694708-225 Intel dual CPU Motherboard
Can you please help me with any info and manual for a... 694708-225 Intel dual CPU Motherboard
Thnx
Dave
  • 4 more comments
  • 995225 Oct 12, 2007
    Thanks for your feedback . but it was really the tip of the iceberg, so to speak..
    Ok.. here goes I will try to give you an overview of what I am trying to achieve..
    I recently got my hands on a Cacheflow 3000 server, real cheap and was wanting to remove the existing internals (N440BXserver board) and install my exsisting server board (SUPER P4DC6+ dual xenon board)..which I have been getting parts together for quite a while now…. problem is its power config is 24 + 8 + 4 pin , and the Cachflow 3000 only has a 20 pin and a 14 pin (non atx) config.. does anyone know how to mod this to work with the xenon board.. as i have searched everywhere for a solution...
    If you need any more information.. just let me know..
    Dave
    i was wanting to use the 2 redundant hotswap PSU's that are already in the cachflow case, as i have already powered up the xenon board with a spare 600w atx psu and installed the os on my scsi raid array..
    that will solve the 20 pin issue.. but.. the PSU's wont fire up... i need to trigger them in some way... as on the intel board thats in the case at the moment there is a 14pin (i think) connector that is maked as "aux power" that believe is some sort of PSU monitoring conector.. .. does that make any sence..? or am i rambling... again.. (been known to sometimes)
    yes there is a manual switch on the front of the case, but on the 20 pin cable that plugs into the existing board, the pwr-on (green) wire is not there.. which was the thing that got me all confused, as i was thinking that it used the other connector to power up..
    yup.. that aux power connector goes to the backplate.. there must be a way to wire that to boot the PSU's..
    ok.. have you got an email..?
    Scholar:
  • 116 Answers
Good news :) You have a Intel® N440BX Server Board and All information regarding this board is available at intel's website.
Main Link
That particular board supports all the P3 chips.
Here is a link to Drivers, and stuff :)
Drivers Link
Posted on Oct 12, 2007
  • 6 more comments
  • Charles Fields
    Charles Fields Oct 12, 2007
    You defiantly need to buy a new power supply, even if you could mod the old one, you wouldn't want to. The PSU 12v rails would never hold up to the xeon power requirements. You would just slowly burn up that fancy board :)
    Are you wanting to just use that cute little case? Or maybe your hoping the cacheflow software will work with your new xeon?
  • Charles Fields
    Well ok then ;)
    Here is a link to a AT to ATX power converter :)
    Linkage
    I guess that is what you want?
  • Charles Fields
    No its just the standard AT power connector of the day. As for the PSU, you should have a manual power switch with those. If not, you can connect the green wire in the 14pin connector to ground, and it should fire up.
  • Charles Fields
    Nope, should be that front power connector. It should wire right into the PSU's However with redundant PSU's i donno for sure :) They should plug into a backplane. And the backplane into your board.
  • Charles Fields
    Any chance you can take a picture of that. If the AUX connector doesnt connect to the backplane, then i'm unsure of what you have.. :)
  • Charles Fields
  • Charles Fields
    FTP Link to PDF
    Yep, not what i though we were talking about. You can mount your own power switch. Just mod the connector.
    Page 97 of that PDF explians all the wires.
    Looks like pin 9 and 7 would be the wires you need to connect to get power :)
  • Charles Fields
    Charles Fields Oct 14, 2007
    Can you change the best solution on this?
    Habit-Forming:
  • 188 Answers
Pls provide some more deyails-like
1-ur computer brand
2-model no (on cpu chesse)
i m sure i can help u///
u can mail me [email protected]
best regards & best of luck..
SOURCE:
Intel Cpu Pentium Dual-Core E2180 2.0Ghz Fsb800Mhz 1M Lga775 Tray Logo Problem with the Intel Cpu Pentium Dual-Core E2180 2.0Ghz Fsb800Mhz 1M Lga775 Tray I have no audio driver for my pc
every other detail...but...motherboard...assuming it has onboard sound.. google drivers for the make and model of your motherboard soundcard should be there somewhere.
Apr 19, 2011 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
What is a version of Biostar G31d-M7
Socket LGA 775
Supports Intel Core 2 Duo/Pentium Dual-Core/Celeron Dual-Core/Celeron 400 Series Processor
Supports FSB 800/1066/1333MHz
Support Intel Hyper-Threading Technology
FSB 533MHz is not supported by this motherboard. CPU TDP over 65W is not available. Please refer to CPU support for further information.
hope this helps
Mar 02, 2011 | Biostar G31D-M7 Motherboard
Sound is not coming due to unavaility of audio driver so please giv the audio driver for intel e2180 cpu
If your motherboard is an Intel motherboard then -
You can download the motherboarddrivers from Intel WEB site. Select your model motherboard/device, and makesure you select the Windows XP or Vista version of the drivers that matchesyour Windows operating system. Please click on this link andselect your model motherboard : -http://downloadcenter.intel.com/default.aspx?iid=gg_support-au+home_downloadctr
Jan 08, 2011 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Asus motherboard model P5VDC-X compatible processor
ASUS P5VDC-X supports Intel Celeron, Intel Pentium 4, Intel Pentium D Processors. The motherboard is capable of supporting the Intel LGA775 Pentium 4, the dual-core CPU, as well as compatibility of either 64- or 32-bit architecture.
Please refer to Product Manual for ASUS P5VDC-X Motherboard for further details (if required)
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 03, 2011 | ASUS P5VDC-X Motherboard
I have intel(r) pentium(r) dual cpu e2180 @ 2.00ghz 2.00ghz on mercury mainboard i have cd of mercury main board but drivers can not installed by that cd.so i find drivers as sound and lan drivers on net...
search with the motherboard name and model in google... you will find the drivers.. or go to the original site of mercury for driver download for your model.....
Oct 20, 2010 | Intel Cpu Pentium Dual-Core E2180 2.0Ghz...
Will Intel Core 2 Quad Q9300, 2.50 GHz processor work on asus p5n73-am motherboard..is it compatible, will the motherboard crash or will the processor overheat. I am looking to change my current processor...
Motherboard info
Yes it'll work. Worst case scenario is that you will need to do a bios update. Overheat should not be a problem if you are using the intel reference cooler wich is provided with the cpu.
Mar 03, 2009 | Computers & Internet
I want UNQUIE CPU ID NUMBER FOR MY CPU (20-11-08)
OK you will need to enable the CPU serial number feature in the bios (if your bios supports it)
or
You can download the Intel Processor Serial Number Control Utility from Intel here: http://downloadcenter.intel.com/Detail_Desc.aspx?strState=LIVE&ProductID=24&DwnldID=823&agr=Y&lang=eng&PrdMap=24
let me know if this info helps
thanks
Note: Check bios first for option because the utility above may not work if the option is disabled in your bios. (if your bios does not have that option then utility should work fine by itself)
Nov 20, 2008 | Intel Server Board S5000PSL - Motherboard...
Open Questions:
Computers & Internet Logo
455 people viewed this question
Ekse
Alun Cox
