Question about Cuisinart CMW-100 Microwave Oven
Microwave won't heat or turn cuisinart cmw-100
Clock is on, timer comes on, turntable won't turn, will not heat
  • 52 Answers
SOURCE: Cuisinart Microwave won't heat food
open the casing and replace the blown fuse.there are several so check them all. probably why the machine was in the auction
Posted on Feb 21, 2009
SOURCE: Cuisinart CMW-100 , wont heat or turn the table? all else o.k.
We changed the 20amp fuse and that was not the problem so we returned it to Macy's. If anyone knows of a reliable brand of microwave today please let us know. All the reviews on microwave ovens recently are bad.
Posted on Jul 31, 2009
SOURCE: Our cuisinart cmw-100 still has the power sources
Bad door switch, usually the top one. The switch costs < $2.00.
Posted on Sep 14, 2010
  • 8909 Answers
SOURCE: cuisinart microwave cmw-100 opening of
Check the door interlock switches.
Posted on Feb 12, 2011
KevinWhite
  • 1902 Answers
SOURCE: I need to find the
Hello & Welcome to FixYa
You can buy the motor from here or from here. Please get back to me if you have any other questions.
Kevin
Posted on May 28, 2011
I have a Cuisinart cmw-100 microwave everything works except for the turntable. any suggestions?
Order a new turntable motor. Turn the microwave upside down and you can see the little door in the center where you can install it. Pretty easy, really.
Apr 18, 2017 | Cuisinart Microwave Ovens
Why won't the microwave turntable won't turn?
This problem is very common.
The turntable motor is defect or its gear mechanism worn out.
You'll need to have the turntable motor unit replaced.
May 11, 2014 | Cuisinart CMW-200 Convection/Microwave...
Just purchased our Cuisinart Stainless Microwave, plugged it in, read the operational instructions and set the clock. As a test, we tried to heat water....does not work. Any suggestions?
Yes! Take it right back to the store for exchange, cause could be a bad magnetron "that heats food" and a couple parts that work together with the magnetron,or there may be issues with the keypad, none of these will be cheap to fix.
Jan 30, 2011 | Cuisinart CMW-100 Microwave Oven
Microwave lights up, timer works. No fan, no turning of turntable, no sound.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 14, 2011 | Cuisinart CMW-100 Microwave Oven
I have a CMW-100 microwave. The turntable has intermittently stopped spinning. Now, it has stopped spinning entirely. Is there a part I need to replace to fix this problem? Judie Snivley
Sounds like the turntable motor has stopped working.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Dec 15, 2010 | Cuisinart CMW-100 Microwave Oven
I have the CWM 100 - the microwave is only about 1-1/2 years old. It runs, but the glass turntable no longer turns. No matter what we've tried, removing the glass plate, cleaning the wheels of the...
Check to make sure the Spindle that the plastic piece fits on is turning when the oven is on.
If the spindle turns, your problem is either the plastic wheel adapter is worn or not making proper contact with the spindle. You can replace th e adapter by going to Cuisinart.com.
If the Spindle is not turning, you can go to Cuisinart.com and find the nearest repair facility.
Nov 20, 2010 | Cuisinart CMW-100 Microwave Oven
Jul 30, 2009 | Cuisinart CMW-100 Microwave Oven
Feb 05, 2009 | Cuisinart CWM-100 Microwave Oven
Cuisinart CMW-100 Microwave Oven Logo
527 people viewed this question
Top Cuisinart Microwave Ovens Experts
William Miller
William Miller
ray gallant
Are you a Cuisinart Microwave Oven Expert? Answer questions, earn points and help others
