I recently found my old Gemark 101 tape recorder in my storage facility. I received this as a gift in the 1960s and haven't used it since the late 70s. Now I brought it home and tried to play back some of my old recordings on it and having problems. It turns on and the left reel runs properly but I think I might be inserting the tape around the front of the machine incorrectly because the right reel doesn't move and I would really love to hear these old tapes again. Any suggestions greatly appreciated. Thank you
  • Frank Allik
    Frank Allik May 11, 2010
    WOW WHAT A FIND....its pretty straight forward set up....I dont think you can put it in wrong....looking at it..the source reel will be on the the side that DOESNT MOVE and the receiving reel will be on the MOVING reel...providing its in forward and at the correct speed...check it out and let me know...
3 Suggested Answers
SOURCE: My Teac Z-7000 will not record tapes
some weeks ago I got this really impressive deck (Teac Z 7000) from a colleague, and found the same problem. I fixed it, and the fix is not too complicated. It´s the potentiometers that do fail. All pots are from the same manufacturer (Alps) and construction. The problem is that the wisher is broken away from the holding plastic and will loose contact completely. You can check that with a normal ohmmeter: You´ll find the total resistance over the outer terminals but endless resistance from one of the outer terminals to the middle wisher contact. The values are: 100 kOhm linear for each of the upper left pots (fader,space), 2x22kOhm pos.log. for the lower left pot (phone volume). So, what does a broken wisher at the "fade in" pot do? The Recorder "thinks" that You selected an "endless" fade in time, and the result is : no record level. You can do an easy "quick and dirty" fix just to see if that´s the problem: Hold- or better solder- a say 47kOhm resistor in parallel to the conducted potentiometer terminals and try to record.
4 of 5 pots have been defective in my deck, and I´ve replaced them with standard types from my local electronic supplier (Conrad electronic, has a shop in Frankfurt/Main). Well, the new parts didn´t fit perfectly, I used a file to get them in (not visible from outside). Also I lost the possibility of pushing the knobs in and out, but that is not a really problem.
I assume this fix might also help owners of the Teac Z-6000 and Z-5000, which- most probably- use the same type of potentiometers.
This text was written by Boris Witke, Kelsterbach (near Frankfurt/Main), Germany. E-Mail:
witke1@web.de Please tell me if You were successful, possibly we get lucky users of these really fascinating machines.
Posted on Feb 24, 2009
SOURCE: I have an AKAI GX-4000D
Yes, that seems to be your problem.
Regardless of the size of reel.
When the:
Capstan sleeve installed is 7 1/2 IPS
Capstan sleeve not installed is 3 3/4 IPS
Hope this helps.
Robert
Posted on Oct 10, 2009
Using Bose 901 Equalizer on Yamaha HTR-5840 Reciever
The manual is linked below. Page 19 advises you to use the "MD/CDR" - "IN (PLAY)" and "OUT (REC)" analog audio jacks.
http://data.manualslib.com/pdf/20/1975/197493-yamaha/htr5840.pdf?ace7c7b79ec34305a811125fb9ef1160&take=binary
Jan 27, 2014 | Yamaha HTR-5840 Receiver
When my husband died, I kept his voice message on my answering machine. I accidently erased the voice message, and haven't been able to get it back. To hear his voice answer when someone called was...
well there is a solution... But it depends, is your machine uses a tape or digital recording device.
If it is a tape, than it can be a very tricky. You will need to contact some kind of recording studio as in music or news studio or police forensic (if you have friends there) and they might be able to retrieve it. If it is a digital than it is simple, all you need to do is to go to any computer place and ask them to recover a lost data. they will transfer it to a storage device such as flash drive and that's it, although it might cost you up to $300-$400.
Sep 13, 2011 | AT&T Cell Phones
Hey there, I have an AudioControl model C-101 EQ, and I just wanted to know how to hook it up to my Yamaha RX-v363 Receiver, thank you, I appreciate it.
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Mon as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? That logical problem also plays into the decision to defeat digital sources if the Tape Mon is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up: Receiver Tape- or VCR Out to the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-In; Receiver Tape- or VCR In from the External Processor (EQ, whatever) Preamp-, Amp-, Tape- or Rec-Out.
If you actually want to use an analog recording deck you could place it within the typical Equalizer's own Tape Monitor loop(s). Many have two to facilitate equalized dubbing between decks.
Aug 09, 2010 | Audio Players & Recorders
Sony CCD TR31 - tape holder will not lower into camcorder
Does the tape have blocking tabs that prevent recording? May be telling you that you can't use that particular tape.
If not take it in for professional repair. I think Sony is in Mississauga.
Andrew in Mississauga :>)
May 16, 2017 | Panasonic PV-GS2 Mini DV Digital Camcorder
Sound playback problems
are those old videos recorded from the same camera? you might need a head cleaner for your camera. Try to play the tapes in different camera for comparison test. caution: make sure that the camera's mechanism does not destroy the tape or put a line or dent on the tape's edges. I suggest you convert those videos to digital format before it's too late.
Aug 10, 2009 | JVC GR-D870 Mini DV Camcorder
Playback problem
Have the same problem.  This is what I have found in trying to solve the problem.  It appears that it is a tracking problem and it appears that either your new "used" camera has the problem or your original camera had the problem.
A simple test would be to take another camcorder and see if the tapes play. If they do, and a recently recorded tape DOES NOT, you may just need to get another camera. Or, see if the camera can be re-tracked at a repair shop. However, be sure you have copies of your most recent tapes recorded with the bad tracking
Feb 09, 2009 | Activision Soldier of Fortune: Pay Back
MARANTZ PMD 101 PROBLEMS, COUNTER AND REWIND
Get the belts changed, and check a clutch inside the mech which drives the auto-stop mechanism.
It works in a way that it normally holds the auto-stop off if the spools are rotating, but when it wears, there is no srive through it to hold the auto-stop off, so the auto-stops stops, if you see what I mean.
Any good audio tech should be able to do this, if the machine otherwise works OK, it is worth doing because these are very nice and usually reliable machines.
For musical work though, the CP series are usually better, as they provide 3-heads and off-tape monitoring, with better quality and the facility to set tape bias to suit high-grade tapes.
May 29, 2008 | Audio Players & Recorders
Horizontal snow lines on record and playback
the symptom is caused by a dirty video head. sometimes cleaning tape cannot do all the jobs, especially when the dirt is so much that any cleaning tape cannot remove it. open the cover, use a clean white paper dampened with a little alcohol. use your finger on the paper and gradually move the head drum back and forth. donot move the paper up or down. just move the drum slowly. good luck!
Jan 31, 2007 | JVC GR-FXM38 VHS-C Analog Camcorder
112 people viewed this question
 Grubhead
Grubhead
