Question about NetGear DG834G 802.11G Wireless ADSL Firewall Router [ DG834GNA Wireless ] (114587)
Port forwarding,I am retarded
I would appreciate help if someone can assist me with forwarding my port...(Billion 400g)
    Problem Solver:
  • 8 Answers
Totally disconnect router from computer reboot system.with your router you should have a install disc.reload the disc and follow the instructions.when you reboot your computer should find your router.hope this is of help.
Posted on May 10, 2009
Router port forwarding
Check out:
http://portforward.com
It'll assist you with setting up port forwarding on most major routers.
Hope this helps!
Aug 24, 2014 | Computers & Internet
Port forwarding
WHEN YOU OPEN A PORT YOU NEED TO ASSIGN THE DEVICE THAT GOES ASSOCIATED WITH IT...LIKE PC1 IP 192.168.1.1
PC2 IP 192.168.1.2 THE PORT YOU WANT TO OPEN NEEDS TO BE ASSOCIATED TO EITHER PC1 0R PC2 WHICH EVER IS RUNNING YOUR APLICATION...TEKGODS.COM
Feb 18, 2013 | D-Link DSL-2740R Wireless N ADSL2 4-Port...
How do i enable port forwarding on my router?
Port forwarding is you need to know what address you to port fowarding. It is usually under the administration tab.
Nov 21, 2009 | Hawking HBR49 Router
I want to know how to open my ports and forward them pls
Its simple to open or forward a port. Please go to this website, www.portforward.com and look for Common Ports tab. That will tell how to open the ports.
Oct 22, 2009 | Zyxel P660HW-D1 Router
Can't use irc undernet server this is the error Local host: siemens (10.0.0.100) --us.undernet.org- *** Looking up your hostname --us.undernet.org- *** Checking Ident --us.undernet.org- *** Found your...
I would suggest you port forward port 113 (IDENT) port from your router to your computer. You'll need to look up instructions on how to do this, as all routers are different.
in mIRC type /identd on <some IDENT ID here>
in the above command, notice the word is IDENTD not IDENT
then try reconnect. The <some IDENT ID here> will show up in a whois as <your nickname>!<some IDENTD ID here>@<your isp>
Looking at your output that you've pasted, I'm also assuming you're using the mIRC IRC client.
Oct 10, 2009 | Computers & Internet
Connection from billion 400g wireless adsl router to Fujitsu
please check your fujistu if there is wireless lan built-in...
Jun 16, 2009 | NetGear DG834G 802.11G Wireless ADSL...
Port forwarding billion 400g
Port Forwarding
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Jun 03, 2009 | NetGear DG834G 802.11G Wireless ADSL...
I don't know how to remove "ports"
You need to specify exactly what you intending on doing. There is a difference in Port Triggering and Port Forwarding. If you are wanting to open a port on a machine you want Port Forwarding. There should be a place to specify a custom range of ports for any given computer on the network. Note that you cannot overlap ports (Cant port forward a port twice).
Dec 11, 2008 | Arris BR700 Router
Port Forwarding for Transmission
This web page has a wonderful graphic step by step to use port forward for your linksys router:
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/default.htm
Hope this helps.
Mar 29, 2008 | Linksys Wireless-G WRT54G Router
NetGear DG834G 802.11G Wireless ADSL Firewall Router [ DG834GNA Wireless ] (114587) Logo
580 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
