Question about Sony KV-32FS12 32" TV
Sony kv-32sf12 -will not power "ON
HI! I would greatefully apreciate any help,with a Sony KV-32SF12. After the initial click when the TV is turned on, I hear 4 or 5 more clicks and then nothing. Sounds like something is repeatedly trying to start up but can't get going.Then will blink:4 times-pause-4 times-pause,and so on. If I can get help troubleshooting this & I'd like to repair it myself. Thanks so much!
  • steliansteel May 10, 2009
    fougski-thank for your help ,I am going to check the ic502 and see what 's going on.
  • 700 Answers
Try the 60 seconds unplugging of wall plug in your outlet. Or check your line if this have surge protector. Temporary plug your unit to wall outlet directly. Just check if it still within voltage operating range.
Posted on May 10, 2009
  • fougzki May 10, 2009
    Ok as per manual I see of kv-32fs12
    Detected symptoms
    1. Has entered standby state after horizontal raster
    2.Vertical deflection is stop
    3. power line is shorted or power supply is stopped
    probable cause location
    1. +13V is not supplied (A board)
    2. IC502 is faulty(A board)
    this is for the kv-32fs12 4 blink
    Or see this link for comparison
    http://www.scribd.com/doc/5889172/Sony-K...
    Hope this help.
The "Initial Setup" screen pops up and starts
replace your tac switches maybe one of the switch are defective.
Dec 22, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Suddenly, "No Signal" display when cable box/VCR Connected to UHF/VHF Jack
How long have you owned the tv? You have two options though your best bet is to locate your nearest authorized service center to have the tv repaired.
Thanks,
lee
Sep 14, 2008 | Sony KV-27FS13 27" TV
Sony Wega KV-34HS510 standby blinks 7 times in red
Hi and welcome to the site,
Initially, the Sony KV-34HS510 uses the DA-4 Chassis. On this chassis, 7 blinks refers to the fault "Horizontal Deflection Stopped" indicating a problem with the horizontal section. Offhand, check, replace the HOut transistor and have the FBT (flyback transformer) ring tested.
Good luck and thank you for asking.
Aug 19, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Tv code for remote control
Hi trinidat
To answer your question;
In many cases the 4 digits code for sony tv`s is "0000"
But if you let me have your remote`s brand name and model # i may be able to help you further.
The model# may be inside the battery compartment.
Be waiting for your reply
Jan 27, 2010 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Hi, my sony trinitron Wega KV-32Hs500 will not come on. The stadby light blinks 6 times. I was able to get it on yesterday after repeated turn on, but now won't come on at all. It was working great and had...
common problem. sony makes a power suplly service kit that will repair it. cheap. the power supply is very efficient but ver sinsitive to power surges. easy ans cheap. good picture is worth fixing.
Nov 15, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
No Power Problem with KV-27s15 Sony TV
Barry, remove the back cover by removing the screws with an arrow next to them. The fuse is located on the left side as viewed from the back, where the power cord connects to the circuit board.
Aug 09, 2009 | Sony KV-27S15 27" TV
SONY KV-27FS20 TV does not start
Only 3 things bad Flyback transfomer,bad picture tube ,shorted hori output transistor. more then likely you have a bad picture tube,ive already throwed over 20 sets out due to bad tubes.
May 04, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv-32fq86e 16 blinks
If red led blinks continously , please check horizontal o/p or EHT screen control reduce and check for power on
sam
Apr 18, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-27FS100 does not respond to remote
Good day.
Maybe there are loose connections along the IC that supports the operation of your remote. This could also hamper initial set up operation of your unit. Also, check on loose connections along the power supply.
Chris
Mar 02, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
KV-27FS12
hi there, there is a problem at your power supply section. do some test, it maybe a electronic part faillure. ty
Dec 28, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Sony KV-32FS12 32" TV Logo
448 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
