.
SOURCE: Haier 1.7 CU Ft. Refrigerator - what is warranty
1 year parts and labor
Posted on Aug 17, 2008
SOURCE: Haier Wine Cooler won't cycle on and off automatically
Hey all,
For those of you who have problems with one or both or your zones not cooling on the HVTB18DABB or similar wine cooler/cellar, the problem lies the Peltier-style thermoelectric cooling module. The original part is "TEC1-12706" and information on it can be found on google. Finding this or a similar part on ebay can be done by searching for "thermoelectric cooler". If the exact TEC1-12706 part cannot be found, then any similar part that's 40mm x 40mm in size, and 51 to 69 watts should do fine. For $25 I was able to get 3 modules...one to replace the bad zone I had, and then I'll have 2 spares in case the other zone, or this new one, ever go bad again.
To replace the part you must remove the back panel from your Wine cellar. You will see 2 big fans attached to two large heat sinks. (If a heat sink on the back does not feel warm to the touch, the the other side is obviously not cooling, which means that zone is broken.) Remove the screws from the fan and the heat sink of the zone that is not cooling, and while holding the heat sink, pull the whole cooling assembly for that zone out. Dont be alarmed if you feel some insulating foam separating as you pull it out, its a tight fit so that is to be expected. Once you have the cooling assembly out of the fridge, take it apart and you will see the square ceramic cooling module inside. (REMEMBER which way the module was oriented before you remove it, so you know how to put the new one in.) Clip the red and black wires near the module and remove it from the assembly. DON'T wipe away any of the white thermal grease left behind on the heat sinks. If you have any extra thermal grease handy (available at Best Buy, or online at sites like newegg), apply an extra pea-sized dab to both sides of the new module. Put the assembly back together and splice the wires from the new module to the loose wires left behind going into the back of the Wine cellar. Mount everything back in place as before, close up the back, and youre done!
This is really a lot easier to do than it sounds, especially if you're comfortable doing this sort of thing...a few pictures would explain much better if anyone wants to illustrate.
These are actually great units, so I hope this helps somebody fix theirs!
Posted on Sep 24, 2008
SOURCE: Oster wine cooler (peltier diode)
I called the contact in one post below, and he was VERY helpful. Took all my info, submitted to the division handling this and they overnighted me a check for the entire amount plus tax for the wine cooler to me! Call Jason!
Jason's contact info is:
Jarden Consumer Solutions
2381 Executive Center Drive
Boca Raton, FL 33431
(561) 912-4100
Posted on Oct 02, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Digital temperature display is missing part of the
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Posted on Jan 02, 2010
Testimonial: "Thank you for the quick response!!!!"
  • 183 Answers
SOURCE: Wine temp on Haier wine
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts: http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/BC112G.aspx
Posted on Dec 31, 2010
How do i set the temperature on my haier model number hvdw20abb
Thanks for including the make and model number.
Without these, an answer is impossible.
Here is a link to the manual, which describes in detail how to adjust the temperature.
Haier HVF020A User Manual Wine Cooler Features And Use Initial Set Up...
If you found my answer helpful, please rate. Otherwise, feel free to ask for any further info if needed.
Oct 30, 2014 | Haier HVDW20ABB 20 Bottle Display Window...
Magic Chef Wine Cooler Model #MCWC50DBT will not hold correct temperature. Temps fluctuate between about 45 to often 70 degrees F. Also, often get an "EEF" error message.
Mr. Lindquist: We are experiencing essentially the same problem. Have tried replacing the temperature control board without change. Would be interested to know if you get a solution.
Aug 10, 2013 | Haier BC112G Wine Cooler
How to adjust the temperature of the wine cooler
How is temperature adjustment set for proper cooling,my Haier holds [9] btls of wine ,please help.
Jan 05, 2011 | Haier BC112G Wine Cooler
Wine temp on Haier wine cooler BC112G went to LL, opened up and some champagnes frozen, other wines very cold, condensation all over door, how do you fix this error?
Dec 31, 2010 | Haier BC112G Wine Cooler
Can't change the cooler's temperature? the temperature reads LL and its very cold.
LL is an error code which means that it is too cold. Surprised that it didn't freeze something. Problem is likely the thermostat ($15 - RF-7350-55) or motor control board ($50 - RF-0668-04).
Nov 21, 2009 | Haier BC112G Wine Cooler
Temperature guage shows "LL"
Probably a bad themp control. try jumping it out. If the unit runs get a generic cold control with a variable temp adjustment. A water fountain control would work as well. Jeeze these dayum chinese pieces of **** are so bad.
Jul 08, 2009 | Haier BC112G Wine Cooler
Haier Wine Fridge problem
Hello bano24
Welcome to Fixya
My name is Huum,
You have a faulty cold control (temperature control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
Check the control for continuity.
And or need a hands on service tech to diagnose this fault
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 30, 2008 | Haier BC112G Wine Cooler
Haier Wine Refrig runs to cold
change your temperature sensor, it's broken and it's going to down temperature
Aug 22, 2008 | Haier HVF042 Wine Cooler
Temperature control
Click on the link bellow then type in your model number then hit go to display your manual
http://www.haieramerica.com/en/support/modelsearch
Nov 30, 2007 | Haier BC112G Wine Cooler
Refrigerators Logo
165 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
