Question about HP Photosmart R707 Digital Camera
No power after dropping it accidentally...
My brother drop My photosmart r707 accidentally and afterward when i press the switch button it doesn't power on.... even when i changed it, it doesnt have power at all please help me ....
Try pushing the reset button by the battery slot, use a paper clip and hold for 5 seconds without the battery in it. good luck
Posted on Jul 18, 2009
Where is the reset switch?
To perform a firmware reset on the HP Photosmart R707 digital camera, open the battery/flash_memory door, and remove the battery and SD flash_memory card. With the front of the camera toward yourself, and upside down, look for a tiny screw next to the battery clasp (holds the battery in place). About 1/4" (6.0mm) to the right of that screw is a tiny hole with a reset button inside it. Gently push a paper clip into it. Some people may feel a very slight click. Hold the reset button for 6 seconds. Place the battery back into the camera, but not the SD card. Power on the camera. Exit the date/time menu. Power off the camera. Place the SD card in the camera. Power on the camera. The firmware is now reset.
May 29, 2012 | HP Photosmart R707 Digital Camera
The HP Photosmart R707 Viewfinder video light keeps blinking in red even when the Camera is switched off.
If you actually mean the power light, that is supposed to blink when you plug it in and it is charging.
If you mean the one in the viewfinder, that is an error condition, and an error message is supposed to show up in the back image display viewer.
There may not be enough battery voltage left to display, so plug it into the AC adapter to be sure.
Aug 14, 2010 | HP Photosmart R707 Digital Camera
My computer can't detect my hp r707 camera. It
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 15, 2010 | HP Photosmart R707 Digital Camera
Menu OK button and zoom controls are not working.
Remove the battery and press the reset switch for about 5 seconds. Reinsert the battery.
Jan 28, 2010 | HP Photosmart R707 Digital Camera
I have a HP camera, when i turn on the camera the lens want come out.
Try to run self-diagnostics tests - press flash button while switching the camera on.
Jan 17, 2010 | HP Photosmart R707 Digital Camera
Having trouble with the flash on my R707
You need to be more specific. Try to run self-diagnostics tests - press flash button while switching the camera on. One of those tests checks the flash.
Dec 14, 2009 | HP Photosmart R707 Digital Camera
The camera turns on and takes pictures but the flash doesn't work. I saw the number 403 on the screen when I was trying to figure out the problem.
Try to run self-diagnostics tests - press flash button while switching on the camera. One of the tests verifies the flash functionality.
Oct 25, 2009 | HP Photosmart R707 Digital Camera
Hello, please could you help me with my problem? I have damaged camera R707. After putting battery, is permanently light up red diode and nothing happend.Is not possible do power on...And after pressing...
Please follow these instructions to do a power reset of your camera. If they do not work, follow these instructions to manually press the reset switch. Also be aware that an online user's manual is available by clicking here., and includes a troubleshooting appendix and support numbers for HP.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 29, 2009 | HP Photosmart R707 Digital Camera
Memory card
To transfer the photos, connect directly SD card to your PC through a card reader.
Try to reset your HP R707 camera: remove the battery and press the reset switch for about 5 seconds. Reinsert the battery.
Mar 26, 2009 | HP Photosmart R707 Digital Camera
R707 wont power up
when you put your battery in,, also put the power on the camera so your adaper on the net, and the end of it in the little hole next to the usb port,,, then try to turn your camera on,, this could help,, i had a similar problem and accidentally i tried to recharge it while the battery was still in the camera and it helped,, i hope i helped ya,,
Aug 07, 2008 | HP Photosmart R707 Digital Camera
HP Photosmart R707 Digital Camera Logo
129 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
