Print server won't speak to printer
Hi Experts,
I have a DP-G301 ethernet print server. The setup is on Vista and the print server is connected into a Fuji Xerox DocuPrint 3055 (the printer name on the system is FX78BF46). When I did the installation for the print server, I had to run it as administrator so that Vister would install the print server. There may have been some setting that I missed in the installation, but the print server will not communicate with the printer. The printer works fine if I hard wire it to the wireless router, and I can access its web page and print. I can also access the web page for the print server both hard wired and wireless. But I can't see the printer through the print server and nor will it print. Is this a Vister problem, or do you have a solution to my dilema?
I look forward to your response at your convenience.
Looking for answers.
I'm having much the same problem with my IOGear print server and my Vista ntebook.  I have 2 printers USB connected to my print server, and the print server ethernet connected to my router.   If I ethernet connect my notebook everything is just fine, but as soon as I go wireless my IOGear print server software does not see the server.  Vista continues to see it and I can connect to it for admin purposes using its IP address through Internet Explorer.  Solve Mac's problem and you'll probably solve mine as well.
Posted on Oct 24, 2007
    Problem Solver:
  • 6 Answers
If I am correct, you are connecting the print server to the Xerox with a parallel cable.  If so, you are printing two different ways when you connect with an ethernet cable.  When you connect the printer with an ethernet cable you are probably printing TCP\IP to the IP Address of the NIC Card (in the printer).  When you connect with a print server, the print servers IP Address becomes the one you would use as the port for the printer object in Windows Printers & Faxes.
Posted on Oct 12, 2007
I am using DP-301U print server and wanting to attach with hp 1020 plus. However the printer in not printing. what is the root cause and give the solution please...
Hello and welcome to fixya.
First off, I would like to provide you a link with the print server's manual to download it directly and have it as spare.
The printer you are trying to install is a laser printer (black/white only) and probably a bit old model.
Therefore, if you are trying to print from your computer over ethernet, and you have windows vista or 7 (64 or 32bit accordingly) you might have the inappropriate drivers for either the print server or the printer. You can find all of the HP printer's drivers HERE. Select carefully based on your OS.
As a SIDENOTE: If you just need the drivers installed and there are only larger setup execut. files available, you can use 7zip or winace to open up the *.exe file and navigate to the appropriate folder and extract only that one to your computer and install the driver(s) from there.
The D-Link DP-301U print server drivers are available HERE. Default username and password for the management console of the print server can be found at pdf manual page 25. The url to access the administration console is dlink-******,where the asterisks stand for the last 6 digits of the print server MAC address.
Overall, not to make things over-complicated (150+ PDF user manual pages) you need to do the following:
1. Install the appropriate drivers of your hp printer on the computer that will have also print serv. softare installed.
2. Install the appropriate software/drivers of the dlink print server on the same computer.
3. Plugin the usb cable of your printer to the print server's USB port.
4. Plugin the ethernet cable of your print server port to the ethernet port of your home router/switch.
5. Setup Fixed IP settings for your print server configuration (page 20 on the manual).
Let me know how that went. I believe you will manage to do it that way quite easily.
**Don't Forget to vote how helpful this was.**
Regards from
Apr 22, 2011 | D-Link DP 301U (DP-301U) Print Server
I have a used d-link dp-g301 print server and would like to reset it to factory condition, reset the ip address
You can download instructions for D-Link DP-G301 from link below:
From Internet Explorer type to following to access D-Link configuration page:
Then follow steps below to reset Print Server
Click Apply to
immediately reset
the print server.
Factory Reset
Click Apply to
reload the factory
settings of the print
Dec 02, 2009 | D-Link AirPlus G DP-G301 (DPG301) Print...
- Kindly visit this web site for instructions:
Mar 12, 2009 | D-Link DP-301U (790069251979) Print Server
Update the firmware of your Print Server.
Mar 04, 2009 | D-Link AirPlus G DP-G301 (DPG301) Print...
D-Link DP 301U Print Server not continuous print from vista
Make sure you have byte counting enabled if you are printing through LPR.
Dec 11, 2008 | D-Link DP 301U (DP-301U) Print Server
DP-300U revB and KONICA MINOLTA bizhub 163
I have just setup DP-300U rev.B1 with my Konica Minolta Bizhub 162, the thing is that it doesn't work with USB port connected (paper out), then I tried connecting Bizhub 162 to LPT port, and it works just fine...
Jul 17, 2008 | D-Link DP 300U (DP-300U) Print Server
DP-301P+ Express EtherNetworkTM Fast Ethernet Print Server
You need to connect to it (using the broswer at the PC of same LAN with the current ip of the print server). Then click on Tools TAB, click on "Reset" at left. You should see "Do you want to restore this device to factory default setting?". Click on "Apply"
Jun 04, 2008 | D-Link DP 301P (DP-301P) Print Server
Linksys WPS54G
Hi Scott.
Make sure your firewall is set on the Vista to allow the network discovery. Follow this link, click on Networking>File and printer sharing. It will tell you how to setup Vista to work with printer
This link should help, too. It is just for your Printe server.
Good Luck!
Jan 05, 2008 | D-Link DP 300U (DP-300U) Print Server
The network connection for the printer has gone
You can get setup guides and download firmware from the following link: Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 11, 2007 | D-Link DP-301U (790069251979) Print Server
Computers & Internet Logo
1,474 people viewed this question
David Payne
David Payne
