Question about Car Audio & Video
Im tryin to replace the tape deck in my ford ka
What colour is the ground wire and the battery wire as im tryin to take out the tape deck on put in a cp player in to my ford ka my ford ka is an r plate
    Sniper:
  • 61 Answers
Rather than cutting wires i'd advise you to buy a pc2-17-4 autoleads ford harness. you can get them in a shop such as halfords or on ebay for between £3.50 to £10. You can plug this directly into the car and straight into the radio you are installing provided it has a standard iso block on it. it means when you sell car you can reinstall the old radio and take new one with you. Plus no tedious wire cutting.
Posted on May 15, 2009
Radio cuts out
Did the xplod deck work correctly before you installed it? When it cuts out does it loose all its memory and setting and go back to factory defaults? It is possible that the deck is faulty.
Nov 15, 2013 | Dodge Neon Cars & Trucks
Help getting my ford ka started
Battery Cables maybe? Check the Cable ground to battery make sure it is grounded to Battery and Frame also check Starter wires and the Positive to the Battery.
Feb 11, 2013 | Ford Vehicle Parts & Accessories
1985 Ford Laser, I want to know what wires/colour match new wires/colour when installing a new car stereo and speakers?
do it the old fasion way i have never used diagrams for splicing iht existing wiring.
simply a test light to find constant+ switched + ground, and such thin trial and error for speakers!
there's 3 screws above the heater/vent controls, and two screws behind the ashtray - you've gotta pull it all the way out. then the centre console comes out, along with the stereo. the heater control knobs pull off by hand, no screws, you may also have to remove the choke 'knob' to get the plastic consol off. The knob is held on by a screw on its underside, then you will have to unscrew the collet (chrome thing) with a screwdriver, you will see what I mean.
For speakers, if the car already has them then sweet, but if you need to check polarity is correct get a AA battery put the wires on either end, and if the speaker moves 'out' polarity is correct as per the signs on the battery,if the speaker moves in the polarity is wrong.
does it have the standard pioneer deck in there?
if so and u want to go by those colours
red = acc
orange = +12v
black = ground
green = left +
black = left -
grey =right +
black = right -
(cut the joining black wires on the plug (the one that has 2 black wires coming out is the front, the one that just has one black then a bridge across the plug is the rear)
if u want to go behind the plugs then
blue/red = left +
blue/yellow = left -
blue = right +
blue/white = right -
(same for rear but on a seperate plug)
dont remember the colours for acc and 12v (they're blue with some trace, one of them is black i think)
ground is black (might have grey dots)
illumination is red/black
Dec 13, 2010 | 2006 Ford Laser
Wirng colours ea ford radio
try the locu libbary they should have book on it
Jun 03, 2009 | Ford Futura Cars & Trucks
Wire colours for my pioneer deh 2300
here are the wiring for the deck and the car:
Deck:
12v - red
ignition: yellow
blk - ground
orange - dimmer
white - frt left +
white /blk - frt left -
gray - frt right +
gray /blk - frt right -
green - left rear +
green /blk - left rear _
Purple - right rear +
Purple w/blk right rear -
Car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 02, 2009 | Pioneer DEH-P4100
Cant turn up the gain on my amp
I believe you have a wire touching a ground somewhere in your car stereo circuit. Most likely there is a speaker wire in your dash that is the cause. Here is a reference: http://www.bcae1.com/brighead.htm
Also make sure the RCA's are taped up in your dash, they will create an entrance to feedback from the amp, which will inturn make your subs go crazy. Also, unplug each channel RCA from your amp and see if it stops, you may have a break in your RCA's causing a ground.
Feb 15, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KA-880D Amp keeps blowing the 6v 250w fuse
please check the VDR in primary supply side.its directly connect to bouth N&Live wire connections of supply.
nuwan.
Jan 11, 2009 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Car Audio & Video Logo
417 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
