Question about Hotpoint Aquarius WF000 Front Load Washer
Fitting a new drive belt to a hotpoint aquarius
Belt is the same number as the one that broke but appears to be too small
  • Hotpoint Master
  • 3,463 Answers
Remove lower rear panel, tilt washer forward, getting someone to help, and fit belt round motor pulley, then fit belt round drum pulley, slowly turning the drum pulley round as you feed the belt on, it is very tight, and you might think the belt is to small, but this is normal, as the belt stretches, just persist, but be careful you do not trap your fingers. Good luck.
Please rate my solution.
TRhanks.
Posted on May 13, 2009
How to fit a belt to a hotpoint aquarius when the back cannot be removed
If there is a small inspection panel at the back where you can get to the motor remove that then remove the top lid of the machine. Loosen motor mounts and swing motor up and remove belt from motor. Now remove belt from pulley from the top of machine. Reverse the order starting from the top to replace belt.
Jan 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How do to put the belt on the washer
Remove top cover, and rear lower panel
Tilt washer forwards, and get someone to hold it for you.
Fit belt round motor pulley first, and slowly feed the the belt round the drum pulley, it will be very tight, so watch your fingers, it may appear to be to small, but that is the way they are, as the belt is a stretch belt.
Thanks.
Oct 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA32 - belt slipping off?
Probably it wasn't fitted properly. make sure the belt is tight when fitted, and at least 2 groves from either side at the motor shaft.
Jul 25, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Drive belt came off Hotpoint Aquarius WT540
At each side of the lid there is a small plastic cover. Remove these then take out the screws. Lift the lid at the front and push it back then lift off.
Thankyou for using Fixya.
Jan 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Need to replace drive belt on hotpoint wf430 but to tight to get
Put it on the motor spindle first then feed it onto pulley. It is tricky with such limited access.
Hope this helps &thanks for using Fixya.
Jan 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I think the belt has snapped
It is rather tricky to fit new belt.
Briefly, remove top cover, remove right hand side panel, there are screws at the back and bottom front, remove any other scews that you can see that hold the panel in place..
The front panel has to be pulled forward to enable the new belt to be fitted. You might have to loosen left hand panel as well to do this.
Fit the belt round the drum and force it over and round the motor pulley
This is a very difficult job, as the belt is a stretch belt
and appears to be too small, so you will really struggle to fit it, you will probably find it helps if you can lever it on with a screwdriver or similar.
Again, it is a difficult job to undertake, so unless you are confident you can do it, get some one in to fix it for you.
Plz rate my solution.
Thanks.
Jan 19, 2009 | Hotpoint Aquarius WD640 Front Load...
The belt in my washing machine just broke
Try this number; 0818 313413
This is Hotpont service in Dublin.
Plz rate my soution.
Thanks.
Jan 14, 2009 | Hotpoint Aquarius WF000 Front Load Washer
I am trying to fit a new drum belt on a hotpoint aquarius vtdoo reverse action
You need to remove the top cover, remove the right hand side panel,ease the drum forward and fit the new belt.
It is very difficult to fit the new belt without the proper tool avialable from Hotpoint.
It can be done without the tool, but be prepared to stuggle
Dec 04, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint aquarius 1300
it takes a fitting stap to fit but can be put back on by hand little tricky but can be done no probs
Mar 01, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WF000 Front Load Washer Logo
453 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
