Where can I find information on my 866 AS Ultra Raid motherboard? The computer is diassembled and I want to upgrade components. Thanks Jim
  • jim5749 May 10, 2009
    Yes, I downloaded the manual and printed it.
    Thanks a lot.
    Jim
    Brigadier General:
  • 8,619 Answers
Hi
The configuration for your Motherboard is---
VIA KT266A Chipset
Socket A 200/266 FSB CPU
5PCI slots
1 AGP slot
1 CNR/ 3 DDR DIMM slots
ATA 100, IDE Raid/ ATX Form Factor
Maximum RAM supported = 3 GB (1GB in each slot)
Please see this manual which has same configuration as your 866 AS Ultra Motherboard--
Jetway 866 AS Ultra Raid Manual
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Posted on May 10, 2009
Have a supermicro x6dal-tb2 motherboard, upgraded to windows 7. Can't find drivers for the Sata Raid controller. Help?
That driver will be issued by the RAID card manufacturer. If this is a software RAID controlled by the motherboard, your only hope is the latest BIOS firmware R1.0c:
Super Micro Computer Inc Products Motherboards Xeon Boards X6DAL TB2
Oct 19, 2010 | SuperMicro X6DAL-TG Motherboard
NEED DRIVERS LOST DISK SD-SIL680-RAID
you can download from web site of board if you can use the public libray system jim
Mar 25, 2010 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
Installed new processor and computer doesnt turn on just flashes green steadily?
CPU • Supports 64-bit AMD® Athlon™ 64 processor (Socket 754) • Supports 2800+, 3000+, 3200+, 3400+, 3700+ • Supports Sempron 2600+, 2800+, 3000+, 3100+, 3300+ Chipset • VIA® K8M800-CE Chipset - HyperTransport connection to AMD Next Generation of CPU - 8 or 16 bit control/ address. data transfer both directions - 800/600/400/200MHz "Double Data Rate" operation both direction - AGP v3.0 compliant with 8X transfer mode - On-board Graphic shared up to 64MB • VIA® VT8237R Chipset - Ultra DMA 66/100/133 master mode EIDE controller - Integrated dual channel native Serial ATA/RAID controller that will supply 150MB/s and support RAID 0, RAID 1 - ACPI & PC2001 compliant enhanced power management - Supports 8 USB2.0 ports. (Rear x4/ Front x4) Main Memory • Supports two 184-pin DDR SDRAMs up to 2GB memory size • Supports DDR400*/DDR333/DDR266 DDR SDRAM (*Refer to MSI recommended modules) • Note: PC3200 (DDR400) maximum 4 banks (2 double-sided) only
I can't seem to find any usefull information as to why there may be a LED flashing on the motherboard. Re-check the memory speed, and configuration, as well as the CPU that it is supported. This seems to be a fairly new motherboard, it may still be under warranty, contact MSI and request an RMA if you feel the motherboard is faulty.
May 31, 2009 | MSI K8MM-V Motherboard
Oc a nvidia geforce 5700 ultra need info
Hey,
Do you want to overclock the 5700 ultra? Its a old card and the performance wont get much better, instead I would suggest upgrading the video card to a newer one or the whole computer.
The nvidia 7xxx series fits into a AGP slot I would recommend that, its alot better but upgrading the computer would be even better.
Let me know if you need anything else.
Thanks,
Ekse
Feb 20, 2009 | PC Chips Computers & Internet
Increasing ram
According to Gigabyte's site, this board is expandable to 4GB of RAM using dual-channel DDR266/333/400 modules.
You can visit the site and get full information here.
Jan 19, 2009 | R.A.M. Computers Gigabyte GA-K8NS...
User's Guide, information....
Hi Buck,
I can direct you to a link which will allow you to download the manual for the, Abit BX 133-Raid motherboard. (Abit no longer supports any downloads for this motherboard).
Other than the drivers for the board, the manual is the most needed item for any motherboard.
