Question about Hobart HL600 Legacy Stand Mixer
Hobart M-6007 Wiring..
I purchased a used 60 Qt Hobart mixer, here are the specs:
SN: 2735195
Spec: 172A3
Model: M-6007
HP 1
Amps: 2.8
Volts: 440 Cycle 60, phase 3
I do have 440 3 phase power in my building. Anyway this unit was wired directly, the problem is they disconnected the power cord completly, all that is showing is the wire grommet.
My question is where does the wire connect to from the power source? I am having the elctrician coming in this Monday and would appreciate an answer as soon as possible.
Thanks
Nick
  • 2 more comments
  • nicknroberts May 10, 2009
    Thanks for the answer, you are correct, someone removed the entire cable, the grommet is all that is left, but my question is, three wires plus the ground, (440) hasve to be attached to the mixer, my question is, where do they go? Once the electrician comes in, all he is going to do is run the wire about 69', he already said he does not work on 440. Anyway if you could just simply diorect me where the wires afre connected to the mixer..
    Thanks
    Nick
  • nicknroberts May 13, 2009
    The electrician is coming in this Thiursday, I will let you know if your advice worked.
    Thanks
    Nick
  • nicknroberts May 14, 2009
    We went to the electrical box, and gthe volts coming out of gthe box are as follows: 125V 240V and 125V, we took this directly to the Hobart mixer and then this is where it goes a bit awry, we saw wires cut and placed them on the same poles but mixer does not work,. My question is where does the 240 V wirte go and the 2- 125V wires go?
    Thanks
    nick
  • nicknroberts May 15, 2009
    Hi, thanks for your help so far, but I think your last comment, although I am not 100% certain how this could be correct, our main ciurcuit box coming in is HUGE, it measures 2'x5' high, and this was a machine ship prior to becoming a restauarant. Anyway assuming you are correct and we do not have a 440 circuit coming into the building then how is the mixer going to work? The mixer is calling for a three phase, 440? or maybe I do not understand this part.
    As I mentioned we attached the three wires from this huge breaker box, three leads plus ground, yes we see the three leads and grounding screw and we attach accordingly, we tried each imaginable way, the 125V on the two outside legs and the 240V on the middle leg, vice versa and vice versa three times, the machine does not come on. We checked the switch and it is in working order and then we bypassed the transformer and went directly to the motor and the mixer worked perfectly, perhaps the transformer or whatever you call it is bad, anyway we are thinking of simply bypassing the unit and going direct and placing a timer switch as a break, simple but maybe effective.
    I have a camera to send pics but the attachements afre in Florida, so sorry about that..
    Nick
    I would love to send you pics of what you requested but the attachements to the camera are far away...
  • 246 Answers
Hello nicknroberts:
>>I have Read the Conversation between you and the Other Expert here.
>>If you Bypassed the Transformer and the Unit Worked, then the Transformer is the Wrong Transformer or is Bad.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 15, 2009
  • 232 Answers
Have you opened the box on the mixer,there should be a connection block there with three poles,generrally these are marked L1,L2,L3 those are the power connections,there may be a fourth for ground,if not there should be a screw attached directly to the frame for it,I imagine there may other connections to the block for the switches and if there are any low voltage circuits contained inside.I tried to find a wiring diagram but Hobart only allows their technicians to have these(trade secrets)I do triple phase electric work for a living so this is quite familiar to me.I'm not supposed to have contact with users outside of fixya,but if you can send me a clear picture of the mixer and the internal of the electrical box on the mixer,I can definitley solve this for you.Post back and I will give you my email if you want to send the pics.
Posted on May 14, 2009
  • George DeMore
    George DeMore May 14, 2009
    I forgot to mention the power that you tried to connect to the mixer is definitly not a triple phase circuit,A 440V triple phase will measure 440V from each of the 3 leads to ground.
  • 5,807 Answers
If possible can you give me a photo of the terminal where the electrician would connect the 3 phase motor, if not you would do like this, arrange the three terminal so that we can temporarily name the three wires. lets say line 1, line 2. then line 3, the trick is here you will be needing an extra capacitor to do this any at least 450vac capacitor will do. i also hope you have an extra 3 phase breaker just for testing this unit. you will wire the two terminal lets say 1 & 2 directly to the breaker you gonna have to connect the capacitor to the 3rd terminal.of the mixer and try to intermittently connect it to any of the two terminal just to see the rotation of your mixer it will rotate clockwise or counter clockwise also have the clip ammeter tester ready.it should be running not the normal speed but it will rotate.if mixer run you have a working mixer. the finalizing step would be to connect it directly. still the same process but instead of capacitor you will now connect it direct. lets say 1 and 2 will be interchange if rotation of the motor is reversed. might be also better if you can take down and note each ampere reading on the lines, they must have the same current or the mixer or breaker will trip. dont forget to rate me when it works
Posted on May 13, 2009
  • Rommel Cana
    Rommel Cana Jun 10, 2009
    you also need a magnetic contactor together with the timer, the timer cant handle it alone, hope this help
  • 1,000 Answers
The electrician will remove the access panel on the machine and wire it directly from the power source to the machine.
