LCD TV automatically turn off and on
I bought a Sony Bravia KDL46X2000 LCD TV in Sept 2006. Since May this year, the tv will switch off & on automatically while it is on. Normally, it happens more frequent if the tv is on for long hour. For example, if the tv is on for three hours, it may happen four or five times in between. The Sony authorized repairer already changed the tuner for two times, the problem is still existed. I just wondering if the problem is with the power supply ?
  • 1 more comment
  • jbarela Nov 24, 2007
    I have a Sony KDL-V2500 HDTV that randomly turns off and back on in just a matter of seconds.
  • KDL46X Jul 09, 2008
    Same problem with a KDL46X2000 no fix so far - replace digital tuner twice.
  • warpcore01 Mar 06, 2009
    My Sony KDL-46X2000 turns off then back on by itself also. Purchased 05/2007. Can happen after 1hr or 6hrs of being on and luckly very infrequent. Might do it twice in one month or as little as once in three months and it barely takes a second or two to do the on/off cycle. Thought it might be RF interferance but have moved house and it still does it. Techo's have had if for three wks now but ofcourse cant find anything wrong. Oh, and losses the HDMI 1080p vid/sound feed occasionally for a second or two from both a BD player and PS3, but not my DVD players 720p or 1080i feed. Chord Co.SilverPlus cable used(& others) so its not that.
    Top Expert:
  • Televison & ... Master
  • 30,035 Answers
It is likely to be capacitors in the power supply.
Posted on Jun 09, 2017
SOURCE:
techman
  • 3130 Answers
SOURCE: Protron PLTV-32CM LCD no picture
This TV set is still under the warranty and it seems proton has no local service available to you. I know its to late to tell you this but anytime you purchase a set, ask first and see if there is a service local to you. Ok enough of that noise.. I would go back to the store where it was purchaced and ask them if they know of any local shops that handle the warranty repairs.. If you want to pay for the repair, and that will most likly be alot for a flat panel set, You will have to call back proton and ask about the shipping cost and whos responsible for that.
Posted on Sep 30, 2006
  • 87 Answers
SOURCE: Vizio GV42L LCD TV screen black when turn TV on first time
If you are using a set top box this might be caused by turnig the box on at the same tie as you turn the tv on or slightly after you turn the tv on.  If you are using compnent or HDMI inputs the set needs to see the signal as it is turned on to know what formt the signal is in.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 23, 2007
welcomejee
  • 10594 Answers
SOURCE: Sony KDL40S2010 Bravia LCD TV... turns off / on on it's own
If TV does not remain in standby and turns on itself then power switch on top of it could be defective and power supply board is also suspected. Take off its back cover and unplug top switch connector just to confirm is that cause of On-Off its own. If problem still exist then power supply board has problem and will be replaced. Let me know the results to move forward.
Posted on Jun 13, 2009
  • 47 Answers
SOURCE: My Sony Bravia turns itself off Stand by red light blinks twice.
If you bought it brand new from a dealer, I would take it back or have them come out and look at it. Less than a month old, it is still under the 1 year MFG warranty or the very best a 30 day one.
Posted on Jun 22, 2009
  • 73 Answers
SOURCE: My brand new 40
This is a characteristic of the dynamic backlight used on this set.Turn off the dynamic contrast in the customer menu this should solve your problem.
Posted on Oct 15, 2009
I have a SONY 52"
don't worry, clean LCD panel connector (rub with pencil eraser)
Aug 21, 2011 | Sony Bravia KDL-32V4000 32 in. LCD TV
I have Sony Bravia X Series 46" Full HD. The Picture froze during a TV show last night. After that it says it cant pick up anything from any channell. It works if you just play DVD's. I've tried...
you will have to check the terms of the warranty, you might have to bring it to where you bought it. Also, if its to expensive, for the age of the unit, you might end up with a new tv.
Mar 13, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Have a 2006 Sony LCD Bravia 46" TV. Receipt from
I don't know the relationship that Cosco has with their customers however the best way to get the CORRECT model number is directly off of the back of the TV. The model number you have is not complete. It should have something like a "KVR" or at least something beginning with a K.
Hope this helps,
Best Regards,
Mark
Jan 26, 2011 | Sony Televison & Video
I purchased an Sony Bravia LCD 26 inch of KLV S200A series 3 years back. The LCD has now started developing problems like automatically the power goes off when any particular channel is being viewed and...
You have intermitant problems which may be caused by contact resistance or circuit overheating.After it cooled down the tv starts again. Leave TV on standby at all times.
Jan 03, 2011 | Sony BRAVIA KLV26S200 26 in. LCD TV
BRAVIA KLV-37U300A 37 in. LCD TV: I have a HDMI cable attached to my Sony Bravia and...
t con is not working is t con is repairbale or can i get ic becouse here in pakistan is not available.
May 17, 2010 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
Sony Bravia KDL-32V2000 LCD TV switching off and on by itself
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Apr 29, 2017 | Sony Televison & Video
My SOny Bravia 40 inch LCD TV has a vertical line
It could be 1 of 4 things:
1. One of the ribbon cables has worked itself loose (Simple Fix)
2. One of the assembly boards maybe faulty
3. The driver board which feeds the panel maybe faulty
4. The panel is faulty
The driver board in the UK costs approx £70 and approx £35-70 to fit it if this is the fault.
All other parts are between £80-160 and approx £35-70 to fit it if this is the fault.
The panel will cost approx 50-75% of what the TV was worth when you bought it - "Repair versus Replacement"
Thanks
Oct 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Jun 22, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Jun 13, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony Bravia 32 inch HD LCD tv has vertical lines going down 2/3 of screen. No idea what problem is. Tv is less than a year old, but I have lost the receipt. Anyone had this problem or know what may be...
We had a similar issue although our Sony Bravia was 21 months old. We were told by an engineer that the panel has failed and that the cost of replacing it would be about 900. We were also told that this is a very common fault and that the "normal" failure time was within 18mths to 3 years. If you registered your TV purchase with Sony, it might be worth contacting them with the serial number to see if you could get it repaired under guarantee. We have now bought a TV with a 5 year guarantee!!! (not a Sony!!!!)
May 04, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Televison & Video Logo
246 people viewed this question
Top Televison & Video Experts
Ekse
