Question about Philips DVP5982
Password bought the new dvp5982 was having no problem playing dvds for a month.One night the system would not respond to remote control so I powered it down.Now I am unbable to play DVD's because the system is asking me for a password which I do not have.
Re: password
Try 136900 for the password and if that works you can go into setup and unlock DVD.
Posted on Jan 19, 2009
  • 26 Answers
Re: password
Sometimes weird things happen and you could've accidentally locked the unit. Some units allow you to reset the password from within a hidden preferences menu. It's usually the same menu that allows you to change your region of your DVD player and/or make it "region free". Here's a page with explanations on how to access that menu. Good luck!
DVP5982 Hacks
Posted on Oct 12, 2007
0 characters
3 Points
I want to find a service manual for my RCA Blu-ray Home Theatre, model # RTB1023. It won't turn on with or without the remote control.
This unit has two problems.
One the fan is very noisy with a short time in use.
The Other problem is a capacitor in the power on circuit.
this capacitor shorts out the power button and needs to be replaced.
I forced my machine to work by unplugging the Rtb1023, continuously pressing the power button while plugin the Rtb1023 in, if it powers on test the temperature of the capacitor in the photograph, If it is hot replace with a 22uf 200volt electrolytic.
Be careful Hot temperatures can burn.
P.S. Unit was given to me got it working for under $5.00 including the new fan.
Oct 02, 2014 | DVD & Blu-Ray Players
I can't find the remote for the phillips dvp 5982 Do you know where I can get a replacement or is there another way to control the DVP other than its own remote? Thanks.
Here is the link to order this remote from Phillips: (its long, and Im not sure if it will come across to you as clickable but certainly if not, copy and paste it). I found the link to order this remote by first going to the Phillips website, then in their search box, typed in your model number then clicking on parts search. They also offer many universal remotes on that site which will work with your model so that using the exact model remote is not necessary. Have a great day.
Feb 21, 2011 | Philips DVP5982
Samsung P480 dvd player- To Play all region dvds
how can I play *.mp4 files in samsung dvd player model no P480?
Mar 11, 2009 | DVD & Blu-Ray Players
Bought a philips dvp5982 dvd player because we understood you can play all region codes on it. My wife bought 2 exercise videos which you cannot get in the U.S. Is there a way to convert so we can play...
- Press "Setup" on your remote.
- Go to the right to select "Preference"
- Press 1,3,8,9,3,1
- Press up or down to scroll through the regions; select "0" for completely region-free.
- Then press "menu" to exit.
Jul 24, 2008 | DVD & Blu-Ray Players
Wrong Region message
This will make the player region free so it'll play anything. It worked on mine and i have the same player.
remote control :
- Press "System Menu" key to enter Set Up menu.
- Move to "Preference Page" using arrow keys to the left or to the right.
- Press the following sequence in the remote control: 135566
- A menu indicating "Region Code" will appear.
- Change region using arrow keys to top or down. Region Code = 0 will play all regions.
- Press "System Menu" key to exit Set Up menu.
Jul 14, 2008 | Philips DVP5982
LG V692wk won't play DVDs
A faulty laser or the connection could be breaking!
May 17, 2008 | DVD & Blu-Ray Players
Player going into standby mode itself
Does it work in India? isnt it 120V compatible for US only? I am aasking as I have the same unit here in US and moving to India...
Mar 08, 2008 | Philips DVP5982
Dvd recorder region codes
1. Press the Menu button on your remote control
2. Press the 5 button on your remote control
3. Press the 7 button on your remote control
4. Press the 5 button on your remote control
5. Press the 3 button on your remote control
6. Press the 8 button on your remote control
7. The currently selected region will be indicated on the TV.
8. Press the 1 button on your remote control for region 1, the 2 button for region 2, and so on, or the 9 button for multi-region playback
9. Press the Menu button on your remote control
10. Press the Menu button on your remote control
Tested with Region 1 DVD's on my UK player (Region 2 bought from Comet)
Jan 28, 2008 | Apex Digital AD-1110W DVD Player
A piece of junk dvd player I just bought
Here's the support site with contact information. When you say it "quit working," how so? Does it spin up/power up? Are you having trouble playing DVDs? What model? It'll help to troubleshoot if you can give us more details.
Dec 01, 2007 | DVD & Blu-Ray Players
LG DVD player LG276
I picked up a LG DV276 DVD Player here in Australia but I am from the United States so I own region 1 DVDs. I unlocked my new player by instead 1. Open the tray. 2. Press 0 0 0 0 on the remote and a Menu will appear. 3. Press 0 for region free. 4. Press pause and power off.
I can play everything now, Aussie and US DVDs. Thanks LJ66.
Dec 01, 2007 | LG DV276 Recorder
Philips DVP5982 Logo
653 people viewed this question
Top Philips DVD & Blu-Ray Players Experts
Level 1 Expert
rugby prop
Are you a Philips DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
