Question about Toshiba Satellite A100-S8111TD Notebook
My advent 7302 showing different numbers and letters
I have an advent 7302 on which i have to keep the fn button down to get the correct numbers and letters
Advent 9517 several letter keys bring up numbers
Touch Freeze, a free utility program may help fix that problem. I assume this just started to happen, correct?
If that fails, try another keyboard, preferably a USB Wireless Mouse/Keyboard.
Jan 08, 2014 | Computers & Internet
Laptop types numbers instead of letters
Hi!
You have enabled NUM LOCK. Press button "fn" and find another button with blue tag "Num Lock". Pres both buttons at once.
Hope it helps
Jul 10, 2011 | Dell Inspiron Mini 10 Notebook
My laptop, a Satellite #L455, is giving me numbers when I type in letters. This does not occur all the time but often when I'm playing games.
the letter that does is U,I,O,PJ,K,L,M it happens all you need to do to fix that problem is press the Fn buttin and while keeping this down it should be the F11 button make sure you look at the other F button as it will show you a little box with load of dots inside it if it is the F11 button then pressing this once will turn it back to letters this function is for when your doing calculations its easier to use it but some people dont like it you can turn it on and or off by pressing the Fn button and pressing the F11 button
Jun 29, 2011 | Toshiba Computers & Internet
I have an hp mini laptop..whenever i press letters u,i,p,o,j,k,l,m it shows numbers 4,5,6,1,2,0. maybe i had typed something which made this like this..how do i do it.
The problem is that you have to turn off the number lock hold FN key and press the scroll button wherever its on your keyboard usually its after the f12 key,, that should fix your problem...
Jun 08, 2010 | HP 2133-1 Mini-Note PC
Unable to find wireless switch on Advent laptop. There is a key combination like Fn + F10 but I cannot remember which.can you tell me?
Hi Friend,
Please find the key combination (for wireless/switch) for different Advent laptop models:
Advent 7096 ---- Button next to the power button
Advent 7100 ---- Fn / F2
Advent 7104 ---- Fn / F2
Advent 7201 ---- wireless key top right and then Fn / F2
Advent 8117 ---- small slide switch on the front of laptop
I hope this will resolve the issue.
Regards
Chiranjeet
May 20, 2010 | Computers & Internet
Half of my letter keys when i type are numbers???????
You have number lock on "num lock" fine that key on youre keyboard (ussualy top right) and press it. If its colored then press it with function key "fn" left down side of keyboard.
May 02, 2010 | Advent Netbook
Wh y do I get numbers up instead of letters on the right hand side of the keyboard
Your NumLock is probably ON.
Hold down the Fn key and look for the NUMLOCK key. It is likely in a different colour than the regular characters.
Jan 25, 2010 | Advent Netbook
Hi my advent laptop says its wireless enabled but when i have tried to set it uo with my wireless router it says i have no connection i have been told by my internet provider to get intouch with advent but...
You may have turn the wireless radio on first before you can connect to the internet.
Look down the sides of the laptop for a small slide switch and push it, an LED light should come on.
If you can't find a switch then hold down Fn and hit the F2 key.
Regards.
Nov 17, 2009 | Advent Netbook
How to gat it to type letters it is stuck on numbers
Number Lock is enabled.
Look for a 'function' button usually labeled 'fn' and in a different color.
Hold that down and then hit the Num Lock button.
If you don't have a 'fn' button just hit the Num Lock button.
May 23, 2009 | Samsung NC10-14GW Notebook
Keyboard types upper case digits instead of lower
It sounds like you may have turned on the calculator function - Does one of your F keys have a light on - F10 or F11, if so Press Fn and the key that is lit up.
May 21, 2009 | Advent Netbook
Toshiba Satellite A100-S8111TD Notebook Logo
100 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
