Question about NetGear DG834G Router
Want to return O2 Router and use netgear Router
I have a netgear Router which was used for sky broadband how do I connect it to O2 broadband
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Jun 01, 2009
Sky anytime+
Call Sky - the guys on the help line have a code which takes you to an advanced menu where your broadband can be setup properly for your router. It sounds as though the box and router are conflicting - happened to me :'
Apr 30, 2012 | NetGear DGN2000-100NAS Router
Does the netgear dg834g work with sky broadband
Thats an ADSL modem/router, so would be used via the telephone line In fact this is the standard router often supplied by SKY DG834GT
theres a number of answers here on the sky site for setting up a router http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=25126ec2-287b-4e70-9014-967423a8dbf1
sky users tutorial for setting up a router http://www.skyuser.co.uk/forum/view-router.html
Mar 19, 2010 | NetGear DG834G Router
Hiya could you tell me how i can put a password on my wireless conection (it is netgear and i use sky broadband,) so only people in my house can log onto my broadband
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Dec 10, 2009 | NetGear DG834G Router
Sky netgear router
add your previus setting in your netgear router
fist you have contect with your pc and config and fist resert the all current seting
Mar 31, 2009 | NetGear RangeMax Dual-Band Wireless-N...
Wireless connection
i can't connect wireless int
Feb 01, 2009 | NetGear DG834G Router
Low signal from my wireless adaptor / router
Have you tried connecting the laptop in a different wireless network? Try changing the channel in your router and you may also upgrade the firmware of your router.
Oct 04, 2008 | NetGear WGR614 Wireless Router
I have recently aquired a router and a Wireless PCI Card. Although I am automatically on the internet when I boot up my Computer,I keep getting a message on screen that I have limited or no conectivity....
the limited connectivity means that your router is not connected wirelessly probably because you have not entered the correct passkey, or it's still giving your lan RJ45 network cable the ip address and this is why you are still connected to the net.
If you are on a Netgear modem/router as i suppose you are if it's from sky, you should connect the RJ11 phone line cable into the router leading to a broadband filter, then connect the filter to your phone socket.
There should be no wires between your pc and the router, so take out the wire that is connected to the router (RJ45), which you should have used to set the router up coming from your onboard wired network card.
You will now be connected only via wireless connection, right click on the wireless network icon in your taskbar, click show all connections and then click on your SKY****, whatever it is and then you will need to enter the WPA-PSK security passkey which is with your Sky paperwork or on the router itself.
Sep 10, 2008 | Computers & Internet
NetGear DG834G Router Logo
299 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
