Question about Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro screen not coming on
Charger for maestro not working trying to send juice thru usb but maestro will not come on
    President:
  • 1,111 Answers
If you have a 3100 or 3140 as you have pictured..they cant be charged via USB..you need a home or car charger
Posted on Jun 15, 2009
How to do a hard reset on Magellan 4250; every time I plug into 12V the monitor shows I'm connected USB? Map won't come up without unplugging and battery only last less then an hour.
I do not have the solution to this problem, I am having same problem. Bought a universal 12v charger and I get a screen with check PC for USB connection. Will not go to blue information screen.
Dec 07, 2010 | Magellan Maestro 4250 GPS
My boyfriend has this gps and it froze up on him around the time that the clocks went back what can I do
Try sending it back to Magellan or go to Magellans Website www.magellan.com and download their updates. You will first need to download Magellans software - then hook your gps to the pc with the usb cord.
One other thing - try a wall charger for 48 hours. I have seen this work.
Jun 12, 2010 | Magellan Maestro 5310 Car GPS Receiver
Will not charge thru the USB or the car charger. Is the battery replaceable?
a magellan 4040 can not charge through the USB port and if it wont charge with a known good car or home charger, then read below.
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Jan 18, 2010 | Magellan Maestro 4040 GPS Receiver
Have a 4040 maestro magellan will not get off the magellan screen
if this just happened, and you have not tried to update it (sometimes the update causes this) then power the 4040 on and once it finished loading to the blue screen, using a paper clip, depress the reset switch on the left side and let it restart (little pinhole on the left side under the usb port)
if you need further help, just reply to this post.
bill
Jan 03, 2010 | Magellan Maestro 4040 GPS Receiver
Unit will turn on only after holding down the power button. The magellan screen is displayed, and a load bar zips across underneath that, then it just turns back off. Is there a reset button that might...
Charging plug is broken off of the printed circuit board. Battery is extremely low on juice, so it won't fully turn on. Once I get home I plan on splicing the charger into the battery wiring directly to see if that will work. This is the second magellan I've had...the other one did the same thing. I'm guessing that it's the same problem. Haven't dropped either one of them...other than they like to fall off of the windshield (suction cup). Seems like they need to come up with a new design (for the circuit board).
Oct 22, 2009 | Magellan Maestro 3200 GPS
Charge Problem
Hello guitarman249,
It sounds like a bad battery. Theoretically, it could be the charger but if the red light on the charger still comes on when the unit is plugged in then the battery is the more likely culprit. The only way to really know for sure is to try charging the unit with a different cable, such as the USB cord used to connect the GPS to a computer. The GPS should charge when connected to USB. If it doesn't, then it's the battery.
Like most GPS receivers, the battery on this one is not replaceable by the user. If you do determine that the battery is causing the problem you will need to contact Magellan tech support to arrange a battery replacement.
Best Regards,
Ken
"Go Ahead. Use Us."
Jun 02, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4010
yes ,
but design some external cicuit for voltage control system as pda needs,
but ,irts possible,
THNX
May 16, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan maestro 4250
I have owned the Magellan Maestro 4250 for 6 months and the black cloudy spots just surfaced.  After talking to the Techs at Magellan (800) 707-9971, they advised me to send it into the factory for repairs.  Hopefully the one year warranty covers it.
Apr 15, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan MAESTRO 3100 98083401 GPS Device Logo
290 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
