My cell is black motrola L6.the problem is that the phone does'nt alert for incoming calls alarms etc....But there is no problem with theb speakers i can hear the ring tones and all. i have done what i can with the settings available for me pls reply mto me emmidietly pls.
sms alert is by a feature used by your profile .. do you have it in meeting ? General ? etc; ... usually if your phone plays music or rings when someone is calling you should get a sms tone however sometimes this feature is disabled user error possible? check your manual
menu 2 settings 3 tones incoming call alert (set to ringing) ringing tone ( pick your ring tone) ringing volume (set to level 5 loudest) vibrating alert (on) message alert tone (pick tone) instant message alert tone (standard) keypad tones (on) warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok alert for (all calls)
To Do, Alarm and Incoming Messages give a single audio alert but to not display on the screen. The Snooze function does not work although it is selected. Missed calls do not display
Go to : SETTINGS then FACTORY SETTINGS.. security code: just type 12345.
If still there is no tone alert, then im sure there is a problem with your phone's buzzer, or it might need to clean the contact of the buzzer insice the board. Just try this....
Sound settings
Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
• Alert type: specify how you are to be informed of
incoming calls.
• Ring tone: select a ringtone for the call ringer.
• Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
messages.
Menu functions
• Tone: select one of several message tones.
• Alert type: specify how you are informed when a
message comes in.
• Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
phone.
• Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
• Connection tone: set the phone to beep when an
outgoing call is connected to the system.
• Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
• Indicative tone: set the phone to beep when a
pop-up window displays.
You can change the settings of the selected active profile.
Select Menu > Settings > Tones > Incoming call alert, Ringing tone,
Ringing volume, Vibrating alert, Push to talk settings, Message alert
tone, Instant msg. alert tone, Keypad tones, or Warning tones. You can
find the same settings in the Profiles menu.
