Question about Mitsubishi HS-U447 VHS VCR
VHS will not stay engaged with cassette
My VCR was in an extra room unused and not plugged into an electrical outlet for about 1 year. I went to use the machine again and when I plugged it in and put in a video tape it would engage the tape and run it about 5 seconds and then stop and eject the tape. It does this over and over and I have used various tapes with the same results. I pulled the cover but could see no obvious problem with anything. Help!
  • 1 more comment
  • kardon71 Jun 17, 2009
    I understand the cleaning part but how do I check the motor?
  • kardon71 Jun 23, 2009
    I borrowed a volt meter but am not really understanding quite how to use it. I have cleaned everything inside that I could. Please advise
  • kardon71 Jun 24, 2009
    Thanks very much for your prompt replies to my questions. Your help is much appreciated.
  • Mitsubishi Master
  • 3,866 Answers
This machine is telling you it needs cleaning or the sensor that pulls the tape to the drum is bad and needs to be changed out. But you had it sitting for a year would not rule out that cleaning is in order also it would not rule out the sensor i am talking about. I repaired VCR's for years and the sensor is telling it to eject as there is a jame or it is dirty.
Thanks for using Fixya.com
Posted on Jun 24, 2009
  • 3,230 Answers
It seems like the motor problem, you need to check the motor.
also try some cleaning in this VCR by using a soft cotton cloth and thinner.
Good luck
thanks
Posted on Jun 14, 2009
  • Mukesh Kumar Jun 17, 2009
    Do you know how to use a multi-meter (volt-meter)?
    So i can assist you further.
    Thanks
When inserting vhs tape, the player pulls the tape from inserted vhs
That is exactly what a typical M-Load mechanism is supposed to do. Once the VHS tape cassette is inserted, cassette housing cover will be flipped up and two arms will pull tape out of cassette housing to wrap tape around cylindrical spinning head housing that contains video heads and, if VHS HI-FI, audio heads as well. When stop or eject button is pressed, arms will retract and tape will wind back into cassette housing. What type of problem are you experiencing with unit? It may have nothing to do with M-load engaging tape around head cylinder.
Mar 22, 2014 | Samsung DVD-VR325 DVD Recorder/VCR
VHS cassette accepts and ejects with kir..r...r sound. I have removed the power cord (Power OFF) and cassette was inserted halfway and then plugged the power cord (Power ON). At this time the VCR ejects...
First of I think you have a K-Deck mechanism. If you do a Google search for "Panasonic K-Deck" you should find the free information. If you can't you will need to E-Mail me.
This sounds like a a timing problem, perhaps caused by some damage to the Cassette Holder. The mode switch could be part of the problem too. They are quite tricky to set up to get the timing right, I do know the Cassette has to be inside the machine to set it up. The good news is that parts are easy to get hold of, so if any thing is damaged it can be replaced. Curry's partmaster is a good place for parts.
Oct 25, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
I would like simple steps to transfer VHS to DVD on my Toshiba DVR620KY. I want to copy with the unit alone. Would appreciate your help. Thanks.
Hi ,
Please follow the instructions below to record from VHS to DVD. You may not be able to record from some pre-recorded VHS cassettes due to copyight protection embedded into the recording. You should stick some tape over the copy-protection tab on cassettes prior to recording if the tab has been removed. On some cassettes, there may be a slide switch which needs to be moved to the record/rec position. All pre-recorded cassettes will have the copy-protection tab removed.
1. Switch on the TV and DVD/VCR and select the correct input on the TV for the player.
2. Set the player for the recording direction, i.e. VCR to DVD . . .
- Press the SETUP key on the Toshiba remote to open the on-screen menu
- Use the UP/DOWN arrow keys to highlight GENERAL SETTING then press ENTER
- Use the UP/DOWN arrow keys to highlight RECORDING then press ENTER
- Use the UP/DOWN arrow keys to highlight DUBBING MODE then press ENTER
- Use the UP/DOWN arrow keys to highlight VCR > DVD then press ENTER
- Press the SETUP key again to close the on-screen menu
3. Press VCR to select VCR mode.
4. Insert the cassette you wish to record and fast-forward or rewind it to the position where you want to start recording from. Allow at least 5 seconds extra if not starting the recording from the beginning of a cassette.
