Be sure that your keyboard is configured properly. You should be able to check under the "Region and Language" area of control panel if you are in windows and select "Keyboards and Languages." Check that it is set as a US keyboard or that it's set to which keyboard type you are using.
where function is the expression you are differentiating x
is the value of variable x at which you are evaluating the derivative,
and tol is the tolerance (the error) you are willing to tolerate in the
result.
If you do not want to specify a tolerance just omit the last comma and tol.
To enter the command d/dx you use key sequence [SHIFT][Integral] To enter the symbol x in the expression you press [ALPHA][ ) ] To enter a comma you use [SHIFT] [ ) ] To enter a power of 10 in the tolerance use [x10^X] key
Go to control panel and check the regional and language settings. make sure it all says English and/or United States, if you are in the states that is, otherwise the keyboard will be different.
