Question about Refrigerators
Removing plastic covering on new refrigerator
We a having a hard removing the plastic covering from the doors of our new whirlpool refrigerator. What is the trick?
  • Gerre May 11, 2009
    Not easy. but what we had to do!
  • 69 Answers
SLOW AND STEADY ....and if it runs under the handles you will need a phillips screw driver Im guessin...
Posted on May 10, 2009
How to remove cover of fridge light to replace bulb
generally there is a Philips screw at the edge of the plastic cover,or sometimes you can squeeze or press in the sides of the cover.Check the make & model and go in line to the company,They usually will have a manual where you can find out the answer.Best of luck.
May 23, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do you get inside the freezer door of a whirlpool gold gs6nbexrl00 to remove the ice dispenser motor?
  • Underneath one of the door shelves is a plastic place secured by screws. Remove the screws and you will see the motor covering.
Jun 03, 2010 | Whirlpool Refrigerators
Need to temporarily move our Whirlpool Gold refrigerator to replace kitchen floor. How do we remove fridge doors so we can get it through the doorway?
Usually, there are bolts/screws on the hinges. They may be covered with a plastic cap which will snap off. Start with the freezer door. While supporting the door, remove the screws from the hinge and lift to free the door. Now you should have access to the hinge supporting the refrigerator door. Same procedure for refrigerator door. Keep the screws in a safe place so you can reassemble the refrigerator when the kitchen floor is done.
Jan 30, 2010 | Refrigerators
Refrigerator side lights quit working bulbs are new
your control board in the lower rear of the unit is defective,a tell-tale sign of this sometimes is, if you can hear a buzzing/chattering sound and the refrigerator lights strobe dimly and the temp set and read-out in the refrigerator is not lit,the control board is located after you remove the rear lower cover on the back side of the unit and on the left inside wall you will see it in a plastic box,remove the screws that secure the box and then remove plastic top cover and there will be 3 wiring harnesses,unplug them,replace the control board and reverse procedure to reinstall
Jan 08, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How to disassemble doors
on the top of the Refrigerator, there is a hinges on both side covered by a plastic cover, take out the cover by fliping it and you will see the bolts on it, remove it one at a time, try to support the door so that it will not fall out. after romoving all the bolts, you can take out the hinges then full up the door slowly. This method is for removing the door from the body
If you would like to remove the plastic trays of the door, you see the rubber magnet around the side of the door, underneath that magnet are screws for attching the tray to the door, remove it all to detach the tray from the door
Nov 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do you remove the face plate the is on the
Remove the top hinge cover , covering the top freezer door hinge , and unplug the visible receptical . This removes power to the dispensor and dorr . Using a butter knife between the grill and the dispensor bottom cover , push down and inward , prying the cover outward . Do this on both sides , about 1 " from each side . This pops the plastic clips off . Raise the cover to release from the upper plastic retainers . Disconnect the plug from the cover and its removed . Do this carefully , because your working with plastic . To reinstall , reconnect the plug to the dispensor cover , slide the top in place and pop the lower tabs back into place . Reinstall the top hinge plug and cover .
Aug 29, 2009 | Whirlpool Refrigerators
How do I replac the clear plastic cover over the ice shute on the
order the chute assy old pull out and down holding the lever as to not break it other snaps in reverse order
Aug 19, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Ice won't dispense, suspect switch in door cover. how to remove door cover to check? Oddly enough, my ice maker stopped working AND the switch in the door (or other circuit problem for dispensing) failed...
Insert a small putty knife between the dispensor plate and the dispensor cover about 1-2 inches from the sides and press down and inwards . Do this carefully because there are 2 plastic "clips" at the bottom . Once bottom is free , lift upwards and the cover will come off . Remove the plug and it's free . There is a white contraption , large , that have 2 rods the micro switches clip onto and sometimes , the switch on the left , has the broken rod holding the micro switch . This causes no ice dispensing .
Aug 15, 2009 | Whirlpool ED2GHEXN Side by Side...
Removing front cover to fix non-closing dispenser door
If your talking about the disp/foutain cover for the ice door chute not closeing problem heres how its done.
1 That cover is plastic and plastic flexs.
2 There should be two notches in the bottom area of cover. Insert flattip screwdriver in either one and pry out towards you. Bottom should pop off and top then slides up of tabs in door.
you can also try pushing down on top of disp cover when prying at bottom or pressing down really hard on fountain cover till part sortof flexs/slides down a milimetter and pulling towards you. The pressing down and pulling is down at bottom of cover inside disping area.
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
Refridgerator door handle
The entire handle slides upward and out to detach from the door. There are two screws attached to the handle which can be tightened once the handle is off. Those screw heads are what reattach the handle to the door by sliding them through the door bracket opening, where they follow a short channel down leaving the handle secured again.
Dec 30, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
186 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
