Question about ASUS P5P800-MX Motherboard
What memory stick and graphic cards to get
Well am avi n i nid help plzzz i dnt no which compatible graphic card to get for my pc with bmotherboard Asus P5P800-mx as i dnt hav an agp slot n dnt no if it is a pci express or not!!
n also compatible memory stick my board...
thnk you in advance plzzzzzzz help
    President:
  • 1,901 Answers
Your motherboard has 3 PCI slots. Any card you install can only be a regular PCI card.
The RAM in your motherboard has to be DDR (333 or 400) 184 pin DIMM's.
Here is a link for your motherboard manual:
Asus P5P800-MX Manual
Layout pic is on page 1-7. Info on your memory is on page 1-15.
Thanks for using Fixya.
Posted on May 10, 2009
    Sergeant:
    Novelist:
  • 197 Answers
Unfortunately your motherboard doesn't support PCI-e. The only type of video card you could use as an upgrade is a standard PCI video card. They exist, but are becoming increasingly more rare with the release of PCI-e video cards.
    Sergeant:
    Champion:
  • 242 Answers
Super Talent 2GB (2x1GB) DDR400
http://www.newegg.com/Product/Product.aspx?Item=N82E16820609058
ati 2400pro PCI
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131082
I have problems with card reader is not compatible with w in 8.1 pro
Hello
Probably you need to download Driver for it to use.
Hope this Helped
Apr 10, 2014 | Sony VAIO Computers & Internet
Will a DDR3 graphic card work as it should work on a DDR2 motherboard or ram
Add more RAM
If you're not sure if a module is right for your system, use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules.
First you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system.
You should always ask for a guarantee on the compatibilitybefore making any purchase and try to buy for working pairs if possible.
computer users often get confused when assembling or upgrading their first computer. While the most common error is made when distinguishing system memory, RAM, from hard drive space, gaming computers have an extra wrinkle to worry about.
Graphics cards use memory separately from the system memory mounted on the motherboard. Some graphics cards use the more typical DDR standard, though it's permanently attached to the graphics card circuitboard, while others use the new GDDR standard.
For the most part, the internals of the graphics card aren't relevant to the rest of the computer it's all about the connection slot.What Is DDR Memory?
DDR, or "Double Data Rate," is the standardized random access memory format for most desktop and laptop computers.
DDR RAM comes in different generational standards: DDR, DDR2, DDR3 and the newer DDR4.
RAM chips, known as DIMMs, come in only one format, as do the DIMM slots on motherboards, so a DDR3-compatible motherboard memory slot can accept only DDR3 RAM DIMMs RAM that uses an earlier or later standard is incompatible.
GDDR Memory and Graphics Cards
Modern graphics cards use a modified memory standard called GDDR, short for Graphics Double Data Rate. While similar, GDDR and DDR memory is not the same:
Most importantly, GDDR memory is integrated into the graphics card and cannot be removed. Some older graphics cards use DDR, DDR2 and DDR3 memory, but this is also integrated into the card.
Graphics cards of varying power come with different kinds of RAM as of the date of publication, most cards feature GDDR4 or GDDR5 memory
Graphics Card Motherboard Connections
Discrete desktop graphics cards are mounted inside a computer case and plugged directly into the motherboard.
Three standard connections are used for graphics cards: PCI-Express (the most common and powerful), PCI and AGP.
It is this connection that determines how much data can be shared between the graphics card and the other system components, such as the CPU, the system RAM and the hard drive.
The expansion slot standard is the primary function for determining whether or not a graphics card is compatible with any given computer:
If your motherboard has a PCI-E slot, it's compatible, if not ideally so, with all PCI-E graphics cards.
Graphics Card Memory and System Memory Compatability
Memory is an important part of game performance, but graphics memory and system memory are two different things.
For better performance, it's best to have as much graphics memory AND system memory as possible, but the different standards used by the graphics card and the motherboard are largely irrelevant.
As long as the graphics card uses the correct expansion slot standard, it will work with the corresponding motherboard, regardless of its DDR version.
Mar 10, 2014 | IBM Lenovo ThinkCentre M55e PC Desktop
Memory stik problem
Have you tried another memory stick? Or have you tried this stick in another PSP? This will tell you whether the stick is faulty or there is something wrong with your PSP.
If the stick is faulty then buy another, otherwise take the PSP to a repair centre.
Apr 15, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
I have abrand new Dell XPS 8100 with upgraded memory to 8mb and an ATI 5770 graphics card. When I start the computer I get 6 beeps and the PC does not start. Fitted a replacement Graphics card, still the...
Depending on the main board, 6 beeps usually signify's either a RAM issue (like a bad connection or incompatible ram) or an expansion slot issue so check any other cards you may have installed and make sure that The new RAM stick is compatible with the main board.. The main board model code is printed on the main board. Use it to search for audible fault codes, or go to www.upgrading and repairing computers.com and search for the beep codes for the main board on this site. Also, try reseating all the RAM sticks and expansion cards, especially graphics card..make sure you have not dislodged any data connectors and double check everything..
Feb 05, 2010 | Dell XPS 200 PC Desktop
White screen on boot
this seems to be a problem with your graphic card, it may not be compatable with your system,or may not be fixed properly in your motherboard or it may be damaged as u said. I suggest get your card fixed or try it in someone else's computor to check if the card is fine or not.
Jul 27, 2009 | Sapphire RADEON X1550 Graphic Card
Upgrade video graphics
try getting new sticks of ram 2 512mb sticks should do or it could be the physical memory.
Apr 18, 2009 | EliteGroup K7SEM Motherboard
Want to format the memory stick through w220i
i think your card is dead... i had the same problem, when you insert your card, it restarts, and will not turn back on, until you take the card out, right?
here is what you can try to do... download turn of your phone, connect it to your PC...
download THIS
try formating your card with this software...
NOTE: be carefull that you selected your phone card, and not your PC hard disc...
if it doesnt work, your card can not be repaired...
Feb 05, 2009 | Sony Ericsson W200i Cellular Phone
Radeon graphics card and 3rd RAM slot conflict
I thought this board looked familiar to me. I recall some rules for the memory cards. Do all your memory cards meet this requirement:
Supports up to 3GB PC1600/2100/2700/3200* DDR SDRAMs
If you are using DDR 400 you can only use 1 slot.
What kind of memory are you using?
Jul 05, 2008 | MSI KT4V (MS-6712) Motherboard
Problem with memory stick micro m2
is the card being read on the other device like camera/mobile etc.
if yes than card is okay
its the pc which is not compatible with your card. in this case u cannot do much but buy a card reader costing 5 usd
Apr 27, 2008 | SanDisk Memory Media
ASUS P5P800-MX Motherboard Logo
172 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