He will have the option of wiring 440 or 220 volt depending on your preference.
If you prefer the machine be mobile, a special receptacle can be installed and a pig tail installed on the mixer, however I would recommend the direct installation.
The installation will not be an issue of concern.
Good luck, let me know.
Regards,
Posted on May 10, 2009
  • Bruce Bracey
    Bruce Bracey May 10, 2009
    Once you remove the access panel you will see the lugs were the wiring is attached. The copper colored lugs are for the power supply or line voltage wires and the silver is for the ground or neutral wire.
    Let me know.
    Regards.
    President:
  • 1,489 Answers
I think I understand your question.
The cable from the power source will go though the grommet into the housing where all the connection terminals are.
There should be a way to remove the housing which has the grommet -- underneath you'll see the terminals.
There may be wires left from the old connection, but it sounds like the source cable was completely removed when the mixer it was deinstalled.
Does that answer your question?
I have a Hobart 60 qt mixer that has oil coming out the top around the shaft cover. What would cause this?
Do you really mean a 60 qt. mixer? That is industrial size and would be about 4' tall. Maybe a 6 qt. mixer? In either case, oil coming out around the shaft cover indicates that someone either over-lubricated the mixer or used the wrong viscosity lubrication. Has it been serviced recently? You might need to take it back to wherever it was serviced.
Feb 21, 2017 | Hobart Food Mixers
Change Hobart N-50 110 V / 60 Hz to 230 V / 50 Hz
You would need to provide the correct power to match the maching, or replace the rotor, stator, controls to match the higher voltage, and worm gears to correct the speed, from 60 to 50 Hz. Unless you don't mind it running slower. Cheaper to find one that matches your local spec..
Sep 25, 2009 | Hobart N50 Stand Mixer
Where can I get a manuel for my hobart D-340 mixer?
What kind of manual do you need. The service manuals are only given to Hobart technicians while they are attending training classes for that paticular piece of equip. I have a parts manual w/ exploded views if needed. A operators manual/guide can be downloaded from Hobarts website. You will need Model, Serial & ML # or spec #.
Jul 09, 2009 | Hobart D340-6007 Mixer
My 20 qt. mixer has no power in speed #1.
Hi All. Since the original poster has not responded to my request for ML and spec. #'s, I'll offer a solution based on a spec.# 3943 for anyone with the same problem. This is an older model A200 with a solid aluminum gearshift lever.
Stop using the mixer!!!
The slow speed gear (1st. gear) is engaged by a "diving key". Over time this key can wear to the point of failure, or break entirely and will no longer engage. This failure only affects the first gear, allowing the second and third gears to function properly. If you can stop the mixer attachment by hand while in 1st. gear, then you have the above problem. The unit must be serviced. If the key has been sheared there is the potential for a broken piece of this key to get into the trans. grease and cause further damage to the mixer. For a Hobart Tech., this is relatively easy to repair as a minimum number of parts need to be removed in order to expose the diving key.
Call your local Hobart office to schedule a repair. If you've never done any repairs on this model, do not tackle this project by yourself. I you have some experience with this model goto the hobartservice.com website, register for free and then download the parts list. Ensure that you have the list for the 3493 spec.
If anyone has been assisted by this solution, please rate it. ricardok45
Mar 17, 2009 | Hobart A200 Stand Mixer
Hobart mixer
Hi,im a hobart tech and know all these mixers well.What kind of mixer are you looking to write about?The differences are the sizes of bowls as 20qt,30qt,40qt,60,qt,80qt,140qt.Pick a mixer and i will write YOUR paper,but i want a fixya rating in return.
Mar 11, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart A200T General Info / Back cover plate gasket
I'm a service tech for hobart,I'll type your serial number into our database and see what it brings up.The changes that have been made---older units use a mechanical start switch on the motor,the new units use an electronic start switch.the old units center shaft and gears have changed.the older units dont have bowl guards and the new units do.(this is a cage that goes around the bowl).The gasket that your talking about is just that--a thin paper.The paper wears and you get that symptom you describe and its normal.I'll get back to you.
Feb 20, 2008 | Hobart A200 Stand Mixer
Hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
Jan 27, 2008 | Hobart D340-6007 Mixer
Hobart HL600 Legacy Stand Mixer Logo
257 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
