Question about Olympus FE-170 Digital Camera
Red Flash mark while taking photo
I am using Olympus FE-170 Camera. When i am taking photo with flash it is not taking. One red flash symbol appers in screen. When i am taking photos without flash it is working preperly. I am using fully charged AA batterys Sony 1700
Please advise me.
samy
samycbe@yahoo.com
  • 26 Answers
It sounds to me like you are not waiting for the camera to charge the flash when turning the camera on or between shots. It seems you are using 1700mAh batteries and most modern digital cameras are better off using 2500mAh batteries. Your camera was released in September 2006 so it is considered "modern". With 1700mAh batteries, your flash (warm-up) recycle time time will be rather long or the amperage may not be enough to fully charge the flash unit. I highly recommend Duracell 2500mAh rechargeable batteries.
Posted on Oct 12, 2007
I have a Olympus FE-100. Everything works fine but it will not flash. Blinking red light. Blinking red lightening bolt. I have tried everything.
hi
blinking red light means camera is trying to charge flash circuitry. if you cancel flash mode, you can use taking picture. But if you want to repair, your local repair shop would charge around $35 to 75 depend on what they really want to charge.
Thanks and best regard!
May 23, 2011 | Cameras
The flash does not work even if the flash setting is SET to FILL ( the flash will work every time the camera is in used) I already tried to reset the settings to default but still the flash wont...
Does the camera indicate that the flash is turned on? In most olympus cameras I have seen there is a lightning blot at the lower left corner of the screen. Verify that it is indeed there and let me know.
Aug 18, 2010 | Olympus FE-170 Digital Camera
How do u turn off the flash on the olympus fe-170? im going to a clapton concert tonite and i need the flash to be set to off i tried everything and i cant turn it off....please help!...thanks!
Press Right-arrow (marked with the lightning bolt) repeatedly to select the flash mode. In this case, you want the lightning bolt inside a circle with a slash through it, indicating "no flash".
After the concert, don't forget to set it back to Auto, or the flash will never fire again :-)
Feb 25, 2010 | Olympus FE-170 Digital Camera
Pictures that I take come out very white/bright. you cannot tell details. I have changed batteries and have the setting on auto.
Double-check your flash settings. You mentioned the camera is in Auto mode, but the flash has separate settings from the camera's shooting mode. With the camera in shooting mode AUTO check the Flash settings (Auto, Red-Eye Reduction, Fill-In, Off) It may be set to 'fill' causing your photos to be too bright.
Also, depending on how close you are to your subject the flash may not be needed. Using the flash when too close to your subject (less then 3 ft.) will cause bright/white photos. Turn the flash OFF if you are taking macro or photos closer then 3ft.
If neither of these fix your problem, turn the flash mode OFF, and camera shooting mode to AUTO and in a naturally well lit area, take a photo, if the photo is still too bright, you may have something mechanically wrong with your camera.
Nov 03, 2009 | Olympus FE-210 Digital Camera
My Olympus FE-170 won't connect to my PC
Hi there
Possibly not, try another camera lead in a different USB port.
If its the same format the camera card and try again, if you still get the same result, the camera is faulty.
Good luck and thanks for using Fixya!!
Feb 13, 2009 | Olympus FE-170 Digital Camera
Olympus sp 350
There is a "quick" button located on the back of the camera just for flashes. It is the first button to the right of the power button and it looks like a crooked lightning bolt arrow that points down. If you are in any picture taking mode, push this button and it will toggle you through each flash option, auto, red eye (eyeball symbol), flash (same symbol as the button, this mode will make the flash work everytime you take a picture), red eye and flash, and no flash (careful, in this mode you have to allow for the camera to focus, the lens will stay open a long time in a dark atmosphere -- if you don't hold the camera still you will get a blurry picture).
Apr 09, 2008 | Olympus SP-350 Digital Camera
Flash issues
It means that the battery is charging the flash! Wait a while and it should stop. Then take your photo.
Do make sure your battery is fully charged.
Apr 05, 2008 | Olympus FE-220 Digital Camera
Red eye
Open your camera as if you were going to take a photo, if you look at the 4 arrows, you'll see one next to it with a lightening bolt next to it. If you press it twice a little symbol should come up which looks like an eye and this is the setting to get rid of 'red-eye'. This button controls the falsh, click it once for auto, twice for red eye, 3 times for flash on and 4 times for flash off :) Hope that helps
Jan 26, 2008 | Olympus Camedia C-350 Digital Camera
Olympus FE-170 Digital Camera Logo
114 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