Click on this link;
http://europe1.nodevice.com/downloads/b7acbf211e78b9448e08a1ca3ddaccef/20050729085007_bx133.pdf
To view the manual you will need to download & install, Adobe pdf reader. (This too is free).
http://www.adobe.com/products/reader/
Once the manual is opened into Adobe reader you can print the manual. Though printing is an option it's not the best option. It is best to view while in the PC. While being viewed in a PC you are able to zoom in & out which makes it easier to see the tiny details of the board. (Very helpful)!
You can download the motherboard chipset utility which will install most if not all of the drivers needed to run the parts on the motherboard.
Click on this next link: http://driverscollection.com/?file_id=5144
Lastly here are the specification for the board: (Also found in the manual).
CPU
1. Supports Intel Pentium® III Socket based processor
2. Supports Intel Celeron® Socket based processor
3. Reservers support for future Intel Pentium® III/Celeron processor
Chipset
1. Intel®440BX chipset (82443BX and 82371EB)
2. Supports Advanced Configuration and Power Management Interface (ACPI)
3. Supports AGP 1X/2X (Sideband)3.3V device
Ultra DMA 100
1. High Point HTP370 IDE Controller
2. Ultra DMA 100MB/Sec data transfer rate
3. RAID 0(stripping mode for boosting performance)
4. RAID 1 (mirroring mode for data security)
5. RAID 0 +1(stripping and mirroring)
Memory
1. Three 168-pin DIMM sockets support SDRAM module
2. Supports up to 1GB MAX. (8, 16, 32, 64, 128,256MB SDRAM)
3. Supports ECC
System BIOS
1. SoftMenuTMIII Patent Technology and DIP switches to set CPU parameters
2. Award Plug and Play BIOS
3. Write-Protect Anti-Virus function by AWARD BIOS
4. Year 2000 Compliant
Multi I/O Functions
1. Two Channels of Bus Master IDE Ports supporting up to four Ultra DMA 33/66/100(up to 4 HDD devices)
2. Two Channels of Bus Master IDE Ports supporting up to four Ultra DMA 33 devices(up to 4 HDD devices)
3. PS/2 Keyboard and PS/2 Mouse Connectors
4. 1 Floppy Port (up to 2.88MB)
5. 1 Parallel Port (EPP/ECP)
6. 2 Serial Ports
7. 2 USB Connectors
Miscellaneous
1. 1 AGP slot, 5 PCI slots and 1 ISA slot
2. Hardware monitoring - Including Fan speed, Voltages,System environment temperature
3. Keyboard/Mouse/Password and Hot Key multifunction Power On.
4. Built-in Wake on LAN/Wake on Ring header
5. Built-in IrDA TX/RX header
You can also high-light this entire question & answer post & print all this.
Good luck Buck!
Have more questions? Post them here.
Mike
Nov 08, 2008 | Abit BX133-RAID Motherboard
Sata raid config
first check your bios & see what raid chips are enabled,usually there's 2. Your main raid is on the first 4 sata connectors, the other chipset probably controlls the remaining sata ports. So if there's an option to disable one raid chip,disable one,just not the one that you're using. I don't know what your bios screen looks like,so this is just a general view based on my experences with various boards,mainly asus.
Jul 13, 2008 | Abit AW9D-MAX Motherboard
Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Dec 17, 2007 | Biostar P4M800-M7A Motherboard
M7NCD ULTRA raid drivers
If the SATA drive is operating in 3.0 Gbps mode and your motherboard can only support 1.5 Gbps mode, the drive will not be detected in BIOS or XP. Try jumpering the drive to SATA 1.5 Gbps mode. The label on your hard drive should indicate which pins should be shorted to achieve this setting; if not, look up your particular model on WD's website to find the manual.
Nov 05, 2007 | Biostar M7NCD ULTRA Motherboard
Computers & Internet Logo
David Payne
David Payne
