How do you make the keyboard letters light up???
How you make the keyboard light up???
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 79 Answers
You have to have a keyboard that lights up. There are several good ones out there. I like my logitech. Go check out office depot or Best Buy for a lightup keyboard.
Posted on May 10, 2009
How do you turn on *** q550 backlit keyboard
If the letters & numbers on your keyboard looks like transparent plastic, then you have a back lit keyboard, but if the letters & numbers looks like they are painted on the key caps, then you don't have back lit keyboard.
let's assume that you have a back lit keyboard: Hold the Function [Fn] key and tap the Spacebar once. That will enable/disable the back light.
You can easily tell if it's a backlit keyboard because the spacebar will have a keyboard icon on the left hand side. If it has the icon, then your keyboard has back lights on it & it should work.
If it doesn't, then it's a hardware issue that a technician needs to fix.
Aug 29, 2014 | ASUS Computers & Internet
I have missing letters and numbers on my Sony Veio laptop keyboard when I type
Keyboard damage? Try a USB keyboard to check it before buying a new one.
Apr 22, 2014 | Sony Computers & Internet
Keyboard typing wrong letters
Your keyboard is not "typing wrong letters", you have a stuck key. The key is shorting out and is stuck on the letter W. Usually caused by dirt/dust/spills on the keyboard jamming the key so it can't release. Things to try in order of difficulty:
>Vacuum cleaner with brush attachment, vac the keys.
>Paper towel moistened lightly rubbed on the 4 sides of the W key; use a knife blade to gently work down into the edges.
>Soft toothbrush, lightly dampened with water, work the bristles all
all around the edges of the W key. After that do step 2 with a dry
dry paper towel.
>Take the keyboard apart; usually several tiny screws on the rear/sides. CAREFULLY remove the top. You may have to turn the board over, lie on its face to do this. Do not knock the letters out of order or you will have a headache placing them back in proper order! Clear whatever it blocking the W and replace the cover.
If none of the above works the keyboard has failed, needs to be replaced.
Jun 08, 2013 | Samsung Computers & Internet
Keyboard
Keyboards on Windows computers can repeat letters when key press sensitivity is too high. This problem can be rectified by adjusting your keyboard's repeat frequency. Once this is lowered, key presses will occur slower and you will not have the letters repeated instantly.
Click"Start," then "Control Panel." Click "Hardware and Sound," followed by "Keyboard." Move the "Repeat delay" slider further to the left below the "Character repeat" option. The further left the slider moves, the longer the delay will be before a character repeats.
Feb 04, 2013 | Vizio Silver 15.6" Thin Light CT15-A2...
My letter keyboard is showing numbers and not letter..please help. (advent laptop)
Laptops do not have as many keys as a normal keyboard so often they include the numbers over letter keys.
So, by mistake you pressed a ctrl or alt or [A] key that simply switches the keys from letters to numbers.
A light or indication must be ON on your laptop indicating that it's Numbers or Letters ON.
Find the key that changes the function and restore the function to letters.
Aug 04, 2011 | Computers & Internet
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
When i press the letters numbers come up
Your keyboard has a button which permits you to use some of the letters keys as a numeric keypad. It works like a shift lock key and probably has a light incorporated with it as a shift lock key does. In fact it may be labeled "Num. Lock".
Jan 03, 2010 | Compaq Keyboard
Letter become numbers
Spacesaver keyboards use letter keys for numbers. Press num-lock so its light goes off, then you will get letters again.
Apr 29, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
How to light keyboard
the letters and numbers dont' glow my friend. sorry.
Dec 24, 2008 | Logitech diNovo Edge 9676850403 Keyboard
Dynex Keyboard
My keyboard misses letters when I type my email
Dec 20, 2007 | Dynex Multimedia Keyboard DX-MKB101
Computers & Internet Logo
1,632 people viewed this question
David Payne
David Payne
