Question about HP LaserJet 3600n Printer
Insufficient memory My HP Color Laserjet 3600n works fine with all applications (Word, Excel) but when used with MSWorks it cannot print and gives a Insufficient Memory error. I tried different computers with same printer, but still the same error message. I had a long chat with HP but they are not capable of solving the problem. This printer seems to have a Host based driver, meaning that it uses the memory of the computer for the printjob. This is no explanation for even a blank Works letter cannot be printed. In Word I can print complicated merged files, using a lot of memory space. Just opening a Works file with database fields in it, gives already a memory error. It seems to be connected with Works for the same file converted to Word has no problem. Anybody knowing this problem and a solution?
  • Vreeswijk Sep 19, 2008
    I am sorry but this is not the solution.
    I have more than 100 Gb free on my harddisk, I have a duo core processor 4Mb memory.
    If this is not sufficient for printing??
    Complicated Word docs with several photo's are printed without any problem.
    Converting the Works doc to a pdf file is the only working solution for the moment.
    Luckily I work mostly with Word or Excel, but I have a lot of old stuff in Works.
    It is definitly a strange incompatibilty between Works and this printer software.
    Even with a print preview there is a crash.
  • 147 Answers
If it's host based, that means when you print:
1) from word, your word document is converted to a series of characters, and sent to the printer.
2) from excel, same thing.
3) from works, it's converted to a bitmap, instead of characters, which can take up significantly more space on your drive.
My guess is that if you imported a photo into word, then tried to print it, you might face similar issues.
If so, it's time to free up some space on your hard drive, or purchase a second one, or add some physical memory to your PC.
Posted on Sep 18, 2008
Door closes with no cartridges but will not with cartridges. looks fine, worked fine before putting in new cartridges for the 1st time. hp color lasorjet 3600n
Did you make sure the cartridges clicks in place? There are while plastic locks on each cartridge and hopefully they are not broken. Not expensive to purchase but major teardown to replace.
Oct 23, 2013 | HP LaserJet 3600n Printer
PCL XL error on HP color laserjet 3600n
Verify printer functionalityTo verify printer functionality, use the following steps:
  1. Turn off the printer and then unplug the Parallel, Serial, or Network data cable from the back of the printer. This will ensure that the information is not being received from the computer or network.
  2. Turn on the printer and verify that the word Ready appears on the printer display.
  3. Print a self-test on the printer by performing the following steps:
    1. Go to the on the printer.
    2. Press the MENU key until INFORMATION MENU appears on the printer display.
    3. Press the Item key until PRINT MENU MAP appears on the printer display.
    4. Press the SELECT button. The printer should generate a print job.
Try to print a page using the software application or a document in question after attempting each item of the following workaround. This will help determine if the changes made have caused the desired results to occur.
  1. Connect the printer directly to the computer. Use an IEEE/1284-compliant cable.
  2. Print a Test Page by completing the following steps:
    1. Click Start and then Settings and Printers .
    2. Right-click the appropriate printer driver.
    3. Select Properties .
    4. Click the General tab and click the button in the lower right-hand corner that is labeledPrint Test Page .
If the error is not resolved, try a different IEEE 1284-compliant cable. If there is no possibility to direct connect, use a different network cable, or network port, on the hub. Simplify communication options depending on the specific printer. Use the Control Panel on the printer to turn off High Speed andAdvanced Functions . To turn off High Speed and Advanced Functions complete the following steps:
  1. Press the MENU key.
  3. Press I/O MENU and disable Parallel High Speed .
  4. Press I/O MENU and disable Advanced Functions .
  5. Connect the printer to a different location, change parallel/USB/network cables. Bypass switch/hub (if there is any).
For problems with certain applications or documents, try modifying the HP LaserJet printer series PCL6 driver settings, such as:
  • Use lower resolution, such as 600 dpi.
  • Enable or disable Send True Type as Bitmaps .
  • Disable the Print Optimization under Printer Properties => Advanced => Document Option .
Some more steps:
  • Try changing the personality type to Auto/PCL/PS in printer Control Panel.
  • If changing personality does not make any difference, remove the current driver completely (from Server Properties ), restart the system, and install PostScript (PS) driver.
  • While installing the printer driver, select the standard TCP/IP port if the default is HP Port , and vice-versa.
General troubleshooting tipsContinue to isolate the error by printing the job in question after applying each of the following suggestions:
  1. Remove any additional memory that has been added to the printer after being purchased. Refer to the User's Manual that was supplied with the printer for memory removal instructions.
  2. Try using a different Font within the application or document in question.
  3. Try to print using the PCL5e driver that came with the HP LaserJet Printing System.
Dec 21, 2011 | HP LaserJet 3600n Printer
I have an HP Color Laserjet 3600n with error 10.10.03
Thank you for contacting FixYa with your printer issue. Support Document (110993)
10.XX.YY SUPPLY MEMORY ERROR Description The printer cannot read or write to at least one print cartridge memory tag, or at least one memory tag is missing. Action
  1. Open and close the front door.
  2. Remove the print cartridges, and then reinstall them.
  3. Close the front door.
  4. Turn the printer off and then on.
  5. If the error persists, contact HP Support.
Helpful CLJ 3600 Error Message Tables:
Hope this helps helps. Please keep us updated and remember to rate this answer.
Jan 22, 2011 | HP LaserJet 3600n Printer
Hp color laserjet 3600. It keeps telling me that
if you have used another printer on the same port # or local port. plug the cable into the 3600 and refresh the port. if its an ethernet port print th io sheet and make sure its holding its settings.
Oct 18, 2009 | HP LaserJet 3600n Printer
Cyan is offset about 3/16"
check the locking tabs on the cartridge, sounds like they are not locking down the cartridge.
Jul 31, 2009 | HP LaserJet 3600n Printer
HP Laserjet 3600n doesn't match screen color
Check the levels for your Magenta cartridge and replace if necessary.
Otherwise, Enter the properties of your printers driver in the control panel and establish if there is any advanced color management being used.
Let us know if you need anything else.
May 13, 2009 | HP LaserJet 3600n Printer
HP LaserJet 3600n Printer Logo
533 people viewed this question
Ben Johnson
