Question about Electrolux EW1000i Front Load Washer
The ewf 1234 doesn't take in water and shuts itself down.
I have the same problem now and then and I usually solve it by switching off the electricy (fuse) for the machine one or a couple of times. Finally it has started again. Have no idea why it works or if it is good for the machine in the long run, but I am a big alt+ctrl+del fan so...
Posted on Jul 06, 2009
I have an washing machine type EWF 1234 does not work and error on the screen E50 I want know the solution and how the treatement thank you
An E50 error indicates a problem with the power control board or the motor. You may be able to get additional information by starting the washer on any program except the first one. Press and hold the start/pause button then press the button 2 buttons to the left. If you see an E51 error, then the triac on the power board has failed. This usually means that both the main control board and the motor have failed.
I can't find a parts list for the EWF 1234. Please check if there is another model number on the unit and add a comment with that information.
I wish that I had better news for you.
Jul 31, 2017 | Washing Machines
Model gfwn1100 front load washer
It shuts down because of time out, is the water turned on, sounds stupid but it has happened several times, I go on a service call just to turn the water on to the machine.
Feb 03, 2014 | GE Washing Machines
Dell Inspiron 8500 won't shut down, on/off button doesn't repond
Hold down the ON/OFF button for several seconds until it shuts off.
Mar 04, 2013 | Dell Inspiron 8500 Notebook
Our electrolux front loader Washing Machine EWF 1083 won't fill with water and there is a humming sound, does anyone know what the problem is ? cheers
Just a long shot - it may be the water inlet filter is blocked? normally there is a little mesh filter in the hose that screws onto the back - check that its not full of crap. This happened to me only a few weeks ago hope its as simple as that for you.
Jan 20, 2013 | Washing Machines
Electrolux EWF 1090 front-loader - the pump cover jammed - help!
You will need to replace the pump assembly. Here is the pump to order. There is no fix for the leak.
The part comes with a 365 day, any part, any reason return policy.
Nov 09, 2012 | Washing Machines
How do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
Jul 19, 2012 | Electrolux EIFLW55HIW Front Load Washer...
Acer extensa 4420 shuts down right after you push power button
sounds like it doesn't have enough power, is it completely charged? you may want to make sure you're getting power from the charger itself.
Jul 02, 2012 | Acer Computers & Internet
My viewsonic cine1000 shuts itself off after about 15 -20 min of playing. The bulb has about 500 hours on it. Why does it keep shutting itself down? It doesn't turn itself to standby either, the...
Make sure the PC itself is not going into a power saving or screen saver mode...this is the most common issue when playing completely automated presentations or movies.
Normally, I suggest turning off all power saving functions in the PC or Laptop, and disabling the screen saver all together.
Jun 20, 2011 | ViewSonic Cine1000 Multimedia Projector
Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
Electrolux EW1000i Front Load Washer Logo
413 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