5. Press PLAY then press PAUSE immediately.
6. Press DVD to select DVD mode
7. Insert a blank DVD
8. Press the REC MODE button to select the recording mode (XP / SP / LP, etc)
9. Press the DUBBING key to start the recording.
You can watch the VCR while it's recording. When you reach the point where you want the recording to end, press the STOP key. You do not need to repeat step 2 every time you record. The player will stay in VCR > DVD recording mode unless you change it.
Hopefully, you will now be able to record from VCR to DVD. If you need further assistance, please let me know.
Regards,
BElectric
Mar 26, 2011 | Toshiba D-VR4 DVD Recorder/VCR
Sony slv-n700 has been in storage. Has been used very little. Last used successfully approximately 1 1/2 year ago. Loads tape around read head, seems to try to start to play, but cassette spools do not...
VHS tapes, VCR's, as well as cassettes have all become obsolete. Putting these in storage is bad for them. They contain rubber parts on the inside that do not do well in cold weather in storage if that is where they were stored. You could possibly get replacements from the internet. With todays technology I would recommend going digital or DVD's or maybe even Blu-ray. Hope this helps.
May 21, 2017 | Sony SLVN700 VHS VCR
VHS cassettes stuck NOT in a VCR. I have a few old VHS cassettes that I want to copy to DVDs. The problem is that that the tape in these cassettes gets stuck. Not only in the VCR. When I use an external...
Yes,Loosen all the VHS cassette screws from the video cassette plastic cover.Take ur finger shaking and rewine wheel a few times with it with ur finger.The VHS tapes shoud work find now.
Dec 06, 2010 | Televison & Video
I bought a panasonic cassette adaptor for my vhs-c tapes . it says svhs adaptor on the front of the box .will the ordinary vhs-c tapes fit in it and does the door open on the front or is it loaded from the...
You don't specify the adapter you have, but most load from the top. The main thing here is that VHS and VHS-C are both the same size of tape. Whether they are recorded in SVHS mode or not will not affect the adapter, just whether or not you get a picture. Theadapter only allows you to put a compact cassette (VHS-C) into a standard VHS VCR. The adapter will require batteries to allow it to place the VHS-C cassette tape into the proper position for use in the VCR.
Dan
Nov 24, 2010 | Panasonic PV-P1 VHS-C CASSETTE ADAPTOR
DVDR/VCR Combo_ZV450MW8a. When I insert the VHS cassette...
Had the same problem. took cover off, cleaned the recording heads. Also look on the left and right of casett chassie.You'll see to thin green strips sticking up with a black elctronic device. Chech to see if it is aimed at the clear plastic pin near the little black plastic gear in the middle. mine was out of alignment on the left one. Works know. Good luck
Jan 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
After vhs auto rewinds both it and TV power down
some televisions have a feature where the video signal disappears,they power off.when the vcr shuts off,the signal goes and the tv shuts down
Jul 07, 2009 | Emerson EWV403 VHS VCR
Vcr sanyo vhr-h793e
It sounds to me that it wasn't the power going off that caused the problem, but when it came back on! They are called surges and they cause damage to the power supply to any electrical equipment. Most parts in the power supply area have to replaced with the same thing for safety (fire prevention). If it's gone there you might have a job getting it fixed. The cost might not be worth it, even if you could do it yourself (not recomended).
In future connect TV's videos and computer etc through Anti-surge plugs (the ones with the lights that tell you it's working) you can then scrap that instead of expensive equipment.
Jan 25, 2009 | Sanyo VHR-H647 VHS VCR
Doesn't power ON
If you have no indication of power at all,(no lights,no display)the fuse is the first component to check but the vcr has be unplug from the wall when you remove the top cover and remove the fuse to check it.Be carefu.
Sep 25, 2006 | Samsung SV5000W VHS VCR
Mitsubishi HS-U447 VHS VCR Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
